SoFloScott Samba Member
Posted: Mon Sep 13, 2021 6:29 am Post subject: Interior - Replace side panels & floor |
Hi all,
We're just removed the interior and ended up throwing out the floor and side panels as they were well past their Best Before date. So now looking for options for something tidy, affordable, and attractive.
For the side panels I've seen there are kits we can buy and that is our fallback. But from the photos they seem pricey and a little flimsy. Any alternatives out there for someone not exactly gifted in the carpentry skill set?
Definitely need help on floor. Want something that holds up better to spills and water soaked boots than the untreated plywood and vinyl tyle that we just removed. Any suggestions, tips gratefully received!
Thanks,
Scott
Ps, Current state of interior:
https://ibb.co/qNMxp3C |
sgellis Samba Member
Joined: July 06, 2016 Posts: 2014 Location: SW Nova Scotia, Canada
galexander Samba Member
Joined: April 17, 2003 Posts: 524 Location: Round Rock, TX
Posted: Wed Sep 15, 2021 9:13 am Post subject: Re: Interior - Replace side panels & floor |
Great suggestion on the 1/8" baltic birch for sure.
On my rear floor, I put down a plastic vapor barrier and then used Pergo laminate flooring left over from when I did the floors in my house. It has been in Jerry the Bus now for 15 years! Holding up well! _________________ enjoy the journey,
Gary
Check out our YouTube Channel, VW Life |
Braukuche Samba Member
Posted: Wed Sep 15, 2021 8:03 pm Post subject: Re: Interior - Replace side panels & floor |
If you want to add to the value get Baltic Birch and have it cut after measuring.
For the floor Westfalia used plywood with linoleum, I think someone reproduces something very similar to the original.
The original stuff held up for a scant what 50 some odd years? I’d stick with it. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Fri Sep 24, 2021 5:33 am Post subject: Re: Interior - Replace side panels & floor |
Thanks guys. sgellis - simply amazing.
I'm also reaching out to Clara here who provides panels if I opt to be lazy. |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Wed Jan 03, 2024 11:49 am Post subject: Re: Interior - Replace side panels & floor |
has anyone been able to source 1/8" Baltic Birch in a 4'x8' piece for the long panel? _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Stocknazi Samba Member
Posted: Wed Jan 03, 2024 2:43 pm Post subject: Re: Interior - Replace side panels & floor |
zuggbug wrote: |
has anyone been able to source 1/8" Baltic Birch in a 4'x8' piece for the long panel? |
Wurth Wood group in Charlotte, NC had some 4'x8' birch about 15 years ago. However, it was not Baltic Birch, and had a darker colored, almost luan/mahogany type color and grain so I passed on buying any. I never could find any that matched the light/tight grain Baltic Birch.
I have not been able to find ANY 1/8" 4'x8' birch since. Luan door skin, which is actually a type of mahogany, is the only product that seems to be available.
I ended up splicing the 5'x5' Baltic Birch in the rear seat armrest area, so it hides the seam for the most part.
Only other option I can think of is a veneer, but you are still stuck with the indoor grade luan material. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Thu Jan 04, 2024 4:02 pm Post subject: Re: Interior - Replace side panels & floor |
zuggbug wrote: |
Check your local lumber supplier. Ones that deal in exotic wood should have 5'x5' 1/8" sheets which are about what you need for the floor, etc.
Around here it goes for around $57 a sheet |
mdege Samba Member
Joined: January 16, 2018 Posts: 940 Location: Niederkruechten, Germany
