rastomas Samba Member
Joined: April 05, 2007 Posts: 258 Location: rosendale, ny
Posted: Thu Sep 16, 2021 4:06 pm Post subject: Bell housing for '74? |
Which bell housing will work for a start-up stand?
'74 type 4. _________________ "It's not 'You are what you eat', it's 'You are what you don't SHIT". Wavy Gravy.
'74 Westy |
SGKent Samba Member
Posted: Thu Sep 16, 2021 4:11 pm Post subject: Re: Bell housing for '74? |
rastomas wrote: |
'74 type 4. |
it and the starter need to fit the flywheel size. You'll have to measure it. You could have a 1978 engine with a 1978 flywheel and bellhousing on your bus now, or a 1972 flywheel and bell housing. These cars have had too many owners. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Sep 16, 2021 4:25 pm Post subject: Re: Bell housing for '74? |
This bus is unmolested. I need to know if a 72-3-4-5 etc comes up I can use it. _________________ "It's not 'You are what you eat', it's 'You are what you don't SHIT". Wavy Gravy.
'74 Westy |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Sep 16, 2021 4:32 pm Post subject: Re: Bell housing for '74? |
If you are sure it's stock 68-75 bus, or any 12 volt beetle or type 3 will fit for your purposes. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Sep 16, 2021 7:31 pm Post subject: Re: Bell housing for '74? |
You can use any bus or Vanagon bellhousing if you have the 210 or 215mm clutch. You need the starter that matches the bellhousing you are using though.
The problem comes in when you have the '76 and later 228mm clutch and try to mate it with the earlier bellhousing. It can be done but takes some clearancing of the bellhousing to get the piece to play with each other. If you are building a stand tough, I would suggest that one way or another you plan to make it work with the 228 clutch as that way it would be universal to most VW aircooled engines plus the Vanagon WBXer engines. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16922 Location: San Diego, California
Posted: Thu Sep 16, 2021 9:36 pm Post subject: Re: Bell housing for '74? |
https://www.google.com/search?q=tom+perazzo&cl...TTdl33LpjM _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
