nicksny Samba Member
Joined: February 25, 2008 Posts: 91 Location: Kamloops, BC
Posted: Mon Sep 20, 2021 2:00 am Post subject: Need help IDing these heat control boxes I found |
Hey guys, I’m going through my bay window parts horde trying to downsize and sell a bunch of it. I came across these heat control boxes which are different than a standard bus. Pic below… left is a regular bus heat control and right is the one I need help with. The outlet is at a different angle and the lever is in a different spot. I don’t THINK they are 914 ones…. Any help would be appreciated.
_________________ '77 Westfalia Bus
'64 Westfalia Passau Trailer
'03 Passat W8 Sedan 6MT
‘03 Passat W8 Wagon A/T |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51121 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Sep 20, 2021 8:54 am Post subject: Re: Need help IDing these heat control boxes I found |
Most likely 75-79 Beetle. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Sep 21, 2021 12:04 am Post subject: Re: Need help IDing these heat control boxes I found |
busdaddy wrote: |
Most likely 75-79 Beetle. |
From what I can see, the late beetle and bus control boxes are the same… was there a variation? _________________ '77 Westfalia Bus
Posted: Tue Sep 21, 2021 5:56 am Post subject: Re: Need help IDing these heat control boxes I found |
Since the control arm is meant to be pulled from the opposite direction, then that would imply they were for a Porsche 914. The angle of the outlet doesn't appear to be the same though, but maybe Dansk just made a poor "kinda fits" reproduction?
https://www.ebay.com/itm/162420380355?fits=Model%3...%3A2499334
Maybe you have some kind of Zamboni or other VW industrial engine part? |
Posted: Tue Sep 21, 2021 8:43 am Post subject: Re: Need help IDing these heat control boxes I found |
I was thinking the heater cables were on the other sides and lower, like earlier models, apparently Beetle are indeed the same as bus.
But the 914 ones in the classifieds sure look like yours:
Слава Україні! |
