guatebus Samba Member
Joined: May 12, 2003 Posts: 393 Location: Oakland, CA
Posted: Wed Sep 15, 2021 8:50 am Post subject: Transaxle out - what else to check/replace? |
So my Rancho transaxle is arriving soon to replace my leaky, pops-out-of-fourth OG transmission.
Looking for opinions on what else to replace while I'm doing the swap.
1. Tranny mounts? Mine are OG and don't seem to be failing. What's the word on Wolfsburg West replacements? I know sometimes the new rubber isn't really as durable as the old stuff.
2. Shifter bushings? I replaced mine about 10 years and 40K miles ago. I guess it's not too much work or $$$ to put in new ones if everything is apart anyway.
3. Other? Does the Rancho rebuild come with axle boots? What other stuff should I have on hand? Trying to minimize downtime since this is my daily driver. _________________ '64 standard microbus
'69 deluxe microbus |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
galexander Samba Member
Joined: April 17, 2003 Posts: 524 Location: Round Rock, TX
Posted: Wed Sep 15, 2021 9:07 am Post subject: Re: Transaxle out - what else to check/replace? |
Good time to check some things:
New rear trans mounts
Check your Bowden Tube.
Check your Clutch Cable
Clutch and Pressure plate and throw out bearing
Does it come with new axle boots?
Is it complete or do you need to assemble?
Axle seals
Check your wheel cylinders and shoes
And get a Wolfgang Mid Mount, way easy to install, especially with transmission out of your Bus. That way whatever happens to the front trans mount, you are OK.
good luck!
Gary _________________ enjoy the journey,
Gary
Check out our YouTube Channel, VW Life |
TheVintageVw Samba Member
Joined: July 19, 2004 Posts: 654 Location: Porter Ranch California
Posted: Wed Sep 15, 2021 11:17 am Post subject: Re: Transaxle out - what else to check/replace? |
Is that Wolfgang mount recommended for all engine/tranny combos or is it more of a "performance" part. |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 363 Location: Mississippi
Posted: Wed Sep 15, 2021 12:04 pm Post subject: Re: Transaxle out - what else to check/replace? |
If the torsion bar/spring plate rubber bushings have never been addressed, this might be the time to replace those? |
Posted: Wed Sep 15, 2021 5:18 pm Post subject: Re: Transaxle out - what else to check/replace? |
Thanks, good tips on things to check.
What I'm very interested in is this tranny mount question. I don't want to replace the OG mounts and put in something new that has a chance to fail within a few thousand miles.
Any opinions on the different suppliers of tranny mounts out there? _________________ '64 standard microbus
Posted: Wed Sep 15, 2021 6:34 pm Post subject: Re: Transaxle out - what else to check/replace? |
The Mid mount is cheap insurance against those not so good Wolfsburg West front trans mounts.
I would not call it a performance add on, just a heavy duty addition. _________________ enjoy the journey,
Gary
Braukuche Samba Member
Posted: Wed Sep 15, 2021 8:04 pm Post subject: Re: Transaxle out - what else to check/replace? |
galexander wrote: |
I would not call it a performance add on, just a heavy duty addition. |
Agreed…it’s pretty much accepted that the repro mounts are garbage they split after a month in some cases.
I’m cheap so I run a 10mm bolt and nut through mine. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Lind Samba Member
Joined: November 06, 2000 Posts: 9916 Location: idaho
Posted: Thu Sep 16, 2021 6:28 am Post subject: Re: Transaxle out - what else to check/replace? |
Braukuche wrote: |
galexander wrote: |
I’m cheap so I run a 10mm bolt and nut through mine. |
That is a month longer than their shift couplers last. I would think that knowingly selling garbage is a bad idea, as it makes people question the quality of your other parts which may or may not be garbage...... _________________ .
Wanted:
Posted: Thu Sep 16, 2021 3:13 pm Post subject: Re: Transaxle out - what else to check/replace? |
OK sounds like I will leave in the OG mounts unless they look really really trashed. I hate it when brand new parts are garbage. _________________ '64 standard microbus
