djdh68dlux Samba Member
Joined: February 24, 2005 Posts: 770 Location: I.E., SoCal
Posted: Thu Sep 09, 2021 9:46 am Post subject: Right rear brake shoes lock up after one pump of the brakes |
Hey all, having an issue on my 1968 bus. I was driving home a couple of weeks ago and I could feel some brake drag. No problem, figured I just needed to adjust the shoes as I had recenlty put new ones on. It got worse and worse as I drove home. By the time I got home, it was dragging so badly that it was like driving with the E-brake on. Passenger side rear wheel was hot and smoking. Let it sit for a few days until I had time to look into it. Got the drum off, decided to replace the Brazilian wheel cylinders with FTE German ones, readjust the shoes, bleed and be done. Problem is that after one pump of the pedal, the same passenger side rear wheel brake shoes go all the way to the drum and do not release, like the brake fluid pressure can't travel back through the line and into the reservoir. Now, I did a search here on the forums and the consensus seemed to be that the brake hose on that wheel must have gone bad on the inside and may be acting as a check valve, not allowing the fluid to travel back through the line. No problem, cheap fix, replace the hose, right? Only that didn't fix the problem! So search some more, and read up on adjusting the Master Cylinder push rod. Seems simple enough. I remove the pedal cover/skid plate, check the push rod and from what I can tell, it doesn't seem horribly out of adjustment. Bentley calls for 1mm of play between the rod and master cylinder piston. While it seems like it might be slightly more than 1mm, I'm pretty positive that it's no way more than 2mm at the most. The way I understand it, the piston needs to come all the way back to not block the compensating port so the fluid can return to the reservoir, correct? Wouldn't the push rod have to be adjusted too long for that to happen? How could that happen if I am a half a mmm to 1 mm shorter than recommended? My next thing to try was going to be to back off the push rod and then readjust it to the 1 mm spec. If that doesn't work, what's next? Remove the Master, clean, reinstall? Master isn't super old, but not new anymore either (5-7 years old). I'm super stumped, so I appreciate all suggestions/ideas at this point. I've never had this problem in the 25+ years I've owned this bus. _________________ 1968 Deluxe "Clipper L" Type 2
Looking for a VW club in Southern California? Check out Inland Valley Volkswagens: www.ivvw.org |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Thu Sep 09, 2021 9:56 am Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
Hopefully others will have other ideas too, but I think the idea that maybe something is wonky in the master cylinder makes sense. Perhaps some crud got in there and found it's way into the port for the rear brakes or something to that effect.
OR
Perhaps a bit of crud found it's way into the brake line when you replaced the cylinder, and has finally made it's way to some point in the lines between the front and back that it is acting as a check valve.
So maybe you could unhook the line from the back of the wheel cylinder and just run a bunch of fluid through the lines and see if you get anything out? _________________ Dave Cook
1973 Wild Westerner
My Thing |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Sep 09, 2021 10:20 am Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
If it was the master cylinder more than just one brake would be acting up, I'm going with the crud in a line (maybe even one of the hard lines) playing check valve as well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Sep 09, 2021 12:19 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
vwwestyman wrote: |
So maybe you could unhook the line from the back of the wheel cylinder and just run a bunch of fluid through the lines and see if you get anything out? |
This sounds like a good place to start.
busdaddy wrote: |
If it was the master cylinder more than just one brake would be acting up, I'm going with the crud in a line (maybe even one of the hard lines) playing check valve as well. |
This was my thinking as well. Since it's only the right rear, I'd assume it would have to be after the hard line splits into 2 at the rear, correct? I've already eliminated the rubber hose part of the equation, so my main suspect should be the hard line going from the hose to the wheel. Makes sense to me, but if you guys see any flaw in my logic, feel free to let me know. _________________ 1968 Deluxe "Clipper L" Type 2
SGKent Samba Member
Posted: Thu Sep 09, 2021 1:01 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
Check the shoe return springs. If that isn't it, remove the hose from the wheel cylinder and from the Tee, and blow air thru it. See if it is restricted.
A single master would affect all 4 brakes, a dual master would affect the front or rear. The problem is downstream of the rear tee. That means either a hose, line, or return spring. This assumes it worked right at one time and that it hasn't been assembled wrong.
ALSO make sure that the hand brake cable is not sticking. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Sep 09, 2021 2:14 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
SGKent wrote: |
ALSO make sure that the hand brake cable is not sticking. |
SGKent, this is where my thinking is heading. I've changed the hose, reinstalled the return springs/shoes/e brake lever so I'm pretty sure the assembly is good to go. It was all working properly before this happened on my last drive. I'm starting to think that maybe the e-brake cable is sticking a bit. To get the drum on I have the shoes adjusted as far in as they can go and can still feel/hear them slightly touching the drum if I spin the wheel. I'm still at work at the moment, but might have a couple hours to fiddle with it later. Gonna inspect the e-brake cable and I will update this post. Thanks all for the suggestions so far. _________________ 1968 Deluxe "Clipper L" Type 2
Posted: Thu Sep 09, 2021 4:36 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
What happens when you open that bleeder on that wheel after you have pumped the brakes up? Do you get a slight squirt? Can you hear the brakes returning? What happens when you open the bleeder on the opposite side of the car? |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Thu Sep 09, 2021 5:21 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
Are your star adjuster locks in place? Could it be that your shoes are getting tight from movement of the star adjusters? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri Sep 10, 2021 12:19 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
Wildthings wrote: |
When I open the bleeder on the locked up wheel, yes, get a nice squirt of fluid and the brakes release from the drum. Haven't tried the bleeder on the opposite side.
aeromech wrote: |
Are your star adjuster locks in place? Could it be that your shoes are getting tight from movement of the star adjusters? |
Yeah, star adjuster locks are in place. I didn't get a chance to look at yesterday, but gonna inspect the e-brake cable a bit more closely. The shoes seem to be pushed out a bit even with the adjusters as far in as they can be. Should have some time this weekend to dig into it again. _________________ 1968 Deluxe "Clipper L" Type 2
Posted: Fri Sep 10, 2021 12:25 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
Pull the drum and take some pictures _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent Samba Member
Posted: Fri Sep 10, 2021 12:43 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
the line or hose, wheel cylinder where the line comes out is plugged up. The squirt and retraction is proof of that. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Posted: Fri Sep 10, 2021 1:32 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
Thanks all for the suggestions. Gonna dig into it tomorrow morning before the temps crawl up to triple digits and I'll see what I can find and will update you all here. _________________ 1968 Deluxe "Clipper L" Type 2
SGKent Samba Member
Posted: Fri Sep 10, 2021 1:49 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
djdh68dlux wrote: |
Thanks all for the suggestions. Gonna dig into it tomorrow morning before the temps crawl up to triple digits and I'll see what I can find and will update you all here. |
see my edit. I typed 'main' but meant 'wheel cylinder where the main port is that goes to the line.' _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Starbucket Samba Member
Posted: Fri Sep 10, 2021 2:21 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
I would remove the rubber hose to that wheel as the symptoms are the same as an older hose with swollen inner rubber, fluid goes in but return springs are not strong e`nuff to return it, that said did you replace the brake springs? |
Posted: Fri Sep 10, 2021 2:26 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
Starbucket wrote: |
I already tried replacing the hose with a new one. Also, even though I didn't mention here, I replaced the return spring. _________________ 1968 Deluxe "Clipper L" Type 2
SGKent Samba Member
Posted: Fri Sep 10, 2021 2:38 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
djdh68dlux wrote: |
Starbucket wrote: |
I already tried replacing the hose with a new one. Also, even though I didn't mention here, I replaced the return spring. |
so another test would be to bleed the brakes, then expand the one so it binds on the drum. Loosen the line at the tee and see if it squirts and the drums collapse. If not loosen the next fitting and see if it squirts and the drum collapses. When you get to the spots between no collapse and collapse there is your restriction. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Sep 10, 2021 3:06 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
How did you adjust the brakes when you rebuilt them, adjust one shoe 4 clks then the other shoe 4 clks until you got contact? if not you may have shoved one piston off center blocking the inlet. |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Fri Sep 10, 2021 3:18 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
I did drum brakes for the first time ever this summer. It was harder than I thought. I adjusted them with the wheels off and checked as I adjusted by pulling the drum on and off and checking progress. It took me awhile to get it right. Then pulling the unadjusted parking brake lever caused something to rub and make noise. It went away after I adjusted the slack out of the e brake cables. |
Posted: Fri Sep 10, 2021 3:46 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
orwell84 wrote: |
You might want to loosen the ebrake cable. |
Posted: Fri Sep 10, 2021 5:10 pm Post subject: Re: Right rear brake shoes lock up after one pump of the brakes |
Starbucket wrote: |
orwell84 wrote: |
I entertained a sticky brake cable earlier on, but the squirt of fluid when opening the bleeder, and resulting brake release points more towards a one way restriction in a hard line right now. Although it also sounds like a read through the Bentley about brake adjustment (including the E brake) may be in order after dismantling the hard lines and flushing/blowing everything out. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
