shakers73 Samba Member
Joined: June 14, 2011 Posts: 820 Location: Saltville, Va
Posted: Sun Sep 12, 2021 10:01 am Post subject: 67 Shock Replacement |
I have a question. I removed the old shocks on the front of my 67 beetle. My question is, does the bushing on the bottom mount supposed to come off with the shock? I have posted photos of the old shock, the new shock, and the bottom mount. The bushing in the new shock does not fit over the mount in its current condition.
_________________ shakers73
'74 Super Beetle
'67 Beetle
Where there is no vision, the people perish. |
cew Samba Member
Joined: June 14, 2009 Posts: 18 Location: Brandon, MS
Posted: Sun Sep 12, 2021 10:11 am Post subject: Re: 67 Shock Replacement |
It looks like the old shock bushing is still (seized?) on the mount bolt. |
Posted: Sun Sep 12, 2021 10:15 am Post subject: Re: 67 Shock Replacement |
So, that is indeed a bushing and not part of the lower mount. If it is, it is definitely seized. Any suggestions on freeing it up? _________________ shakers73
'74 Super Beetle
'67 Beetle
gt1953 Samba Member
Posted: Sun Sep 12, 2021 10:21 am Post subject: Re: 67 Shock Replacement |
1 Soak it with yout favorite soaking fluid.
2 cut it with a dremel tool carefully
3 lots of four letter words like pull _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9759 Location: Oregon
Posted: Sun Sep 12, 2021 10:31 am Post subject: Re: 67 Shock Replacement |
shakers73 wrote: |
So, that is indeed a bushing and not part of the lower mount. If it is, it is definitely seized. Any suggestions on freeing it up? |
All of what gt1953 said. Maybe invent some new words on item #3.
Item #4, Heat! _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Sun Sep 12, 2021 11:16 am Post subject: Re: 67 Shock Replacement |
Just score it lengthwise, at an angle, with a Dremel or hacksaw. Then get a hammer and chisel, or your favorite beat up screwdriver and hit it where you scored the bushing and peel it off like an orange. Also use some spray or heat. Should not be that difficult. _________________ Come on, It's not rocket science. KISS |
glutamodo The Android
Joined: July 13, 2004 Posts: 26311 Location: Douglas, WY
Posted: Sun Sep 12, 2021 11:47 am Post subject: Re: 67 Shock Replacement |
In my experience, when you have a shock sleeve stuck to the mounting stud, you use an air chisel applied at an outward angle. _________________ Andy T.
raydog Samba Member
Posted: Sun Sep 12, 2021 11:58 am Post subject: Re: 67 Shock Replacement |
glutamodo wrote: |
In my experience, when you have a shock sleeve stuck to the mounting stud, you use an air chisel applied at an outward angle. |
Same idea, I was just going with more common tools in case he wasn't set up with a compressor and attachments. _________________ Come on, It's not rocket science. KISS |
Posted: Mon Sep 13, 2021 6:08 am Post subject: Re: 67 Shock Replacement |
Thanks everyone. I got it off. Propane torch, vice grips, and a ball peen hammer. _________________ shakers73
'74 Super Beetle
'67 Beetle
