Jimbug57 Samba Member
Joined: October 08, 2002 Posts: 817 Location: Mid Michigan
Posted: Mon Sep 06, 2021 5:59 am Post subject: #3 exhaust stud drill and tap |
The nut came off the lower stud on #3 exhaust. It stripped when I tried to put a new one on. There's not enough left of the stud to "double nut" it out. I can't budge it with vice grips.
I have the drill and tap for a step stud, which I also have. I've done this job a couple times - about 20 or 30 years ago. I'll try to cut the old stud off flush with the head, then drill a pilot hole and work it up to my 8.5mm drill bit, and tap with 10mm x 1.5.
I don't know how flush to the head I can cut - don't want to damage the sealing surface. I don't have a grinder. Also worried about getting the hole centered. I don't have a center punch.
I kinda think I know what I'm doing It has to be done today though. Please send any advice my way and wish me luck - Jim _________________ Repeat after me "I am smarter than metal!" |
fez68 Samba Member
Joined: December 12, 2015 Posts: 242 Location: massachusetts
Posted: Mon Sep 06, 2021 6:07 am Post subject: Re: #3 exhaust stud drill and tap |
just cut it off then make it nice and flush to the head. like you said use a small "new" drill bit in the center of the old stud, if it goes off center just angle the drill to get it back correct. then you can drill it out with the proper size for the 8mm 1.25 stud. then tap it . Ive done this numerous times. i would avoid the oversized stud if you dont need to. then install a new 8mm stud. I make my own from stainless steel bolts and cut off the head. or buy some. |
fez68 Samba Member
Posted: Mon Sep 06, 2021 6:10 am Post subject: Re: #3 exhaust stud drill and tap |
cut it off and use a sharp file to get it flush with the head. you could also try and run a die over it before and see if the nut goes on. I just did that also the othe day. the studs looked shitty but after i ran the die over it the nut went on nicely. try that first and then go about with the cutting. |
fez68 Samba Member
Posted: Mon Sep 06, 2021 6:11 am Post subject: Re: #3 exhaust stud drill and tap |
can you post a pic of the stud ? |
empi3 Samba Member
Joined: October 03, 2015 Posts: 347 Location: SW Wyoming
Posted: Mon Sep 06, 2021 9:09 am Post subject: Re: #3 exhaust stud drill and tap |
Check this out
"Cylinder Head Exhaust Stud Drill Jig"
https://www.thesamba.com/vw/forum/viewtopic.php?p=8801600&highlight=#8801600
Hope this helps and good luck!!
Steven _________________ The fact someone posts a thousand messages a month does not mean the messages contain anything worth reading.
Bob Hoover
1970 Beetle
1956 Ragtop Beetle |
anthax Samba Member
Joined: October 21, 2016 Posts: 283 Location: Hälsingland, Sweden
Posted: Mon Sep 06, 2021 9:30 am Post subject: Re: #3 exhaust stud drill and tap |
Weld on a nut on what's left of the stud and slowly work it loose.
It might need several attempts, but work very well.
I use this method almost weekly at work to remove snaped off and striped bolts.
No use in drilling and ruining the stud, when it's easier to just weld and remove. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Mon Sep 06, 2021 9:57 am Post subject: Re: #3 exhaust stud drill and tap |
anthax wrote: |
x2 _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Mon Sep 06, 2021 11:51 am Post subject: Re: #3 exhaust stud drill and tap |
Cut the stud off as close as I could get it, then filed it flush.
This is the second of 4 pilot holes. The final size was 8.5 mm. It was slightly off-center but it didn't seem to matter.
Ran a 10 x 1.5 tap in until I could feel it through the back wih the tip of my finger.
I double nutted the step stud in until it tightened up firmly and it was in up to the collar of the stud.
Thanks for all the responses guys, really appreciate it - Jim _________________ Repeat after me "I am smarter than metal!" |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9770 Location: Oregon
Posted: Mon Sep 06, 2021 12:21 pm Post subject: Re: #3 exhaust stud drill and tap |
Whad a bitch of a spot to drill and tap an exhaust stud!
Nice job! _________________ I have learned over the years.
Buy Once, Cry Once!
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Sep 06, 2021 12:23 pm Post subject: Re: #3 exhaust stud drill and tap |
Good job; I have done similar a long time ago, drilled and tapped to 8mm x 1.25mm. I figured the piece of old/broken stud in there would hold it, and it did. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
fez68 Samba Member
Posted: Mon Sep 06, 2021 2:01 pm Post subject: Re: #3 exhaust stud drill and tap |
I am glad it all worked out |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Tue Sep 07, 2021 4:38 pm Post subject: Re: #3 exhaust stud drill and tap |
Best of all is that you did it using only basic hand tools! |
