58Olstor Samba Member
Joined: December 28, 2014 Posts: 57 Location: Brøsetvegen 167, 7050 Trondheim, Norway
Posted: Sun Sep 12, 2021 4:09 am Post subject: Can I use VW T1 bug rims on my T2 1961 bus? |
Hi
My bus has T1 rims. They fit but the axle width will become approx. 2 * 20mm = 40mm wider. I that OK?
The rims are 15" X 4.5"
Torstein Olsen
NUTSFORBUSES Samba Member
Joined: December 08, 2016 Posts: 560 Location: I don't recognize it anymore
Posted: Sun Sep 12, 2021 1:38 pm Post subject: Re: Can I use VW T1 bug rims on my T2 1961 bus? |
To me, they look like Bus wheels. The off-set is far outside, meaning deep inside. I have "modified" bug wheels on my Bus (the off-set was pushed outward on 5.5 " x 15 " bug wheels) Find the manufacturer name on those wheels if they are VW, and maybe take a picture of the mounted wheels _________________ kaiser kills kids.com |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Posted: Mon Sep 13, 2021 11:29 am Post subject: Re: Can I use VW T1 bug rims on my T2 1961 bus? |
vwuberalles wrote: |
Those aren't Beetle wheels. They look like Porsche 356 style, not sure if they're original Porsche or if they're reproductions. I think most stock bug wheels are narrower than bus wheels. |
They are called MANGLE WHEELS
He posted those after the first images-I have no idea where he is now or what is mounted currently _________________ kaiser kills kids.com |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Mon Sep 13, 2021 7:53 pm Post subject: Re: Can I use VW T1 bug rims on my T2 1961 bus? |
NUTSFORBUSES wrote: |
He posted those after the first images-I have no idea where he is now or what is mounted currently |
Mangels wheels are available in 4.5 and 5.5, and yes, they will work on just about any stock bus. _________________ regards
Uli
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Wed Sep 15, 2021 6:14 pm Post subject: Re: Can I use VW T1 bug rims on my T2 1961 bus? |
The first two photos are regular bus 15" rims. |
FarmerBill Samba Member
Joined: July 25, 2017 Posts: 767 Location: New England
Posted: Wed Sep 15, 2021 7:36 pm Post subject: Re: Can I use VW T1 bug rims on my T2 1961 bus? |
The original mangle. When you got your arm caught in it, it was "mangled". https://en.wikipedia.org/wiki/Mangle_(machine)
I had a set of 5.5 repop Mangel rims that did fit on my bus, but the tires were dangerously close to the lip of the rear fender. It may have had more to do with the tires than the rims though, I cant remember what size tire I was running. |
Posted: Wed Sep 15, 2021 8:32 pm Post subject: Re: Can I use VW T1 bug rims on my T2 1961 bus? |
Mangle or Mangel, I don't like the holes so I did this. Took 5.5" x 15 and moved them outboard, trued them and didn't need to shorten my beam after lowering. Did front and back same, then added disc's all around w 205x65 on rear.
A true RIM JOB easy e
easy e Samba Member
Posted: Thu Sep 16, 2021 10:04 am Post subject: Re: Can I use VW T1 bug rims on my T2 1961 bus? |
A true RIM JOB easy e |
I'm not a big fan of the later (small slot) 15" & 14" bus rims, but love the big slots of crow's feet rims.
Looks like your rim job lets them tuck under well enough:
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
Posted: Thu Sep 16, 2021 11:53 am Post subject: Re: Can I use VW T1 bug rims on my T2 1961 bus? |
easy e wrote: |
5.5" wide Modded wheels are big enough to allow CORRECT and wider tires. Originally the IRS (installed) was made to fit OG wheels (14") so the width was stock w the exception of an IRS set-up. I have about a thumb of clearance at the lip, inside is not an issue. The front has the same 5.5 X 15"Modded wheels and I used 185x55's vs the 205x65 rears Yoko Avid Ascend GT. I could use bigger in front easily, but I wanted a match and Yoko does not make them. The tires have about 1150 lb rating ea. The 4x disc brakes came after I installed about 180 HP 2332. the motor's low end came from Powerhaus and it's sporting genuine Italian 44's. The Koni's make it ride great. The sound is from Tiger at A1. _________________ kaiser kills kids.com |
Posted: Tue Sep 21, 2021 2:46 am Post subject: Re: Can I use VW T1 bug rims on my T2 1961 bus? |
To me, they look like Bus wheels. The off-set is far outside, meaning deep inside. I have "modified" bug wheels on my Bus (the off-set was pushed outward on 5.5 " x 15 " bug wheels) Find the manufacturer name on those wheels if they are VW, and maybe take a picture of the mounted wheels |
Hi
Thank you for your feedback. I'm sorry for the late reply.
It seems that there is no problem with a wider axle width.
There is no manufacturing name on my rims. I thought they where T1 rims, but they seemes to be reproduction, Mangels, bus or Porche rims.
Regards Torstein Olsen |
Posted: Tue Sep 21, 2021 2:48 am Post subject: Re: Can I use VW T1 bug rims on my T2 1961 bus? |
Hi
There is no manufacturing name on my rims. I thought they where T1 rims, but they seems to be reproduction, Mangels, bus or Porsche rims.
Posted: Tue Sep 21, 2021 2:51 am Post subject: Re: Can I use VW T1 bug rims on my T2 1961 bus? |
mandraks wrote: |
Mangels wheels are available in 4.5 and 5.5, and yes, they will work on just about any stock bus. |
Hi
Posted: Tue Sep 21, 2021 2:53 am Post subject: Re: Can I use VW T1 bug rims on my T2 1961 bus? |
easy e wrote: |
They are called MANGLE WHEELS |
A+ for your conviction (w/using all caps) |
Hi
Thank you for your feedback I'm sorry for the late reply.
Posted: Tue Sep 21, 2021 2:55 am Post subject: Re: Can I use VW T1 bug rims on my T2 1961 bus? |
FarmerBill wrote: |
Hi
It seems that there is no problem with a wider axle width, but I will measure the distance to the fender.
Posted: Tue Sep 21, 2021 2:58 am Post subject: Re: Can I use VW T1 bug rims on my T2 1961 bus? |
Hi
Quite impressing modifying you did
