bw65vw Samba Member
Joined: August 04, 2020 Posts: 149 Location: Tennessee
Posted: Wed Sep 15, 2021 8:56 am Post subject: 1300cc single port carb and dizzy combo?? |
My son bought a 72 super beetle and it has a 1300cc single port engine from a 66 in it. The engine has been rebuilt but has some hesitation with acceleration. The PO also had a Solex 34 PICT 3 carb paired up with a 009 dizzy. I have read on here that this combo is known to have that problem. So I'm wondering what would be better to replace the carb, dizzy or both for better and smoother performance? I have read here the Solex 34 need a vacuum advance dizzy but is this carb too big for the engine? I have an old ZV/PAU4R5 dizzy in a parts box that probably needs reworked but I understand they are vacuum advance only. Any suggestions are appreciated. Thanks! |
glutamodo The Android
Joined: July 13, 2004 Posts: 26320 Location: Douglas, WY
Posted: Wed Sep 15, 2021 9:40 am Post subject: Re: 1300cc single port carb and dizzy combo?? |
I doubt this engine is a 1300 single port engine any more, because a 34PICT-3 will not bolt onto a 1300 single port intake manifold. What kind of intake manifold do you have here??
_________________ Andy T.
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Wed Sep 15, 2021 10:03 am Post subject: Re: 1300cc single port carb and dizzy combo?? |
glutamodo wrote: |
Adapters are very common and cost like $10 bucks. Available at every VW parts house. |
bw65vw Samba Member
Posted: Wed Sep 15, 2021 10:18 am Post subject: Re: 1300cc single port carb and dizzy combo?? |
Here is a pic of it |
oprn Samba Member
Joined: November 13, 2016 Posts: 12730 Location: Western Canada
Posted: Wed Sep 15, 2021 10:50 am Post subject: Re: 1300cc single port carb and dizzy combo?? |
You need to ash can the 009 and find the stock VW distributor that matches that cab. Make sure the heat riser on the intake is not plugged with carbon and you have proper connections on whatever exhaust is on that engine too.
Your throttle hookup looks pretty flakey too by the way. I hope the engine bay has all the right tins and seals in place ... _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
bw65vw Samba Member
Posted: Wed Sep 15, 2021 10:57 am Post subject: Re: 1300cc single port carb and dizzy combo?? |
oprn wrote: |
Your throttle hookup looks pretty flakey too by the way. I hope the engine bay has all the right tins and seals in place ... |
Yeah my son has been doing alot without talking to me or letting me help. He rigged up the throttle connection with zip ties because the pin is missing. He hasn't put in the breastplate tin so told him needs to finish alot before he starts driving it. So that is my question what distributor is meant to pair up with that carb? I have seen maybe the 034? |
gt1953 Samba Member
Posted: Wed Sep 15, 2021 11:06 am Post subject: Re: 1300cc single port carb and dizzy combo?? |
Show us a photo of the intake manifold. The numbers on the side of the carb. Without that information most of us are not able to give you good advice. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
bw65vw Samba Member
Posted: Wed Sep 15, 2021 11:22 am Post subject: Re: 1300cc single port carb and dizzy combo?? |
These are the only other 2 pics I have I can ask him to take some more. I told him that fuel line/filter situation going on there has to be fixed too. |
thomas. Samba Member
Joined: July 31, 2010 Posts: 1291 Location: South West (Pa.)
Posted: Wed Sep 15, 2021 11:49 am Post subject: Re: 1300cc single port carb and dizzy combo?? |
Pruneman99 wrote: |
glutamodo wrote: |
I thought the adaptors were only used to put the smaller carb like the 30pict or h30/31 on the dual port manifold. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7215 Location: Videbaek Denmark
Posted: Wed Sep 15, 2021 1:47 pm Post subject: Re: 1300cc single port carb and dizzy combo?? |
I have come across such a manifold once or twice. I believe it is either from a 1600 sgl port industrial engine for the US market, - or from a 1 year production KG 1600 sgl port. Someone might be able to shed more light on that.
However, if the engine is really only 1300 displacement that is not the carb to use. Too "big" due to too large idle bypass etc etc. It can be made to work, but it is NOT for the average tuner.
I would take a volume measurement and figure out what the displacement really is and then work from that. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Wed Sep 15, 2021 1:56 pm Post subject: Re: 1300cc single port carb and dizzy combo?? |
thomas. wrote: |
Yes, that is the common adapter. Hell I have a few of them and run one on my Baja Bug. As for converting from small flange manifold to large carburetor, if such a part exists, I've never seen one. _________________ Andy T.
Posted: Wed Sep 15, 2021 2:45 pm Post subject: Re: 1300cc single port carb and dizzy combo?? |
glutamodo wrote: |
thomas. wrote: |
Yes, that is the common adapter. Hell I have a few of them and run one on my Baja Bug. As for converting from small flange manifold to large carburetor, if such a part exists, I've never seen one. |
I've not used them, but it was my understanding you could just flip them over to go the other way. So I could be incorrect. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31373 Location: Hot Arizona
Posted: Wed Sep 15, 2021 2:50 pm Post subject: Re: 1300cc single port carb and dizzy combo?? |
Pruneman99 wrote: |
I think that one could engineer a way to flip the adapter to use large carburetor on a smaller manifold. Also, some manifold center sections come drilled these days to accept smaller or larger base carburetors.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
bw65vw Samba Member
Posted: Wed Sep 15, 2021 3:50 pm Post subject: Re: 1300cc single port carb and dizzy combo?? |
Sorry I should have given more information. We had the top end of the engine apart due to a bad cylinder head when he first got it and had a local builder rebuild the bottom end. So we do know it is a 1300. He just recently got it back in the car to try it out. Those where the carb and dizzy on it when he got the car. So we are trying to tune the engine and get it road worthy now. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Wed Sep 15, 2021 4:32 pm Post subject: Re: 1300cc single port carb and dizzy combo?? |
It would be highly unusual for that engine to have been built back up as a 1300. Check with the builder that it's not a 1966 case built up as a 1600.
If it's truly a 1300 I would run the stock carburetor, a 30 PICT 1 Solex with the matching 113 905 205 K distributor to get the best performance. Even if it's a 1600 you could run the above pairing as long as you are not looking to race around town _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Wed Sep 15, 2021 11:28 pm Post subject: Re: 1300cc single port carb and dizzy combo?? |
Some numbers I'm interested in knowing here.
The full part number of the intake manifold.
The Modification State Number of this carburetor. It should be on the base flange of the carb on the left side. (ie... VW 377_1) The carb in the photos has way too many vacuum fittings on it.
oprn Samba Member
Posted: Thu Sep 16, 2021 5:45 am Post subject: Re: 1300cc single port carb and dizzy combo?? |
After struggling to get my 1600 SP to run right with a 34PICT-3 and a 003 distributor I gave up on them and went with a years matching 30PICT-2 and a 205T distributor. The difference was amazing, the engine has never run this good! One tap on the gas to set the choke and it starts with no baby sitting and runs all day long with no misfire, stumble or hesitation ever.
Could I gain a HP or two with the 34PICT? Maybe but I will never miss it on a 1000lb Buggy riding the trails in the hills. You might in the heavier Super Beetle on the freeway. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Thu Sep 16, 2021 8:17 am Post subject: Re: 1300cc single port carb and dizzy combo?? |
Agree with all of the above except that numbers matching with a 30 PICT 2 carburetor would have been a 113 905 205 M distributor. The only real difference being that the 113 M uses the short cap and rotor as do the earlier distributors. The 113 M and T even use the same vacuum canister on a vacuum advance only distributor so it's a small correction. _________________ Roads Scholar &
Posted: Thu Sep 16, 2021 10:01 am Post subject: Re: 1300cc single port carb and dizzy combo?? |
oprn wrote: |
I agree. A stock 1600 sgl port simply do not have the "suction" needed to get the 34 Solex working properly without some hefty mods. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
oprn Samba Member
Posted: Thu Sep 16, 2021 4:20 pm Post subject: Re: 1300cc single port carb and dizzy combo?? |
tasb wrote: |
Agree with all of the above except that numbers matching with a 30 PICT 2 carburetor would have been a 113 905 205 M distributor. The only real difference being that the 113 M uses the short cap and rotor as do the earlier distributors. The 113 M and T even use the same vacuum canister on a vacuum advance only distributor so it's a small correction. |
The chart I looked it up on from this site listed both the M and the T. Other sources may differ but as long as they both use the same vacuum canister they are both a match as neither one has a mechanical advance component. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
