catadromous Samba Member
Joined: September 11, 2021 Posts: 6 Location: Pagosa Springs, CO
Posted: Sat Sep 11, 2021 7:43 pm Post subject: Topside Wear on #1 Exhaust Rocker Arm |
Hi all,
Just got my first bus and finding my way around. It's a 68 Westfalia in great overall condition. Single port 1600cc (I think anyhow, has an AB Engine # and there was a rebuild in 1982 after #3 burned valve... not too many miles on it since then, maybe 20,000? Most recent owner just replaced cylinders and pistons).
I found some strange wear on the topside of the actual body of the #1 Exhaust Rocker Arm, like it was rubbing on something. Someone shimmed the end there with two fat washers, everywhere else has the stock washers and wavy/spring washers. There's not any wear on the Exhaust valve spring or on the nearby bolt or anywhere that I can see. I also remember that I couldn't really get the feeler gauge in there while I was adjusting the valves, I ended up backing the adjustment screw all the way into the rocker arm. I guess that means the valve is sitting too high for some reason?
Any ideas? Thank you in advance.
Brandon
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Sat Sep 11, 2021 8:24 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
it looks like that rocker spent some time rubbing on a head stud that was sticking up too far. or was clearanced to avoid that situation. i'd be just as concerned with that adjuster screw. why does that spring retainer look different from the rest? gonna need some pics of that valve stem end and adjuster screw face.
you have a problem with that valve and/or it's seat.
don't run it in this state. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
busdaddy Samba Member
Posted: Sat Sep 11, 2021 9:23 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
That's grinder work on the arm and washers, can't figure out why though, access to retorque heads without removing the rocker maybe?, savage!
Mighty clean in there, like it's somewhat fresh, but why is that valve up like that?, some deeper investigation now might save a catastrophic even later. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sat Sep 11, 2021 10:40 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
You need a new engine. Where do you live? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Sun Sep 12, 2021 1:40 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
Okay, photo time. Thanks for your help everyone : )
borninabus wrote: |
All the adjuster screws are pretty worn, but #1 Exhaust has pitting also.
These are the valve stem ends, they look pretty good to me? I think it is the same spring retainer, just different lighting.
Interestingly, I did peak up at the studs behind the head and noticed some scoring on the lower rightmost stud closest to the valve in question, almost like it was spinning and wore on the outside of the cylinder.
Here are the rocker assemblies. Passenger's side:
Driver's side (those rocker arms are kinda stuck, don't want to slide off):
busdaddy wrote: |
Yeah, my buddy remarked, "That's a real custom job."
aeromech wrote: |
You need a new engine. Where do you live? |
Lol, please don't say that. In southwest Colorado. I was hoping I could make this engine work. But yeah, I figured that might be the case when I bought it.
Compression is good in all cylinders (120, 120, 115ish, 120). The last owner was having trouble with compression which was why he put in the new piston and cylinder kit. But when I got it, the distributor cap was on backwards, spark plugs were barely torqued, lots of loose electrical connections. Vacuum advance wasn't hooked up. Thermostat is long gone (it had the crazy Bowden cable with a spring on the end) but from what I can tell the cooling flaps aren't even wired open, just free flapping... it just makes me wonder if I'm going to keep discovering new things that need to be fixed. But it wasn't run very much since then either... so maybe nothing is too screwed up.
The rest of the vehicle is beautiful, sat in a garage for many years apparently. So yeah, just trying to figure out whether I should sink a lot of time and money into this engine or just start with a clean slate. I haven't done a lot of work on engines but I'm learning a lot and I enjoy it, it makes sense.
The bus. She's a beaut.
Anyway, thanks all,
Brandon |
SGKent Samba Member
Posted: Sun Sep 12, 2021 1:57 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
or someone removed the stud and replaced it with Vise grips. That stud may have pulled and the case & stud were not repaired properly. Those appear to be the older style studs. The case and heads may have been cut too. I would be concerned that someone just tossed that engine together however they could to get it going. There is a lot of that which goes around with flippers selling buses. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Sep 12, 2021 2:16 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
You need a new engine, sorry. But you do. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
airschooled Air-Schooled
Posted: Sun Sep 12, 2021 2:34 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
aeromech wrote: |
You need a new engine, sorry. But you do. |
Are you selling engines now Gary? _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Danwvw Samba Member
Posted: Sun Sep 12, 2021 2:42 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
I am going with the previous owner or mechanic ground the rocker down before realizing the stud was backed out But then tightened the stud.
Maybe just get some solid rocker shafts for it. "Scat" are nice. And or maybe better yet get some good swivel adjusters too. PS Because that one adjuster is all the way out you will probably need at least .060 or .080 shims under the rocker arms plus grind the arms back so the swivel adjusters will fit.
One more thing. Sometimes a exhaust valve seat starts to pound into the cylinder head and the valve will keep needing adjusted further out to maintain the clearance needed. Better just bolt it together and adjust the valves first and drive it another 1500-3000 miles to see if the adjustment is holding, If not get the head rebuilt then install the Solid Rocker Shafts and swivel adjusters. Swivel adjusters prolong the life of valve guides. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
SGKent Samba Member
Posted: Sun Sep 12, 2021 2:52 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
Danwvw wrote: |
One more thing. Sometimes a exhaust valve seat starts to pound into the cylinder head and the valve will keep needing adjusted further out to maintain the clearance needed. Better just bolt it together and adjust the valves first and drive it another 1500-3000 miles to see if the adjustment is holding, If not get the head rebuilt. |
great guess as to what happened. Made me think of the TV Series from the 50's - "You Are There." _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Posted: Sun Sep 12, 2021 2:59 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
Those look like original rockers, and the head studs seem to be poking out a lot…
Do the head studs torque up to 18 foot pounds?
The arm and wave washer look to have been “machined” the same amount, so either a human or an architectural issue did this. Question is, did it happen on the current build, or the last one?
How does it drive? Does it make odd noises? _________________ Learn how your vintage VW works. And why it doesn't!
SGKent Samba Member
Posted: Sun Sep 12, 2021 3:01 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
airschooled wrote: |
How does it drive? Does it make odd noises? |
just plllummmm berip berip plummmmb berip occasionally. What causes that? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Sep 12, 2021 3:07 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
I’m in the market which says you need a new engine. Sure, I guess someone could come along and install the rocker arm geometry correctly but what about the head studs pulling. You’re going to throw bandaids on a tramma wound hoping that the blessing stops long enough to reach the hospital. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent Samba Member
Posted: Sun Sep 12, 2021 3:15 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
what Gary is saying is that if you are going to enjoy a VW bus you don't want to be worrying about breaking down 350 miles from home. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Danwvw Samba Member
Posted: Sun Sep 12, 2021 3:18 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
Yes torque the other head bolts that you can reach under the valve cover before putting it back together. If they torque ok all will be good. What 25 foot lbs? _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Sun Sep 12, 2021 3:22 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
What Gary is saying is you have a 1982 rebuild. Then a recent piston cylinder swap and really poor workmanship including rocker arm geometry.
Best to find a quality long block rebuilder and start down the right tract with you new bus so you can just enjoy it _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Danwvw Samba Member
Posted: Sun Sep 12, 2021 4:07 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
There is one other possibility.
The rocker could be shifting off the valve to one side!
Posted: Wed Sep 15, 2021 4:09 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
All the studs were torqued properly... they are 10mm, I tightened them to 23 ft*lbs as I found in the Bentley manual, though they didn't need much. It drives great, though it lacked some power on the uphill probably from not being timed correctly, bad gas, no vacuum advance, and some other stuff. I've fixed all that, need to get insurance, registration etc., and get it up to highway speed and see.
SGKent wrote: |
or someone removed the stud and replaced it with Vise grips. That stud may have pulled and the case & stud were not repaired properly. Those appear to be the older style studs. The case and heads may have been cut too. I would be concerned that someone just tossed that engine together however they could to get it going. There is a lot of that which goes around with flippers selling buses. |
Ah yes, that seems likely. The studs seem pretty long although I have no basis for comparison. Maybe whoever rebuilt the engine mixed them up. I'm concerned for sure, just not sure what to do about it. I could take the engine apart, but would I even know a problem if I saw it? Still learning a lot. Or I can try and fix problems as they arise.
Danwvw wrote: |
One more thing. Sometimes a exhaust valve seat starts to pound into the cylinder head and the valve will keep needing adjusted further out to maintain the clearance needed. Better just bolt it together and adjust the valves first and drive it another 1500-3000 miles to see if the adjustment is holding, If not get the head rebuilt then install the Solid Rocker Shafts and swivel adjusters. Swivel adjusters prolong the life of valve guides. |
There are already shims in there, on both sides. I ordered a new rocker arm, and in the meantime I ground the existing arm enough to so I can adjust the valves, drive it gently and see how it goes. I have a solid rocker shaft already but it won't fit right now because the studs contact the spacer on it. If things feel good I can figure out the stud problem later when I drop the engine.
So I guess, what's the takeaway? Either the valve or the pushrod is too high, that's why I'm out of room?
aeromech wrote: |
I’m in the market which says you need a new engine. Sure, I guess someone could come along and install the rocker arm geometry correctly but what about the head studs pulling. You’re going to throw bandaids on a tramma wound hoping that the blessing stops long enough to reach the hospital. |
aeromech wrote: |
Best to find a quality long block rebuilder and start down the right tract with you new bus so you can just enjoy it |
Lol. You're probably right, but since I have more time than money at the moment, I'll nurse this one along. If it dies, I'll be in the market for a new engine. Also I'll get a AAA membership : )
I spoke with the last owner again, he drove it much less than I thought, it's only been driven around 5,000 miles since the rebuild, and I've no reason to distrust either him or the owner before that. So the mechanic who did the rebuild maybe didn't do such a good job, and I should be aware that the last owner put it back together in a hurry.
Thanks all for the advice everyone. Hoping to be on here quite a bit. |
Posted: Wed Sep 15, 2021 5:06 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
Hot damn, you’re in Pagosa Springs which is super close to Durango. We have a Type 1 expert living in Durango who has the hook up with a great mechanic there. Contact Rich Parker. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Wed Sep 15, 2021 10:28 pm Post subject: Re: Topside Wear on #1 Exhaust Rocker Arm |
catadromous wrote: |
DON'T force them off! If you do, you will gouge the inside surface of the rocker arm bearing area. Push them towards the shaft center, then take an oil stone and remove the burr around the rocker shaft mounting holes. The burr is from pounding the rocker shaft assemblies onto the studs. When properly deburred, solvent washed, and oiled, the rockers should slide easily off the shafts. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
