Rebel buggy harness vs bug harness vs deluxe bug harness
Page: 1, 2, 3  Next
aircooledmark
aircooledmark is offline
PostPosted: Tue Sep 21, 2021 12:23 pm    Post subject: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
I am on the verge of ordering a wire harness for new Berrien Nostalgia build.
I see some people recommend the Rebel bug harness or deluxe bug harness over the buggy harness.
Any reason why, other than more circuits? I'm stuck... not wanting to spend more money than necessary, but not wanting to make a bad decision on this either!
Pajero
Pajero is offline
PostPosted: Tue Sep 21, 2021 12:37 pm    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
I'd buy the Rebel harness sold by Meyers Manx. It's the 12 circuit bug harness with a flat towing wire breakout already included.
aircooledmark
PostPosted: Tue Sep 21, 2021 12:41 pm    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
Where do I find that one? The Meyers Manx website is kind of a mess to be honest.
The other option I have considered is having Dune Buggy Bros make a harness for me. That's kind of appealing, mainly because I have VERY little VW-based components on my dashboard!
jspbtown
jspbtown is offline
PostPosted: Tue Sep 21, 2021 1:48 pm    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
Just about anything will work. You really want only the number of circuits you need. I think I usually ran 8 (its been a while) but you don't need anything complicated.
A basic wiring harness for a basic dune buggy is super simple.
Whatever you choose just make sure you have a good grounding system. And remember....it is more exposed to the environment than most normal vehicles.
Dale M.
Dale M. is offline
PostPosted: Tue Sep 21, 2021 1:59 pm    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
Problem with those is everything is taped and you have to lay out your "stuff" to fit harness, where a loose (generic) harness allows more freedom as to where you locate fuse blocks and switches and accessories and light fixtures....
No matter what harness you get you will have to add custom wiring and nudge locations of stuff to suit you build...
First thing is to decide what you need... How may light circuits (head lights (Hi/lo) tail lights, parking lamps), turn signal circuits , engine control circuits, accessories.... Then get harness the most closely matches you needs and expect to do modifications....
Also consider a harness that has each wire labeled as to what function it is, it make wiring so much easier.... I did free form from bulk spools and had to label a lot of wires to keep track of where they went and what they connected to... As work progresses tags got removed and any errors had to be traced by wire colors and if you have multiple wires of same colors its takes time....
And the quality if you crimp tool is everything .... Suggest good pair of ratchet crimpers....
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
slayer61
slayer61 is offline
PostPosted: Tue Sep 21, 2021 2:02 pm    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
I will be getting to this point in my build some time next year, so I'm reading up on it now.
I've been an electrician for all of my adult life and I hope to retire soon. Spare wires are like gifts from the Gods! Go with more, because, what does it add to the wiring price right now, $20? $30? What would you pay to already have the spare wires/circuits if your wife sorry California, partner, wanted heated seats? Another set of speakers? Big screen TV with video game player, or some other such accommodation?
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
aircooledmark
PostPosted: Tue Sep 21, 2021 2:08 pm    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
Thank you for the input on that... I get what you're saying! I just gotta get past the intimidating part (you know, getting started!).
I am leaning towards the Rebel harness, it kind of seems to be more suitable for what I am trying to accomplish.
jspbtown
jspbtown is offline
PostPosted: Wed Sep 22, 2021 5:36 am    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
Then I guess you would be far beyond the "basic dune buggy" I referenced Very Happy
So yes...if you plan on future installing speakers there is no room for, or a "big screen TV" that there is no room for then run dozens of extra wires.
Dale M.
Dale M. is offline
PostPosted: Wed Sep 22, 2021 6:02 am    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
The idea of running a few extra wire from the front to back is not a bad idea, I ran a 1 inch soft conduit (plastic) from front to back glassed in under body lip and pulled the necessary wire for lighting and engine electricals into conduit, knowing from experience the problem associates with adding wires to a conduit the is already populated with wire I ran in 3 (of maybe it was 4) extra wires with the thought if I ever go EFI or some exotic ignition there would be a possible the extra wiring I might need.....
20 years later, they are still there bunched up and tape together and still not needed....
Pajero
Pajero is offline
PostPosted: Wed Sep 22, 2021 6:38 am    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
You'd have to call them to get one right now, but it would be worth it. It has a lot of extra length and all the basic parts you'd need. It sure saved me a lot of time and money for the wife's buggy, as opposed to doing my own for the Manxter.
If MM didn't have it, I'd bet you could get it directly from Rebel.
aircooledmark
PostPosted: Wed Sep 22, 2021 6:49 am    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
Thanks for the reply, I'll look into it.
slayer61
slayer61 is offline
PostPosted: Wed Sep 22, 2021 7:27 am    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
Sorry brother. I didn't intend to get your knickers in a wad at all.
I just look at wires as I would any other commodity. I would rather have more and not need it than less and need it. I think the same way about cash, groceries, motorcycles etc. etc.
jspbtown
jspbtown is offline
PostPosted: Wed Sep 22, 2021 8:32 am    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
When I built my Manx I just ran a cord in the factory tube from front to rear.
If someone needed to add the big screen into it later they could easily just use the cord to pull some wires through.
didget69
didget69 is offline
PostPosted: Thu Sep 23, 2021 3:24 am    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
I'll ditto the inclusion of a few extra runs of wire AND the pull cord in the wiring tube...
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
Davz912/911
Davz912/911 is offline
PostPosted: Sat Sep 25, 2021 4:43 pm    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
I just put mine together, I used the Rebel deluxe bug harness. Excellent quality, and super easy to run. It’s real nice they mark the wire every so many inches.
Came with a dedicated tach and oil temp wire... also a 12v feed for a dedicated usb connection.
I recommend it.
aircooledmark
PostPosted: Mon Sep 27, 2021 10:20 am    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
Well, I decided to shoot for the middle of the road and ordered the Rebel Bug harness. It seems to fit my needs the best. I'll update after install!
jspbtown
jspbtown is offline
PostPosted: Mon Sep 27, 2021 1:08 pm    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
Make sure you pick up some black ground wire. You will need a bunch depending on how you decide to run your grounds.
aircooledmark
PostPosted: Fri Oct 01, 2021 9:49 am    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
Arrived yesterday... Rebel Bug Harness. Very nice quality. One thing to note!
Their web site says it comes wired with a 3-terminal flasher. That's not true - it's a 2-terminal flasher. I'll be returning the 3-terminal LED flasher I ordered.
Other than that... It looks like it will do the job for me. I have a bunch of ground wire on order as well as a couple terminal busses.
I probably won't actually start wiring for another week or two - I still gotta paint the frame!
JMCFAN
JMCFAN is offline
PostPosted: Sat Oct 02, 2021 7:42 am    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
Which one did you order? I ordered the basic harness from Appletree...had not seen these...look much nicer...dang it...
aircooledmark
PostPosted: Sat Oct 02, 2021 7:47 am    Post subject: Re: Rebel buggy harness vs bug harness vs deluxe bug harness Reply with quote
This is the Rebel Wire Bug harness. Yea, it’s a very nice harness for sure.
Page: 1, 2, 3  Next
