HELP! 1980 2.0 Aircooled Stuck in CO, won't start
VeeDubn
VeeDubn is offline
PostPosted: Sat Sep 18, 2021 10:27 am    Post subject: HELP! 1980 2.0 Aircooled Stuck in CO, won't start Reply with quote
1980 2.0 aircooled has fuel, spark from coil, checking plugs, cranking, trying to fire, but not quite there - help please.
djkeev
djkeev is offline
PostPosted: Sat Sep 18, 2021 10:49 am    Post subject: Re: HELP! 1980 2.0 Aircooled Stuck in CO won't start Reply with quote
It has fuel in the tank or fuel at the injectors?
Spark at the coil or spark at the plugs?
Dave
Ghia
Vanagon
Beetle
VeeDubn
VeeDubn is offline
PostPosted: Sat Sep 18, 2021 11:02 am    Post subject: Re: HELP! 1980 2.0 Aircooled Stuck in CO won't start Reply with quote
Fuel in the tank - spark at the coil - just changed the plugs cuz they did not look good.
Husband is asking what the fuel pump should read - volts?
Seems like we have fuel, but maybe not getting enough fuel to get the engine running.
Xevin Premium Member
Xevin is offline
PostPosted: Sat Sep 18, 2021 11:25 am    Post subject: Re: HELP! 1980 2.0 Aircooled Stuck in CO won't start Reply with quote
Can you be specific about your engine and ignition set up? All OEM or……something else?
Keep on Busin'
67rustavenger wrote:
Clatter wrote:
skills@eurocarsplus wrote:
Xevin is offline
PostPosted: Sat Sep 18, 2021 11:36 am    Post subject: Re: HELP! 1980 2.0 Aircooled Stuck in CO won't start Reply with quote
I’ll post a link to this in the Bay forum. You might get faster advice on troubleshooting.
Keep on Busin'
SGKent wrote:
pathao
pathao is offline
PostPosted: Sat Sep 18, 2021 11:53 am    Post subject: Re: HELP! 1980 2.0 Aircooled Stuck in CO, won't start Reply with quote
What altitude you're at ?
When we were at Grand Canyon, engine died at a stop sign right in front of shuttle bus. Bus Driver look = not very happy (or helpfull) . My face = sweat like hell because were on an incline going UP (to push it out of the way). When out of the way, cooled out and start thinking. How high are we now !
It would not restart until i play with advance.
After when down in altitude, had to adjust advance.
1982 AC P27 - 2.0 FI FED - 091 - BA6
English is a second language to me
VeeDubn
VeeDubn is offline
PostPosted: Sat Sep 18, 2021 12:40 pm    Post subject: SOLVED! Re: HELP! 1980 2.0 Aircooled Stuck in CO, won't start Reply with quote
Thank you everyone!! We are running Very Happy
Like I told my husband - the down side to an "older" vehicle, is that parts are hard to find; the up side is that the engine is easier to work on.
I believe altitude is partly to blame. We are in Alamosa, Colorado, just outside Great Sand Dunes National Park. Altitude for sure!
We used the starter fluid method which got us running (THANK YOU SAMBA postings). Just by chance, yesterday morning we were camped across the way from Darryl Auch, air-cooled engine builder. He left his card with us (VW owners are the best!) and I held on to it. I left him a message as we were trouble shooting, and although he is on the road traveling himself, he kindly returned my call. Darryl's first question was what is the altitude!
We will be looking into possibly replacing our fuel pump, filter, and whatever the cold start piece is (I just drive Sparky; I am not a mechanic, nor do I play one on TV) when we get home. In the meantime, one HUGE shoutout to Darryl Auch and all of you Samba members who responded to our call for help.
Safe travels - Judy (and John, and Chloe, the doggie)
Wildthings
Wildthings is offline
PostPosted: Sat Sep 18, 2021 3:18 pm    Post subject: Re: HELP! 1980 2.0 Aircooled Stuck in CO, won't start Reply with quote
At altitude these engines when tuned to drive near sea level are known to dump in too much fuel, can't say if that is your problem or not. If it is running to rich to start, a possible solution is to disconnect the wire going to the TS-2 (temperature sensor 2 or TSII) sensor and ground it out, another one is to disconnect the electrical plug from the CSV (cold start valve). You may have to give the engine some throttle as well.
dobryan
dobryan is offline
PostPosted: Sat Sep 18, 2021 3:24 pm    Post subject: Re: HELP! 1980 2.0 Aircooled Stuck in CO, won't start Reply with quote
Glad you are back on the road! Very Happy
Dave O
The Western Syncro build
Yellow Rabbit
Yellow Rabbit is offline
PostPosted: Sat Sep 18, 2021 7:14 pm    Post subject: Re: HELP! 1980 2.0 Aircooled Stuck in CO, won't start Reply with quote
Is it the original fuel injection on has it been converted to carbs? Fuel injection should compensate for altitude I would think. My 1.9 does just fine (just slowly) at altitude.
Wildthings
PostPosted: Sat Sep 18, 2021 10:20 pm    Post subject: Re: HELP! 1980 2.0 Aircooled Stuck in CO, won't start Reply with quote
There is no compensation for altitude during starting, and no compensation once running on the Federal models that lack an O2 sensor. The L-jets and D-jets were notorious for having starting problems at altitude. I worked at a ski area for years and of the hundreds of vehicles in the parking lot these cars and vans were the worst of all for starting.
You can not compare either a Digijet fueled engine or a Digifant fueled engine to an L-jet they are different beasts.
vwwestyman
vwwestyman is offline
PostPosted: Sun Sep 19, 2021 9:25 pm    Post subject: Re: HELP! 1980 2.0 Aircooled Stuck in CO, won't start Reply with quote
I had the pleasure of meeting Judy and John (and Chloe!) on Thursday morning.
They passed through Manhattan and were able to time a stop for when I had an hour without a client. It was a nice visit and they have a pretty Van with a sweet updated interior setup!
Dave Cook
1973 Wild Westerner
My Thing
