Rickyk22 Samba Member
Joined: February 13, 2020 Posts: 49 Location: Long Island, NY
Posted: Wed Sep 15, 2021 5:30 pm Post subject: Help installing head studs |
Hey all, I'm up to installing me head studs and I'm installing them on my 3-4 side currently. I have 8mm case savers installed. I've got the 4 long studs installed, the two middle short ones and the one mid sized stud. My question is that I am trying to installed the last stud which is supposed to be a long one also, but because of the case saver, I can't screw it in even close to enough to be the same height as the mid sized stud that is the opposite corner. Am I doing something wrong, or do I need to get an additional mid sized stud because of the case savers?
Thanks alot. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9771 Location: Oregon
Posted: Wed Sep 15, 2021 5:52 pm Post subject: Re: Help installing head studs |
Should be 5 long, 2 short and 1 mid length. On the left side of the engine.
4 long for the bottom of the cylinders and the extra for the deep studded #3 forward upper.
The 2 short for the top between cylinders 3-4 and the mid length upper rearward #4.
All the above IIRC is correct.
You can carefully run a tap through that deep thread insert. Just don't bottom out the tap and break it off.
There might be a burr preventing the stud from threading in deeply enough. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Wed Sep 15, 2021 6:02 pm Post subject: Re: Help installing head studs |
Thanks. Seems like it bottoms out on the shoulder of the stud. I thought I might have to use a dye to continue the thread on the stud, but you're saying I should have to do that? Thanks again |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Wed Sep 15, 2021 6:12 pm Post subject: Re: Help installing head studs |
If they did not deep set the case saver (its flush with the case deck like the other 7), you will need another mid length stud, dont cut more threads on the long stud. If that case saver is down in the hole like its supposed to be, you need to look close to see why the long stud wont thread all the way _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Wed Sep 15, 2021 6:13 pm Post subject: Re: Help installing head studs |
Where on Long Island are you? I might be able to stop by and take a look. _________________ Glenn
Member #1009
#BlueSquare |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Wed Sep 15, 2021 6:38 pm Post subject: Re: Help installing head studs |
What Teeroy said above...sounds like your upper back head stud is NOT deep studded, which is a modification to a stock case
If your case is still stock you simply need one more medium length stud |
Posted: Wed Sep 15, 2021 7:28 pm Post subject: Re: Help installing head studs |
Ok thanks. Yes, it's flush like the others, so I guess I'll just get another medium length.
Thanks Glen, I'm in sayville. Where are you? |
Glenn Mr. 010
Posted: Wed Sep 15, 2021 7:36 pm Post subject: Re: Help installing head studs |
Rickyk22 wrote: |
Massapequa.
If you want, email or PM me your phone number and I can come by and take a look.
I've built a few engines over the years _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Sep 16, 2021 8:23 am Post subject: Re: Help installing head studs |
is there any reason i couldn't cut down one of the long studs and then run through a dye and rethread the end? |
Posted: Sat Sep 25, 2021 8:48 pm Post subject: Re: Help installing head studs |
Ok, so I can't cut down a longer stud because the shaft is narrower than the threads and when I thread it, there isn't much there. So now I need a single 8mm medium length stud. I think it measures 8 3/8" long. So my next question is that all the other studs are from this scat kit
https://scatvw.com/product/8mm-dual-port-8740-stud-kit/
If I get a stud that's different, will it be an issue? Will it be a weak point?
Thanks a lot! |
