mykillcykill Samba Member
Joined: March 06, 2012 Posts: 50 Location: LOs Angeles
Posted: Mon Sep 13, 2021 7:52 am Post subject: Early tail light repair |
Looking for advice before I have to cut things up. The connectors on my early round tail lights are broken and brittle and need replacing. Does anyone sell the connectors to replace? Otherwise I was considering cutting and installing a modern connector. Thoughts? Thanks in advance.
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
So.Cal Danny Samba Member
Posted: Thu Sep 16, 2021 12:17 pm Post subject: Re: Early tail light repair |
I have these on my bus and they are an excellent upgrade to a traditional bulb. They are bright even during the day. |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Thu Sep 16, 2021 6:22 pm Post subject: Re: Early tail light repair |
So.Cal Danny wrote: |
Same here, great upgrade. |
Lind Samba Member
Joined: November 06, 2000 Posts: 9916 Location: idaho
Posted: Thu Sep 16, 2021 6:39 pm Post subject: Re: Early tail light repair |
late '60 - '61 taillights suck. The plastic gets brittle and breaks.
I have used '57-'60 taillights and then fold back the two tabs holding screw terminal guts in, and then put spade terminal guts from a '62-'71 taillight in it. Then I use a hose clamp to hold a ground wire to the barrel, so I get a good ground without drilling any holes. All bolt on using stock parts. (the hose clamp will not work on '61 taillights.)
The LEDs are good too. _________________ .
Wanted:
Posted: Fri Sep 17, 2021 7:43 am Post subject: Re: Early tail light repair |
Thanks for the suggestions. In keeping with my normal traditions, I'll mess around with it until I get frustrated and order the LED's
Thanks again |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 363 Location: Mississippi
Posted: Fri Sep 17, 2021 1:49 pm Post subject: Re: Early tail light repair |
Looks like a job for a dremel tool on a Lego block to me. |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
