Which cam?
dieseltdi
dieseltdi is offline
PostPosted: Tue Sep 14, 2021 4:22 pm    Post subject: Which cam? Reply with quote
I am about to start my first rebuild of a 36hp engine. I have rebuilt many VW engine but I have never had the problem of figuring out which cam gear goes in the engine. +1, +2, -1, -2, 0? Any way to figure it out without buying 3 or mare cams? Hayden
Dan22
Dan22 is offline
PostPosted: Wed Sep 15, 2021 7:17 pm    Post subject: Re: Which cam? Reply with quote
You can start by matching what came out of the engine. In reality the best ways is to sort it out as you assemble the motor. There is a backlash spec. Too tight and the cam pops out of its bearing as you rotate, or too loose and you feel the backlash. Then adjust accordingly.
The perfect gear may not exist but some vendors sell different numbered gears new. I do have a spare couple of gears. One is a +4 (new).
1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074
dieseltdi
PostPosted: Wed Sep 15, 2021 7:41 pm    Post subject: Re: Which cam? Reply with quote
problem is, I don't have the cam that cam out of this engine. I have a cam, but haven't cleaned it up yet but it is labeled as having come out of another block that I have. I am trying to rebuild the original numbers matching engine. I have the fully dressed crank but so far I haven't found the cam that goes with it. Hayden
Dan22
Dan22 is offline
PostPosted: Wed Sep 15, 2021 8:18 pm    Post subject: Re: Which cam? Reply with quote
Well it can be a starting point then. At least you have it and don't have to buy 3. With the one example cam you can use it, go up one, or go down 1. This assumes the cam journals and cam bearing surfaces are in good shape.
Somewhere I saw a reference to what the different numbers mean in terms of backlash. It could have been in the VW Trends rebuild article. Check that out at least. It is somewhere on this site.
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Wed Sep 15, 2021 11:54 pm    Post subject: Re: Which cam? Reply with quote
The timing gear pitch radius is a way to correct for slightly different center-lines between the crankshaft and camshaft bores.
Put the crank in the case with its bearings. Along with the cam you have, mesh them correctly, make sure the bearings have some lube and spin the crank over by hand a couple of turns forwards. Then do it again backwards. Watch and feel all the time for signs of binding or the cam gear wanting to lift up.
Andy T.
I do not know how to fix this. All I can say is it all works fine for me with what I use, Firefox.
dieseltdi
PostPosted: Thu Sep 16, 2021 5:45 pm    Post subject: Re: Which cam? Reply with quote
turns out the cam I have is a -4. I am going to see if I can find a couple of other cams and just use the one that "fits" the best.
dieseltdi
PostPosted: Fri Sep 17, 2021 6:11 pm    Post subject: Re: Which cam? Reply with quote
OK I now have a few more cams with varying numbers on them from +3. +4, a 0, but I also have a cam that has absolutely NO number on it. Any ideas?
Dan22
Dan22 is offline
PostPosted: Fri Sep 17, 2021 9:37 pm    Post subject: Re: Which cam? Reply with quote
Probably a zero.
PostPosted: Fri Sep 17, 2021 9:42 pm    Post subject: Re: Which cam? Reply with quote
There are 2 threads going, please use
https://www.thesamba.com/vw/forum/viewtopic.php?t=759585
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Beetle - Oval-Window - 1953-57 All times are Mountain Standard Time/Pacific Daylight Savings Time
