Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1089 Location: Atlanta, GA
Posted: Wed Sep 15, 2021 5:36 pm Post subject: Subaru Conversion Dilemma-Wiring Harness |
My Subaru conversion project ground to a halt today. The UPS Store that shipped my wiring harness, ECU, transmission controller, and drop sensor lost the package. They have admitted fault, and the store owner will be cutting me a check tomorrow for the loss.
This is a huge blow. I was already disappointed that I couldn't use my engine from my short block due to issues discovered during dismantling. Now this.
If I were to go looking for all of those components, would they have to specifically come from a 2001 Forester Automatic, or could I go a couple of year models higher to say, a 2004? As long as it's a physical throttle cable and uses a 4EAT automatic.
Or, do I just scrap what I have and start with a clean slate and a different donor car? _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A converversion-Road Testing Phase
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Wed Sep 15, 2021 6:39 pm Post subject: Re: Subaru Conversion Dilemma-Wiring Harness |
Someone with greater knowledge will chime in but here is my understanding as I have an 00 outback 2.5 in mine. The 00-02 are plug and play interchangeable. The 00-04 work together with some minor mods like swapping out some sensors like knock etc.. maybe the manifold as well?. Again someone else will chime in but this a my limited understanding. Sorry for your rotten luck on that, hopefully it will turn up at some point |
Joined: January 01, 2007 Posts: 16886 Location: sticksville, ct.
Posted: Wed Sep 15, 2021 10:13 pm Post subject: Re: Subaru Conversion Dilemma-Wiring Harness |
Silverghost500 wrote: |
clear this up for me...
your donor was from a 01, is that how i read this?
01 was a funny year, and IIRC it was only the outback that had a goofy "1 year only" set up and had a specific cam and crank pulley in terms of the pick up (teeth for the sensors)
why do you need the trans controller? reversed subaru i am guessing?
anyway, any harness from 99 until 04 iirc should work, just match the components (electrically) and don't forget the o2 sensor harness (some had them, some didn't)
the engine doesn't care what you bolted to it, just make sure the cam/crank sprockets match the ECU.
i would for sure grab the VIN from your donor. makes life easier when calling the dealer for parts _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Sep 16, 2021 5:13 am Post subject: Re: Subaru Conversion Dilemma-Wiring Harness |
Yes, the 2001 Forester S 2.5 with 4EAT automatic transmission was to be used for a Subarugears reversed automatic transmission conversion.
I did at least keep the intake manifold wiring harness, but everything else is MIA. My harness had the connectors for the transmission sub harness, as well as the connectors for the drop resistor and the transmission control unit. My alternator harness was included in the shipment too. My harness also had the oxygen sensor sub harness for 2 O2 sensors.
I've checked Subaru dealer parts pages, and the electrical components are available, but the prices are steep.
-transmission control unit $510
-ECU $600+
-drop resistor $80
I do have the crank pulley sprocket from my donor. Not sure it's an oddball tooth configuration or one more commonly used on the automatics before and after this year & model. I can take a photo of it and attach later. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
Crankey Samba Member
Posted: Thu Sep 16, 2021 8:22 am Post subject: Re: Subaru Conversion Dilemma-Wiring Harness |
Isn't it possible the receiver of your package will reject it and the local ups will send it back to the store it came from ? |
Posted: Thu Sep 16, 2021 8:24 am Post subject: Re: Subaru Conversion Dilemma-Wiring Harness |
p/m sent _________________
Jake Raby wrote: |
Brian wrote: |
valvecovergasket Samba Member
Posted: Thu Sep 16, 2021 8:36 am Post subject: Re: Subaru Conversion Dilemma-Wiring Harness |
Not sure it's an oddball tooth configuration or one more commonly used on the automatics before and after this year & model. I can take a photo of it and attach later. |
the two subaru setups im familiar with are the 36-2-2 (left) and the 6/7 (right)
i assume youve got one of those? _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Posted: Thu Sep 16, 2021 9:16 am Post subject: Re: Subaru Conversion Dilemma-Wiring Harness |
the 36-2-2 is the oddball in i believe the outback. it also had a goofy throttle body as well
beyond that anything should work ok in the same year range that the o/p is working with _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Sep 16, 2021 11:57 am Post subject: Re: Subaru Conversion Dilemma-Wiring Harness |
Here's the crankshaft timing sprocket/pulley that came of my donor's 2001 Forester EJ251. Looks to be the 6/7 rather than the 36.
3-Speed Automatic
Posted: Thu Sep 16, 2021 12:16 pm Post subject: Re: Subaru Conversion Dilemma-Wiring Harness |
^^^^ that's the more common one on the early cars. _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Sep 16, 2021 12:45 pm Post subject: Re: Subaru Conversion Dilemma-Wiring Harness |
@Skills, well at least one good thing...I have a common part! _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
Posted: Thu Sep 16, 2021 2:13 pm Post subject: Re: Subaru Conversion Dilemma-Wiring Harness |
@Crankey, you would think, but that's where it gets complicated.
I brought in my 35 pound package and the label created at 4:41PM.
The other person brought their package in and label created at 1:27PM.
So it takes them that long to apply loose labels on packages? C'mon! You're asking for trouble!
The other person's label was to transfer a 1 pound envelope of documents over the USPS for them to ship and deliver. I finally got hold of that wrong label's tracking receipt and the tracking number. Neither UPS or USPS tracking sites show any information on the tracking info.
After multiple calls to USPS today they see the wrong label created, but no record that the package was picked up by USPS.
However...my package with the wrong label left the UPS Store. No one at the store can answer whether it was a UPS or USPS person that picked it up.
My package arrives in Johnson City and is rejected by the recipient. Apparently it is sent to a Johnson City post office. I've been on the phone with all of them. One person at one of them stayed on the line and looked and tried multiple options. They said if this happened last week it probably would have been sent back to UPS, even though it has a USPS tracking number.
The UPS Store manager and owner I shipped my package from are washing their hands of it all. They wrote me a reimbursement check today for my shipping, and the insurance. They've been friendly, yet completely incompetent.
Today while picking up the reimbursement check they had a USPS guy going through packages, and in less than 5 minutes he picked out 4 different errors by them from no postage, no label, or parcels that should be shipped through UPS being in their USPS pile of pickups. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
Posted: Thu Sep 16, 2021 7:11 pm Post subject: Re: Subaru Conversion Dilemma-Wiring Harness |
Wow. Sounds like an episode of the 3 stooges. That sucks.
I get other people's mail about 2x a week these days and an errant ups delivery too.
Usually the mail is for a neighbor, but the ups is a little more odd.
Folks at the local ups store here seem ok, but I haven't challenged them with anything yet.
Good luck with this and hopefully it's the worst hiccup you have during your project. |
Posted: Fri Sep 17, 2021 5:44 am Post subject: Re: Subaru Conversion Dilemma-Wiring Harness |
Thanks. The frustrating part of this experience has been the aloofness of the store manager. Every time I would go by or call for a status update I would have to start over with them. We're not a big city, and this is not a big store. You can smile all you want, but it'll only cover up the incompetence for so long.
I've got some folks on the lookout for components, but this may be the final sign I need to scrap everything with my current donor and start over. Every thing about this car as fought me.
I have at least learned a great deal from this experience, and if/when the time comes I work on another donor I'll be better prepared to know what to look for and how to approach it. Hopefully with better parts! _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
