Stuck in Vegas!! Need brakes!
johnnytod
johnnytod is offline
PostPosted: Sat Sep 18, 2021 9:05 am    Post subject: Stuck in Vegas!! Need brakes! Reply with quote
As much fun as Vegas can be, it happened that I have to do my brakes here.
Does anyone know a good VW brakes shop which works on Saturday and is reasonably priced? I could also drive outside of Vegas if need be
Do you guys know where I can find on Saturday to buy the front disk brakes pads? I have already the parts for the back drum brakes
Vehicle: VW 1982, diesel , Adventurewagen (higher roof which maybe a problem for some shops to put on the lift)
Appreciate any help because we have to leave for the Grand Canyon today
djkeev
djkeev is offline
PostPosted: Sat Sep 18, 2021 9:54 am    Post subject: Re: Stuck in Vegas!! Need brakes! Reply with quote
NAPA
Auto Zone
If not on the shelf, a day away.
Dave
Ghia
Vanagon
Beetle
Wildthings
Wildthings is offline
PostPosted: Sat Sep 18, 2021 3:35 pm    Post subject: Re: Stuck in Vegas!! Need brakes! Reply with quote
There is a VW parts house and shop to the east side of Vegas on what I believe used to be old US93, sorry don't know its name. Old US93 is a nice straight road that heads SSW towards Henderson so sticks out on the map.
I don't know that there is anything all that special about the front pads, so you may be able to get them at most any FLAPS. You don't need a whole lot of tools to just change out the pads, just an extra long screwdriver or pry bar, and whatever tool is required to remove the pins that hold the pads in place. There may have been more than one design of caliper used in your year so it helps to know what kind you have so you know which pads to buy.
It is best to have the correct size box end wrench to open the bleeder valve on the calipers (maybe 11mm?), but you could also buy a syringe or turkey baster to suck some fluid out of the brake fluid reservoir before pushing the pistons back in, so you don't make a mess.
Steve M.
Steve M. is offline
PostPosted: Sun Sep 19, 2021 7:54 am    Post subject: Re: Stuck in Vegas!! Need brakes! Reply with quote
Front? Rear? Pads, shoes discs?
Enquiring minds want to know!
16CVs Premium Member
16CVs is offline
PostPosted: Sun Sep 19, 2021 11:34 am    Post subject: Re: Stuck in Vegas!! Need brakes! Reply with quote
Why would you leave on a trip like that in a 30Yr old vehicle without some Pre maintenance? Brakes are not something that just break, you can look and see they are bad and should be kept safe and maintained if you're driving it 10 miles or 10K miles.
I agree with the others, those parts should be easy to get and any repair shop or Mobile Mechanic should be able to fit them and get back on the road.
Stacy
Samba member # 14980
djkeev
djkeev is offline
PostPosted: Sun Sep 19, 2021 1:46 pm    Post subject: Re: Stuck in Vegas!! Need brakes! Reply with quote
My el cheapo Auto Zone Everlast pads were gone from new to 1/8” in 4,000 miles!
That is only half the distance my last across the Country trip was!
I carry a spare set of pads for those “Oh crap!” Moments, but never want to actually use them…….
Dave
Ghia
Vanagon
Beetle
Franklinstower
Franklinstower is offline
PostPosted: Sun Sep 19, 2021 2:27 pm    Post subject: Re: Stuck in Vegas!! Need brakes! Reply with quote
Dave
You don't wear out even the cheapest pads in 4'000 miles. You have other issues, like a stuck piston. You know better than that. Jeez
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
djkeev
djkeev is offline
PostPosted: Sun Sep 19, 2021 2:41 pm    Post subject: Re: Stuck in Vegas!! Need brakes! Reply with quote
Franklinstower wrote:
Dave
Sorry but no.
Rotors were new with the pads,
Pistons are good, pivot pins are clean and lubricated, pad slide areas in the caliper are clean, rust free and lubricated.
The amount of black brake dust on both wheels was beyond astounding.
New NAPA pads are wearing much better, just checked them on Friday.
Dave
Ghia
Vanagon
Beetle
Abscate
Abscate is offline
PostPosted: Sun Sep 19, 2021 3:12 pm    Post subject: Re: Stuck in Vegas!! Need brakes! Reply with quote
Dave
You haven’t used URO parts, have you?
.ssS!
Wildthings
PostPosted: Sun Sep 19, 2021 4:39 pm    Post subject: Re: Stuck in Vegas!! Need brakes! Reply with quote
Dave
There is certainly no guaranty of that, especially in these days of COVID related shortages and loss of quality control.
