Goodman1967 Samba Member
Posted: Thu Sep 16, 2021 6:27 am Post subject: Where are the door drain hole locate? |
Hello everybody.
I have already done some research about door drain holes but it is not clear to me.
The picture below was captured from this website. Could you please tell me that red arrows are drain hole? If there are, how water drain out when door seal is put in. By the way, what is blue arrow mean?
Thank you in advance.
rcooled Samba Member
Joined: September 20, 2008 Posts: 2507 Location: Santa Cruz, CA
Posted: Thu Sep 16, 2021 10:43 am Post subject: Re: Where are the door drain hole locate? |
Yes, the red arrows are pointing to the drain holes in the bottom of the door. If you look real closely, you can see that the channel for the door seal does not completely block the holes. They remain partially open to the inside of the door, allowing water to drain out. The door seal does not cover these holes.
The blue arrows are pointing to a reinforcement beam that was added to the inside of the doors starting in 1973 to give added protection in the event of a side impact collision. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
Posted: Tue Sep 21, 2021 6:26 am Post subject: Re: Where are the door drain hole locate? |
rcooled wrote: |
The blue arrows are pointing to a reinforcement beam that was added to the inside of the doors starting in 1973 to give added protection in the event of a side impact collision. |
I really thank you for your answer that is very clear to me. |
