boundstaffpress Samba Member
Joined: June 18, 2013 Posts: 161 Location: Southeast Colorado
Posted: Thu Sep 09, 2021 10:30 am Post subject: Considering dual carbs for a 73 Super. Opinions/Suggesti |
I have a stock 1600 with DVDA and 34 Pict3 in my 73 Super. I have rebuilt my carb and purchased an NOS vacuum pod for my cleaned and serviced distributor. I still get unreliable idle, sometimes racing, sometimes dying.
I am ready for reliability.
What dual carb suggestions would you make with an eye towards reliability and economy instead of raw horsepower? _________________ Justin
Building a 73 Super Beetle with my kids. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
vernonc Samba Member
Joined: April 23, 2012 Posts: 681 Location: Parkersburg, WV..yes, I sold the boat
Posted: Thu Sep 09, 2021 1:40 pm Post subject: Re: Considering dual carbs for a 73 Super. Opinions/Suggesti |
I know that you said you rebuilt your carb but that still could be your problem.....it was for me. I then had Tim at volkblitx (spelling ?) do my carb and everything has been great. I believe that, since you're looking for reliable performance, you'll be more happy with a 'good, stock, all German designed' setup.
Good luck and I hope this help.
ol' mort _________________ "Those who don't read newspapers are un-informed. Those who do read newspapers are mis-informed." Will Rogers
'69 sedan, low mileage, all original.....currently being 'freshened-up' for road trips and daily driving...just not every day
Freshening-up link http://www.thesamba.com/vw/forum/viewtopic.php?t=617386 |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4408 Location: Stuck in Ohio
Igpoe Samba Member
Joined: February 24, 2019 Posts: 853 Location: South Boston, VA
Posted: Fri Sep 10, 2021 3:38 am Post subject: Re: Considering dual carbs for a 73 Super. Opinions/Suggesti |
I agree with Bugee that you should get the car to idle and run smoothly first. Simply adding dual carbs might multiply your problems. It's possible you dvda still isn't advancing smoothly and returning to 7.5btdc accurately. The duals are a great idea for easier drivability and increased mileage. The accelerator pump volume on them must be correct for ease of starting in cold weather. I use the Empi 34 kit, works nice for me! _________________ '73 super. |
Posted: Fri Sep 10, 2021 2:59 pm Post subject: Re: Considering dual carbs for a 73 Super. Opinions/Suggesti |
Yes. I have considered the possibility that something else is wrong with the engine, and I understand dual carbs could complicate finding the problem. Like the subject says, I'm considering my options.
The thing that makes me think the engine isn't the issue is that the symptoms are not consistent. Were it a compression issue, I would think that the symptoms would not change or go away. I have considered that a rebuild kit and the machining would have a similar cost as a Weber IDF kit.
Thank you for your ideas and concerns. This is what I was looking for, though I thought maybe more people would chime in. _________________ Justin
johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 572 Location: South of Raleigh
Posted: Fri Sep 10, 2021 3:05 pm Post subject: Re: Considering dual carbs for a 73 Super. Opinions/Suggesti |
The question is how much of a deep dive have you done to actually diagnos what's going on? i.e. timing light to see what the advance is actually doing, checking for vacuum leaks with carb cleaner spray, compression check, etc etc.
Have you checked that the idle shut off solenoid if functioning properly?
I'll echo what others have said, dual carbs are an added level of complexity, even if you're 1000% sure the carb is the problem |
Igpoe Samba Member
Posted: Sat Sep 11, 2021 3:13 am Post subject: Re: Considering dual carbs for a 73 Super. Opinions/Suggesti |
If you should choose to go with the dual carbs I personally think 40idf might get a bit too complicated for your 1600. You must consider how to obtain the proper vacuum for your distributor. You'd likely have to drill and tap a manifold to get enough. Then you may have to balance the manifolds by doing the same to the other. Or you would ditch the dvda for a 009. _________________ '73 super. |
