janoostland Samba Member
Joined: August 15, 2019 Posts: 19 Location: Goshen, IN
Posted: Fri Sep 10, 2021 7:51 pm Post subject: Is this a chopped top or original convertible? |
I found this 1969 Ghia online, wondering it it is an original convertible or a chopped roof. Can someone confirm what I'm looking at? It seems very rough above the windshield.
Thanks for your help!
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Fri Sep 10, 2021 8:55 pm Post subject: Re: Is this a chopped top or original convertible? |
Looks like a hack job to me. Looks nothing like my original convertible. You have any other pics of the rear area and the convertible hinges?
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Marcdeb Samba Member
Posted: Sat Sep 11, 2021 4:47 am Post subject: Re: Is this a chopped top or original convertible? |
If you have access to the car or can ask the seller for information, try to find out the width of the back seat. A coupe back seat is approximately 42 inches wide. The convertible back seat is approximately 36 inches wide. You can measure the back seat itself or the opening that supports it.
I think this looks like the top of a windshield from a coupe where the top has been cut off??
Over the entire production run of the Karmann Ghia, there was 2 very different designs of the top of the windshield frame and this one does not resemble either one. There's definitely something going on with this car. Here's a thread about a coupe that was chopped into a convertible and there's lots of helpful information on this subject.
https://www.thesamba.com/vw/forum/viewtopic.php?t=668495&highlight= _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1678 Location: Raleigh, NC
Posted: Sat Sep 11, 2021 6:03 am Post subject: Re: Is this a chopped top or original convertible? |
That is 100% a chopped coupe _________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2507 Location: Santa Cruz, CA
Posted: Sat Sep 11, 2021 12:09 pm Post subject: Re: Is this a chopped top or original convertible? |
From the looks of that windshield frame, I'd say that car started life as a coupe.
The rear seat area will have certain features that are unique to convertibles too. This photo from the gallery shows the panel just below the rear edge of the interior opening with mounting points for the rear window hinges ↓
Here you can see one of the plastic tubes that drain water away from the rear window. These tubes exit thru holes in the bottom of the quarter panels, just behind the rear wheels. These tubes and the holes are only found in convertibles ↓
The small 'L'-shaped bracket in the upper-left of this photo is also unique to the later convertibles. It anchors the ends of the cable that holds down the rear edge of the convertible top. And the structure just below that is one of the mounting points for the top frame ↓
This photo shows the 'U'-shaped channel around the rear opening for the cable that fastens the rear edge of the top ↓
_________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
Posted: Sat Sep 11, 2021 12:29 pm Post subject: Re: Is this a chopped top or original convertible? |
Thanks everyone for the detailed feedback. The owner claimed this was an original convertible and these explanations definitely confirmed it was not. None of the pieces you mentioned is shown in this car. See Pictures.
You saved me from buying the wrong body!!
Thanks!
Braukuche Samba Member
Posted: Sat Sep 11, 2021 12:54 pm Post subject: Re: Is this a chopped top or original convertible? |
janoostland wrote: |
Thanks!
The lies some people will tell to make a dirty dollar.
At least some people are more honest and try to sell a hacked and ruined coupe as a “roadster.” _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Sat Sep 11, 2021 3:19 pm Post subject: Re: Is this a chopped top or original convertible? |
Wow, those pictures are unreal! What a back job. Good that you were suspicious and asked some questions. This car is going to be someone's nightmare. _________________ Marc
Previously Owned:
2001 Saab 9-3 Conv
1997 Saab 900 Conv
1997 Mazda Miata
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sun Sep 12, 2021 8:56 am Post subject: Re: Is this a chopped top or original convertible? |
Ask that idiot to describe how it "converts" back to a covered car. It's original only in its manner of devaluing execution. Many a dumba** thinks roadster and convertible are interchangeable terms, too. We've got one of those hack jobs floating from unsuspecting owner to owner around Boise- many lies told over the decades... _________________
EverettB wrote: |
FU#5 |
