Blowing a fuse, need a second set of eyes
TheVintageVw
TheVintageVw is offline
PostPosted: Sun Sep 12, 2021 1:57 pm    Post subject: Blowing a fuse, need a second set of eyes Reply with quote
59 single cab
Out of the blue every time I pull the headlight switch I blow the fuse pictured below. If I pull the wire from the right taillight housing I no longer blow that fuse. If I remove the right tail light bulb, fuse blows.
Double checked wiring at right taillight, and at the headlight switch.
Obviously right taillight does not work but signal does. All other lights functional
Is my problem at the right taillight?
pyrOman
Fire Master
pyrOman is offline
PostPosted: Sun Sep 12, 2021 2:19 pm    Post subject: Re: Blowing a fuse, need a second set of eyes Reply with quote
Trace that wire, it must be “pinched” somewhere grounding out! Confused
ToolBox
ToolBox is offline
PostPosted: Mon Sep 13, 2021 8:25 am    Post subject: Re: Blowing a fuse, need a second set of eyes Reply with quote
TheVintageVw wrote:
59 single cab
Is you liscense light hooked to that fuse like it should be?
Sounds like an issue with the tail lamp housing. Post a picture of the backside.
johny__utah
johny__utah is offline
PostPosted: Mon Sep 13, 2021 9:22 am    Post subject: Re: Blowing a fuse, need a second set of eyes Reply with quote
Check your license plate light housing, make sure the wires are correct. Power wire isn't connected to the ground terminal in the holder.
1956 L31
1961 L346 L347
1963 L380 L289
TheVintageVw
PostPosted: Fri Sep 17, 2021 2:27 pm    Post subject: Re: Blowing a fuse, need a second set of eyes Reply with quote
that was it!
Thanks
johny__utah
PostPosted: Fri Sep 17, 2021 2:40 pm    Post subject: Re: Blowing a fuse, need a second set of eyes Reply with quote
TheVintageVw wrote:
that was it!
Thanks
Aweome! Glad it was resolved.
1956 L31
1961 L346 L347
1963 L380 L289
