VJP5 Samba Member
Joined: May 22, 2021 Posts: 52 Location: San Diego, CA
Posted: Wed Sep 08, 2021 9:15 am Post subject: Help with attaching plywood deck to Yakima Roof Basket |
I need some advice as I am over my ski's on this one. I will also preface that I am a belts and suspenders guy when it comes to these types of projects. I tend to overbuild everything.
This is also not about weight. I understand the dynamic and static weight limit concerns and will be well under the limits for both moving and parked.
My concern is with the flooring.
I have added a Yakima Roof Basket to my tintop. It's sitting on 4 sets of crossbars (it's only 74" long and 48" wide). I want to add 3/4" plywood to it so we can use it as a deck, as well as for packing some odd items when going camping. As I see it, there are 2 ways for me to affix the deck to the basket.
Option 1 - U-Clamps, plates and lock nuts. These will have to be about 4 1/2" long and can mount to all 4 crossbars. This is likely the most secure, since those crossbars aren't going anywhere, but could also be overkill. I am thinking about 14 of them. 4 on the front, 3 on the two middle bars, and 4 on the back crossbar (about $60 in galvanized hardware)
Option 2 - small clamps attached to the 1/2" bars of the basket. I would still use bolts and lock nuts and could easily use about 30-40 (about $45).
Am I way over thinking this? The cost difference is insignificant, so it comes down to safety. The last thing I want is a sheet of plywood popping off the roof while driving.
If you've done this before, what did you use? Is there a better, third option?
Sorry for the crude photos, but hopefully you get what I am trying to do. Thanks in advance for your help.
Vince _________________ 1988 Vanagon Wolfsburg Tin-Top - "Elmo" |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Wed Sep 08, 2021 9:34 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
I know you said you overbuild things, but consider that the plywood isn't really supporting the load - the basket itself is. The wood is only stopping things from falling through the cracks per se.
Therefore, 1/2", or even thinner, will do the job.
Are you leaving the plywood up there more or less permanently?
If not, I'd go with door skin (or <1/2") and zip tie it in, as the load on top being lashed will hold everything in the basket, including the wood floor.
Then when finished with your trip, cut the zip ties, and easily move the thin wood to your shed, basement or garage.
Elsewise, I'd be using 6 of those clamps, 3 on the front and 3 on the rear. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
VJP5 Samba Member
Posted: Wed Sep 08, 2021 9:50 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
When we're camping, which is maybe once a month, you are correct in that the load will help keep it in place. But its primary use will be as a roof deck, which will be left on permanently. One of the benefits of living in SoCal is there are plenty of places to drive around to catch a good sunset. My wife and I will eat dinner 'on the deck' as the sun goes down. No worries about fighting for space or trying to get an unobstructed view. it is just a great place to relax
It also works as a great place to spot where the waves are breaking for surfing. I'll even get up there to watch others surf if I'm too tired.
So my primary concern is driving with no load bearing weight on it. _________________ 1988 Vanagon Wolfsburg Tin-Top - "Elmo" |
panel Samba Member
Joined: December 02, 2001 Posts: 1090 Location: Victoria B.C. Canada
Posted: Wed Sep 08, 2021 9:56 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
If you went with the 2nd option using the conduit clamps you could always line them with rubber to protect your new rack. _________________ My '65-Subaru EJ20 Turbo conversion |
VJP5 Samba Member
Posted: Wed Sep 08, 2021 10:00 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
Agreed, I would absolutely use rubber to protect the bars.
My main concern is safety, as this is my daily driver and 90% of the time there will be no weight on the decking. _________________ 1988 Vanagon Wolfsburg Tin-Top - "Elmo" |
pnwkayaker Samba Member
Joined: April 01, 2008 Posts: 919 Location: Sammamish, WA
Posted: Wed Sep 08, 2021 10:18 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
I think both would work fine, but personally, I'd go with u-clamps:
- easier to install and remove, they can drop from the top instead of pushing from the bottom (gravity is a great helper)
- they can distribute the load at a pass-through hole more easily (you'd need to add multiple washers and such using the other method to distribute the load at a hole)
- less number of u-clamps (14 u-clamps vs 30-40 small clamps is not overbuilt in my book) _________________ 87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link) |
Crooked Designer Samba Member
Joined: March 22, 2018 Posts: 323 Location: Chicago, IL
Posted: Wed Sep 08, 2021 10:39 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
I have my solar panels held on to the roof rack with 6 u bolts. (like your Option 1) I also put 1/8" pieces of rubber between the panel box and the rack bars. I've had it up there for 3 years now and it's incredibly solid.
However, using that method for what you're going to be using as flooring, I would probably think about how to attach it without bolts coming up through that flooring to avoid giving yourself something to trip on. If I were you, i would probably consider something like the electrical conduit solution, but attach to the basket before you put the basket up top. This would allow you to put some flush mount bolts down through the floor and bolt them on from the bottom. _________________ '85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Wed Sep 08, 2021 11:00 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
I'd treat the wood well (staining?) and leave it permanently. It will create an airflow and help cooling down the van... similar to the Land Rover roof... |
VJP5 Samba Member
Posted: Wed Sep 08, 2021 11:54 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
pnwkayaker wrote: |
My gut was saying option #1, but I'm old enough to not be embarrassed to ask others for advice.
Crooked Designer wrote: |
However, using that method for what you're going to be using as flooring, I would probably think about how to attach it without bolts coming up through that flooring to avoid giving yourself something to trip on. |
I'm happy to hear of your success. Another vote for U-Clamps. I thought about the tripping factor and that's what led to Option #2. However, I don't envision a ton of walking up there. Pretty much climb up and sit. If it's too high, I may score the top to recess it some more. I'll have to see how it looks once it's done.
0to60in6min wrote: |
Exactly the plan. 2 coats of oil based paint. Black on the bottom and sides, white on the top side. Knowing my wife, we'll likely add outdoor carpet or synthetic grass to it before it's done. _________________ 1988 Vanagon Wolfsburg Tin-Top - "Elmo" |
DuncanS Samba Member
Posted: Wed Sep 08, 2021 7:30 pm Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
9 mm Okume plywood fastened down with 3M 5200 and nothing else. Once cured if you try to lift the ply with a crane, the whole van will come off the ground. No fastenings at all. |
calo1956 Samba Member
Joined: April 18, 2011 Posts: 700 Location: long Island new york
Posted: Wed Sep 08, 2021 7:47 pm Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
Awesome van and roof rack setup! Have fun camping with it. Aside from the attachment method, I would question why use plywood, personally I would go with a solid wood. _________________ Enjoy the ride....
72 bug
80 westfalia |
Posted: Wed Sep 08, 2021 8:58 pm Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
And while you're at it, weld some proper sized tubing onto the basket so you can sport an umbrella up there for sun protection and coolth.
Skip all the wild paint work and graphics and just have a couple of chairs and the umbrella. Although this does have some qualities.
Just noticed the difference in the way the rear fender wells and the firewall are designed for the splitters and the T3. Wish ours were like the splitters so we would have more interior storage capability. |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Thu Sep 09, 2021 1:26 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
Having had plenty of expereince with plywood on the roof rack:
1.) Do not permanently mount it. It is wood and will deteriate/rot over time and require replacing.
2.) Use the "U" shaped brackets. Those longer brackets will distort the framework by pulling the metal tubing out of shspe.
3.) Before mounting get all your holes drilled for the u-shaped brackets and then use Thompsons Water sealer on the plywood making sure it gets into every hole to soak into the raw wood exposed by the drilled hole.
4.) Use stainless steel stove bolts and nyloc nuts with washers coming down through the top so the bolts do not stick up into the cargo area.
5.) Do not paint it. I used the best quality Behr exterior paint on my first sheet of plywood thinking it would last for years. Did all the proper prep work to paint it and it only lasted 6 months before starting to peel off in strips. It looked like palm leaves blowing in the wind going down the road. Since then I have only used Thompson Water Sealer and the lastest sheet has been on the roof rack since 2016. Reseal it every year.
6.) You only need 1/4" thick marine ply. The framework under it is going to distribute the loaded weight. Weight is your killer and the thinner you can go is best. Even think about 1/8" sheet of aluminum if it is less weight.
7.) The temperature difference between the bare roof and the shafe underneath the plywood is going to be about 15-20° cooler in the shade.
Nicely painted waste of time and money to remove it 6 months later. Slots cut inyo along the edges are hand holds for when climbing up there and also double as places to use ratchet straps for cargo.
Road grime will blacken it. _________________ This free advice is worth exactly what you paid for it.
Posted: Thu Sep 09, 2021 1:30 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
DuncanS wrote: |
Skip all the wild paint work and graphics and just have a couple of chairs and the umbrella. Although this does have some qualities. |
Not a bad idea really. I would go for a surplus parachute to cover the entire Vanagon for shade. I would shorten the pole to just stick up high enough to give access to the cargo in the rack when camping.
You would save the weight of mounting an awning off the side and get full 360° shade that you could fold over to only have the area you want shaded. _________________ This free advice is worth exactly what you paid for it.
Posted: Thu Sep 09, 2021 5:36 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
Steve--Not a fight here, but a few defensive thoughts on my ply post.
1. Okume ply is marine and will not degrade for the life of the van
2,3,4 NA
5. Use only marine oil paint with a primer first. Interlux Bilge Coat is really tough and will stand up to traffic. I recommend it for porches. And recoat as needed. Paint the underside too. But after the ply is on. Take the rack off and paint then.
6. I agree on thickness. The 9mm has extra cores so more better for the abuse and very little extra weight.
7. You are dead on. Absolutely. White is the only way to go. Any scuffs or stains are above eye level and can be repainted when they become objectionable.
The ply can be removed, but only by destruction if no longer needed or a different idea.
Duncan |
syncro surf Samba Member
Posted: Thu Sep 09, 2021 6:52 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
Duncan - as a boat guy I expected you to recommend Starboard/Seaboard HDPE type material. Fit it and forget it. Too expensive? I haven't used it for anything but it seems like a good application for it. |
VJP5 Samba Member
Posted: Thu Sep 09, 2021 7:18 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
Steve M. wrote: |
When you say use the U shaped brackets, just to be clear, you are saying Option #2, correct? In this scenario, the flooring is only attached to the 1/2" bars of the roof basket (NOT the (4) 1.5" roof crossbars). If so, you believe those will be just as strong, if I put enough on?
1/4" or 1/2" is really strong enough? I am not worried about dynamic weight issues. At most, when moving, I'll have an extra tent, tarps, and maybe a gas can. _________________ 1988 Vanagon Wolfsburg Tin-Top - "Elmo"
VJP5 Samba Member
Posted: Thu Sep 09, 2021 7:23 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
calo1956 wrote: |
Awesome van and roof rack setup! Have fun camping with it. Aside from the attachment method, I would question why use plywood, personally I would go with a solid wood. |
Thanks. My use of plywood is mostly because I want to have a solid surface area. I prefer to not have individual planks. I thought about using Trex, but again, a solid surface is preferable to me. _________________ 1988 Vanagon Wolfsburg Tin-Top - "Elmo" |
pemz0r Samba Member
Joined: August 26, 2010 Posts: 126 Location: Huntington Beach
Posted: Thu Sep 09, 2021 7:42 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
I would use a bunch of rubber hose clamps. I don't like the sight of "U" bolts.
This is how I mounted my solar panel. The best part, is that the rubber gets sandwiched between the the metal bar and the solar panel for some sort of anti vibration.
https://www.amazon.com/LOKMAN-Stainless-Cushioned-...4&th=1
Posted: Thu Sep 09, 2021 8:09 am Post subject: Re: Help with attaching plywood deck to Yakima Roof Basket |
VJP5 wrote: |
Steve M. wrote: |
1/4" or 1/2" is really strong enough? I am not worried about dynamic weight issues. At most, when moving, I'll have an extra tent, tarps, and maybe a gas can. |
Yes, option #2 the smaller bracket just to the bars of the basket. If you attach the basket to the crossbars well enough then it will easily be strong enough.
Whatever you put in the cargo rack is going to held down by gravity for the most part, but the basket needs be secure to the crossbars.
The biggest danger of a roof rack is a head on collision and if the cargo is not secure it's going to continue going straight ahead at 60mph+ ( think of those cars you see carrying a mattress home using a single piece of string to keep it on the roof!)
A 1/4" should easily be strong enough becsuse the frsme under the plywood is the load bearing surface. The plywood just distributes the weight out better.
Yoy may want to cut holes or slots in the center of the wood so you can hook a ratchet strap hook around tubing of the rack to give you a spot to lash down to for individual heavy items. _________________ This free advice is worth exactly what you paid for it.
