Switch
jonnydot
jonnydot is offline
PostPosted: Thu Sep 16, 2021 4:54 am    Post subject: Switch Reply with quote
Was there a supplemental driving light switch or was it wired direct to the head light switch
SGKent Premium Member
SGKent is offline
PostPosted: Thu Sep 16, 2021 8:34 am    Post subject: Re: Switch Reply with quote
usually a relay with a separate power lead. The relay trigger on off is tied to low beams and a switch so the aux lights only come on with low beams. An off road set up would be totally separate but most states the aux off road lights would have to be covered when driving other than off road.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
sjbartnik
sjbartnik is offline
PostPosted: Thu Sep 16, 2021 4:49 pm    Post subject: Re: Switch Reply with quote
Yes when I had done this years ago I ran the driving light power via a relay and the trigger wire for the relay was tapped into the the white high-beam wire (either one) at the fuse box (you can use a piggyback-type spade terminal for that). That way when the high beams were turned on, the relay closed and fed power to the driving lights.
Tap in on the OUTPUT side of the fuse so that if your relay shorts out it blows the fuse rather than melts a lot of wiring under the dash.
1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
jonnydot
jonnydot is offline
PostPosted: Thu Sep 16, 2021 6:39 pm    Post subject: Re: Switch Reply with quote
I was hoping that there was an OEM dedicated switch that disconnected them from the high beam switch. In Aus this is what we need to have for registration. Perhaps the Westfalia's had them ? or I believe there was a foul weather package did they have a switch ?
rsbadura
rsbadura is offline
PostPosted: Thu Sep 16, 2021 10:44 pm    Post subject: Re: Switch Reply with quote
No extra switch - also not included at Westfalia or bad weather package Z01.
Extra light switch only for fog lights (rear/front) in Z01.
And st some extra switch for interior light.
See VW wiring plans
Rolf-Stephan Badura
1970 VW Karmann-Ghia Coupe
1979 VW Bus L to camper conversion
1982 Eriba Pan travel trailer
2017 VW CrossPolo
HAZET classic tools
jonnydot
jonnydot is offline
PostPosted: Fri Sep 17, 2021 12:09 am    Post subject: Re: Switch Reply with quote
Bummer will look at some Porsche switch's to see what they had, or perhaps use a hazard light switch many thanks to all
