Dual Master Cylinder - Use both brake sensors?
mikelars
mikelars is offline
PostPosted: Mon Sep 20, 2021 5:58 pm    Post subject: Dual Master Cylinder - Use both brake sensors? Reply with quote
I have a 1966 Split, and the master cylinder was upgraded to a dual master cylinder. The brake lights have been wired through the front brakes’ sensor and the rear brake sensor has nothing connected. I recently saw an image where both sensors were used - kind of splitting the 2 wires and having them each split to one prong on each of the sensors on the master cylinder.
Do folks usually use both sensors on a dual master cylinder? I just got a second sensor boot and was going to rig up some wiring to use both, but thought I would ask here if anyone has thoughts on using one vs both sensors…
Here is my 1961 Beetle Restoration:
https://www.youtube.com/playlist?list=PLW_2wBCs4Ny2qXEPvdnfvEzN42T8JA8zO
Here is my 1966 Split Bus - Restoration Channel:
https://youtube.com/channel/UCPBRysmvrJlif2wzwEwiuwQ
2332 Torque Motor Build
https://youtube.com/playlist?list=PLW_2wBCs4Ny2HwsKM9QT4LFpcSqP3QG0p
Engine Rebuild 1968cc Playlist:
https://youtube.com/playlist?list=PLW_2wBCs4Ny1JbZ2EgJQQ2awfo0koZRqz
Mile High Puma
Mile High Puma is offline
PostPosted: Mon Sep 20, 2021 6:55 pm    Post subject: Re: Dual Master Cylinder - Use both brake sensors? Reply with quote
I hooked them both up in parallel, figure if one quits working the other one would be the back up.
1965 Velvet Green DC
NUTSFORBUSES
NUTSFORBUSES is offline
PostPosted: Mon Sep 20, 2021 8:26 pm    Post subject: Re: Dual Master Cylinder - Use both brake sensors? Reply with quote
Mine only has One sensor
Haven't seen a dual sensor MC, maybe 66 is different?
kaiser kills kids.com
BonTonRoulet
BonTonRoulet is offline
PostPosted: Mon Sep 20, 2021 9:06 pm    Post subject: Re: Dual Master Cylinder - Use both brake sensors? Reply with quote
I've got a 66 that I "upgraded" to a 67 dual master cylinder with the 2 brake light switches. I hooked the original brake light wiring to switch connectors to one of them. Left the other one hooked to nothing. Thin air. That way if and when somebody tells me I have no brake lights I'll just swap the wiring over to the other switch and reply "how about now?" Smile
NUTSFORBUSES
PostPosted: Tue Sep 21, 2021 3:11 am    Post subject: Re: Dual Master Cylinder - Use both brake sensors? Reply with quote
Sound advice^
When I up graded to Dual MC for disc, I did notice a "Plugged" hole, this must be another place to use a sensor switch-I use only one. Chip Birks LED set up makes the lights react a bit faster, plus very bright. Harmless either way suppose, but I think the front system would be faster and if you have calipers, no leaky wheel cylinders
2type2
2type2 is offline
PostPosted: Tue Sep 21, 2021 4:16 am    Post subject: Re: Dual Master Cylinder - Use both brake sensors? Reply with quote
When I did my dual circuit conversion, I used the hydraulic switch but also installed an electronic switch at the pedal. Fail Safe brake lights all the way, lights guaranteed.
"A life of peace and happiness depends on your own gratefulness"
Erik G
Erik G is offline
PostPosted: Tue Sep 21, 2021 3:06 pm    Post subject: Re: Dual Master Cylinder - Use both brake sensors? Reply with quote
if you only use one, use the one closest to the bolt flange part. your brake lights will turn on right as you tap on the brake pedal. If you only use the further one, you have some significant lag time before the brake lights turn on.
