Ragtop Samba Member
Joined: November 23, 2003 Posts: 615 Location: Rio Rancho New Mexico
Posted: Sat Sep 04, 2021 4:35 pm Post subject: Split case Tranny in 63 Bus |
This one is new to me. Is there any advantage or disadvantge to putting a split case tranny in a 63 bus, besides that's what was laying around.
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Sat Sep 04, 2021 5:49 pm Post subject: Re: Split case Tranny in 63 Bus |
There is no advantage unless you like first gear growl and coming to a full and complete stop at all stop signs. |
Ragtop Samba Member
Posted: Sat Sep 04, 2021 6:02 pm Post subject: Re: Split case Tranny in 63 Bus |
buseric wrote: |
I was thinking the same but the adapter seems to be well made. |
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Sat Sep 04, 2021 8:03 pm Post subject: Re: Split case Tranny in 63 Bus |
That was a lot of work to make the adapter when they could have used a split case beetle nose cone and then bolt on to the later style stock mount. _________________ .
Wanted:
Ragtop Samba Member
Posted: Sat Sep 04, 2021 8:09 pm Post subject: Re: Split case Tranny in 63 Bus |
Lind wrote: |
That was a lot of work to make the adapter when they could have used a split case beetle nose cone and then bolt on to the later style stock mount. |
Its crazy the things people will do. I guess I can put an engine in and see if the tranny is good, then decide whether to leave it or put a tunnel tranny. |
Braukuche Samba Member
Posted: Sat Sep 04, 2021 8:18 pm Post subject: Re: Split case Tranny in 63 Bus |
I used to insist on split case in all my 36hp powered VWs in order to keep it real, but reality is getting parts and anyone to rebuild one has become next to impossible. Toss it in the recycling and get a tunnel trans. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Ragtop Samba Member
Posted: Sun Sep 05, 2021 9:37 am Post subject: Re: Split case Tranny in 63 Bus |
Braukuche wrote: |
I used to insist on split case in all my 36hp powered VWs in order to keep it real, but reality is getting parts and anyone to rebuild one has become next to impossible. Toss it in the recycling and get a tunnel trans. |
I'll probably end up just using the reduction boxes on a tunnel center section . |
Clara Samba Member
Posted: Sun Sep 05, 2021 12:54 pm Post subject: Re: Split case Tranny in 63 Bus |
Ragtop wrote: |
Probably they had a split case tranny that was good, so used it.
I bought a 66 DC that had a little nut tranny. Probably same deal.
x2 on what Lind said about the nose cone.
If it is good used, don't throw it away, someone wants it.
Nose cone issues putting a tunnel trans in split case bus meant I put a split case back in. But I never converted a tunnel case bus to split case. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Ragtop Samba Member
Posted: Sun Sep 05, 2021 1:45 pm Post subject: Re: Split case Tranny in 63 Bus |
Clara wrote: |
Ragtop wrote: |
Nose cone issues putting a tunnel trans in split case bus meant I put a split case back in. But I never converted a tunnel case bus to split case. |
Exactly that's what has me scratching my head |
EmpiGT Samba Member
Posted: Sun Sep 05, 2021 3:08 pm Post subject: Re: Split case Tranny in 63 Busr |
This bus doesn't happen to be a 1963 swr/bg standard does it? I sold one years ago that I put a split case in just to make it a roller. |
Ragtop Samba Member
Posted: Sun Sep 05, 2021 8:28 pm Post subject: Re: Split case Tranny in 63 Busr |
EmpiGT wrote: |
Its a 63 Turquoise panel |
AKdude Samba Member
Joined: May 16, 2016 Posts: 29 Location: The Far North
Posted: Sat Sep 11, 2021 9:04 pm Post subject: Re: Split case Tranny in 63 Bus |
Well, split case trannies aren't called "crashboxes" for nothin' .
And, if ya dont mind maxing out at 55 and getting passed by little ol' ladies in Ramblers, a split case might be for you. I got the original one in my '58 bus, and 1st gear is great for climbing trees, walls, and other minor obstacles. I like to start out in second gear so I dont have to come to a complete stop...
But, if you have a built motor in there, you might wanna put in a tranny with longer legs to enjoy the full power spectrum of it. |
Alan Brase Samba Member
Joined: March 28, 2004 Posts: 4532 Location: Cedar Falls, Iowa
Posted: Mon Sep 13, 2021 5:58 pm Post subject: Re: Split case Tranny in 63 Bus |
Anybody that grew up on old American cars should know how to double clutch an get it in 1st while rolling. Just gotta spin up the input parts till close to the same speed as it will be when in gear.
Been doing it for 55 years.
And what you gonna do if somebody give you a 1951? (they are all crashboxes/ sliding gears). _________________ Al Brase
Projects: 67 sunroof bug, 67 Porsche 912 Targa, 70 Westy
Dec 1955 Single Cab pickup WANT 15" BUS RIMS dated 8/55, thru 12/55
To New owners: 1969 doublecab, 1971 Dormobile
Vanagons:
80 P27 Westy JUL 1979, 3rd oldest known US
83 1.6TD Vanagon, 87 Wolfie Westy daily driver, swap meet home |
