elpres Samba Member
Posted: Thu Sep 16, 2021 7:01 am Post subject: Engine noise |
Hey guys.
Im struggling with a weird “exhaust like” sound.
Valve gaps are set, timing fine, nice idle, doesn’t seem like an exhaust leak. The sound comes out from the exhaust pipe tip
But when I pull the #4 ignition cable while running, the sound disappears!
Any pointers? Ideas?
https://youtube.com/shorts/1t7YPvhNCt4?feature=share _________________ Jakob |
Posted: Thu Sep 16, 2021 11:48 am Post subject: Re: Engine noise |
elpres wrote: |
Hey guys.
https://youtube.com/shorts/1t7YPvhNCt4?feature=share |
Done a compression check? |
Danwvw Samba Member
Posted: Thu Sep 16, 2021 11:59 am Post subject: Re: Engine noise |
I don't think it's anything. serious it sounds to me like an exhaust leak combined with a cylinder that doesn't fire every time it should. Maybe you can isolate it by disconnecting one plug wire at a time. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Fri Sep 17, 2021 11:53 am Post subject: Re: Engine noise |
I would do a compression check - if the sound is coming from the tail pipe rather than around the engine, it could be a valve seat problem. _________________ Ancient vehicles and vessels
Cap10323 Samba Member
Posted: Fri Sep 17, 2021 2:27 pm Post subject: Re: Engine noise |
It sounds like a missfire to me. Step one would be to isolate which cylinder it's coming from and check for compression and spark.
If it has good compression, I'd assume an ignition issue. _________________ -Ian
'77 Westfalia - 2.0 F.I |
Starbucket Samba Member
Posted: Fri Sep 17, 2021 4:03 pm Post subject: Re: Engine noise |
Wait until motor is cold, start it and feel around heat riser joints and head exhaust mounts with your hand and you will feel the leak. |
SGKent Samba Member
Posted: Fri Sep 17, 2021 4:29 pm Post subject: Re: Engine noise |
if the sound is a putt putt .... putt ....... putt putt where it skips a beat then you can put ypur hand close enough to the exhaust to feel it at idle but not close enough to be burned. Feel if the pulses are regular or miss sometimes. If they miss and you remove the #4 wire, and the irregular goes away but there is a permanent hole in the rhythm then it sounds like #4 is mis-firing. All the advice given by others is valid. It could be mechanical but it could also be a bad spark plug, an air leak on that cylinder, a bad plug wire, or even a distirbutor cap. You can start by inspecting it at night in the dark, being careful of any belts and hot things - no long hair etc near the engine, loose shirt sleeves, and see if there are any electric arcs on number 4 wire in the dark. They will be really visible in the dark if it is happening. If misting the wire with a fog of water from a misting bottle makes it worse then it is probably a wire. Plugs and distributor caps can do it too. So can a sticking valve or loose seat but you normally hear that valve noise too when it happens. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
elpres Samba Member
Posted: Sun Sep 19, 2021 11:57 am Post subject: Re: Engine noise |
SGKent wrote: |
if the sound is a putt putt .... putt ....... putt putt where it skips a beat then you can put ypur hand close enough to the exhaust to feel it at idle but not close enough to be burned. Feel if the pulses are regular or miss sometimes. If they miss and you remove the #4 wire, and the irregular goes away but there is a permanent hole in the rhythm then it sounds like #4 is mis-firing. All the advice given by others is valid. It could be mechanical but it could also be a bad spark plug, an air leak on that cylinder, a bad plug wire, or even a distirbutor cap. You can start by inspecting it at night in the dark, being careful of any belts and hot things - no long hair etc near the engine, loose shirt sleeves, and see if there are any electric arcs on number 4 wire in the dark. They will be really visible in the dark if it is happening. If misting the wire with a fog of water from a misting bottle makes it worse then it is probably a wire. Plugs and distributor caps can do it too. So can a sticking valve or loose seat but you normally hear that valve noise too when it happens. |
A lot of good advice right there. Thanks
I did take dizzy, cable and plug from another engine without any change in the putt putt putt sound.
Next I will go after the regularity of the sound.
I don’t hear any mechanical sound I think..
I’ll post my finding. _________________ Jakob |
Posted: Mon Sep 20, 2021 10:13 am Post subject: Re: Engine noise |
When an engine has an exhaust valve leaking, you may also be able to hear a periodic louder hissing as you crank the engine with the ignition disabled.
Also the rhythm of the cranking will become uneven as the load on the starter motor is lower on the low compression cylinder.
I found one by accident at our technical weekend - I put a 2000 amp current clamp probe on the starter motor feed connected to a 1995 Fluke scopemeter, and instead of telling the owner that the max current his 2110 was needing to crank was 180 amps for each cylinder in turn, which was the question he asked me to check ..
It turned out that one cylinder needed 180 amps and two needed 150 amps and one needed 100 amps.
A compression test showed basically 10 PSI on the low cranking current cylinder...
This engine made chuffing noises as you cranked it, same as leaving out a spark plug..
A Mofoco head which it turned out had a loose valve seat, and every valve guide in both heads was loose, apart from one which had been fixed with a 0.1mm larger guide at some time in the past. _________________ Ancient vehicles and vessels
Posted: Mon Sep 20, 2021 11:16 am Post subject: Re: Engine noise |
mikedjames wrote: |
A Mofoco head which it turned out had a loose valve seat, and every valve guide in both heads was loose, apart from one which had been fixed with a 0.1mm larger guide at some time in the past. |
People don't appreciate how easy it is to do a pseudo compression test by just cranking the engine over with the ignition disabled. A few seconds of cranking and you often have a pretty good idea of the engine's condition. Turning it over by hand can be helpful as well as you may be able to hear where the compression is leaking off and tell if the leak is occurring on the up stroke or near TDC. |
elpres Samba Member
Posted: Wed Sep 29, 2021 9:04 am Post subject: Re: Engine noise |
Did a compression Test
130/130/130/100
So something to work from there.
Thank you for all your great input guys. 👍 _________________ Jakob |
