Mateo83 Samba Member
Joined: September 14, 2021 Posts: 601 Location: Lodi, CA
Posted: Fri Sep 17, 2021 6:24 pm Post subject: 83 2.0 intake manifold plenum |
Tried to smog my new Vanagon yesterday and failed miserably for a number of issues. Seems the previous owner did a half ass hot smog to register it and sell it. The shop has a $1450 estimate to get it repaired. Anyway they say it has the wrong year intake manifold with the egr port blocked off and may not pass smog unless I have the referee approve it. My question would be were could I find the correct intake manifold if the referee doesn’t accept it? |
pathao Samba Member
Joined: November 01, 2012 Posts: 291 Location: Montreal, Canada
Posted: Sun Sep 19, 2021 6:25 am Post subject: Re: 83 2.0 intake manifold plenum |
83 2.0
FED ? CAL ?
I don't really know but my guess is you have one of the last year air cooled. CV engine. same like the bay
https://www.thesamba.com/vw/classifieds/detail.php?id=2497361
but you probably will also need other components that probably have been removed. Again baywindows buses 79 use a CV engine.
And if you have a California specs, well that's an other beast. _________________ 1982 AC P27 - 2.0 FI FED - 091 - BA6
English is a second language to me |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32591 Location: Reading Pennsylvania
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10371 Location: Sunshine Coast B.C.
Posted: Sun Sep 19, 2021 11:53 am Post subject: Re: 83 2.0 intake manifold plenum |
scwright99 wrote: |
... Anyway they say it has the wrong year intake manifold with the egr port blocked off and may not pass smog unless I have the referee approve it. My question would be were could I find the correct intake manifold if the referee doesn’t accept it? |
Find an intake plenum in thesamba classified section?
Is the issue the lack of EGR port or entire EGR system?
The air cooled AFC manual shows some detail on the EGR systems. IIRC, there's 2 types. A 'net search should lead you to a link for a PDF of that AFC manual.
Would decoding the VIN help?
https://www.gowesty.com/tech-article-details.php?id=110
1988 West DIY 50º ABA
VE7TBN |
Posted: Wed Sep 22, 2021 6:50 pm Post subject: Re: 83 2.0 intake manifold plenum |
It’s CA smog, but the vin history looks like it lived in Oregon most of its life. So no smog. It’s still at the shop getting the visual smog issues addressed, hopefully tomorrow call the “Smog Referee” to see if they will allow it or not. Otherwise the shop said parts are hard to come by and a pain to change. |
Posted: Thu Sep 23, 2021 9:41 am Post subject: Re: 83 2.0 intake manifold plenum |
If you need parts, the Bay Window classifieds may have what you need. e.g. :
https://www.thesamba.com/vw/classifieds/search.php...ton=Search
The Federal and CA intake plenum may be the same but as you're likely finding, sourcing EGR parts is likely a PITA.
VE7TBN |
