GreenZoomBug Samba Member
Joined: September 19, 2021 Posts: 45 Location: Over the Hill
Posted: Tue Sep 21, 2021 12:32 pm Post subject: Father/Daughter Baja Project |
Hi Everyone, new guy here, l just bought a 67 Baja Bug for a Dad/Daughter project. First thing is the accelerator peddle and the carb. I think l need to replace the complete peddle assembly and cable, Second thing is the oil cooler, would it be a good place to center it inside the back cage ?
Last edited by GreenZoomBug on Wed Sep 22, 2021 12:39 am; edited 1 time in total |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Posted: Wed Sep 22, 2021 12:46 am Post subject: Re: Father/Daughter Baja Bug Project |
Thanks Matthew, good thought. I'm missing some engine shrouds but l think l have a lead on some. That oil cooler needs to be moved but where ? I'm thinking mounted to the center inside cage. |
slayer61 Samba Member
Posted: Wed Sep 22, 2021 6:39 am Post subject: Re: Father/Daughter Baja Project |
It's not for everybody, but on a baja, I always thought it worked well in a scoop over the rear passenger section
ETA Welcome to the Samba & good luck with your father/daughter project. Looks like you have a good start. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9654 Location: Pearl River, NY
Posted: Wed Sep 22, 2021 6:19 pm Post subject: Re: Father/Daughter Baja Project |
Nice going with the Baja. Is your daughter still young so that she will be driving it when she's old enough? Or is she somewhat older and just wants something different to drive?
That external oil cooler is huge! Since your engine is a dual-port which would originally have the efficient "doghouse" oil cooler and fan shroud, you could consider to get rid of that cooler, the adapter, oil lines, etc and go back to the "simple" factory oil cooler.
A stock-design gas pedal (correct spelling) should also last years. |
Posted: Thu Sep 23, 2021 12:01 am Post subject: Re: Father/Daughter Baja Project |
Cool Bug, but it's more work than l want to get into
slayer61 wrote: |
Posted: Thu Sep 23, 2021 12:38 am Post subject: Re: Father/Daughter Baja Project |
I'm inclined to agree with you. The previous owner stripped off some of the cooling shrouds that I've got a lead on replacing. Another thing that Bugs me 😃 is the short trunk lid leaving my engine more exposed than l like. I live on the "Wet Coast" so that's a concern for me. My garage already has a "Princess" living in there so the Poor Little Bug has to live outside. I don't know how l could extend the engine cover the way my fenders are without looking goofy. My daughter is in her 30's but we have very similar interests and she just likes hanging out with me.
Rome wrote: |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Thu Sep 23, 2021 4:57 am Post subject: Re: Father/Daughter Baja Project |
Hate to be that guy! But, the car is a later than 67 model.
A 67 VIN starts with 117. I betting yours starts with 118 or 119. Meaning it could be a 68 or 69.
Another give away on the year is the for lug wheels. Those came into play starting in 68.
Look at the rear axles and see if they are swing axle or IRS. Swing axle will be inside tubes. IRS will be exposed with CV joints.
A 67 has a thumb button on the door handles. Your are trigger type that you squeeze with your index finger to open the door.
My long gone BAJA lived outdoors. And had far less engine coverage than your car. Don't sweat it.
There's more, but I don't have time to get to all the details right now.
Have fun. And welcome to the samba. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Rome Samba Member
Posted: Thu Sep 23, 2021 2:11 pm Post subject: Re: Father/Daughter Baja Project |
Quote: |
I don't know how l could extend the engine cover the way my fenders are without looking goofy |
You could find a bottom-crumpled '68 or '69 Sedan engine lid probably for cheap and cut it across at the same height as where the fenders end at the quarter panel. That would give you a smooth cover several inches longer than what you now have. "Unfortunately" those 2 sturdy pipe braces that go from the firewall to the rear bumper will be in the way, unless you weld a metal "tunnel" onto the engine lid for each of the bumper braces so that the lid tunnels can fit over the braces.
Good points as to many details which point to a '68 - '70 body and chassis, including the large front blinkers that started for '70. Though those are easily installed from a later car. Looks like there is a door lock pull-up stem which would be as of (edit) '67. But the foot-operated high beam switch was last factory-installed thru the '65 model year. Maybe a PO had problems with the steering column blinker/high beam stalk during the nose cutting and simply installed the foot switch?
IRS or swingaxle- could that be an outer CV joint seen outboard of the right exhaust pipe, which would indicate IRS?
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Thu Sep 23, 2021 3:36 pm Post subject: Re: Father/Daughter Baja Project |
The car has no external fuel flap which started with the dimple hole version in 1968.
Whilst it is possible the external flap was welded shut or the front right quarter was replaced so check around there. Quite possible that the body at least is not a post '67. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
Posted: Thu Sep 23, 2021 10:50 pm Post subject: Re: Father/Daughter Baja Project |
I have so much to learn, 😃 |
Posted: Fri Sep 24, 2021 2:06 pm Post subject: Re: Father/Daughter Baja Project |
Guy that l know, said the first 3 Vin numbers says it's a 67 vw. He said the first 1 means Beetle, second he couldn't remember and the 3rd is 7 which is the year and it has IRS. This car was likely a collection of parts, l heard the 67 engine didn't have dual port heads |
Posted: Fri Sep 24, 2021 3:58 pm Post subject: Re: Father/Daughter Baja Project |
GreenZoomBug wrote: |
That would be correct for a USA delivered 67.
Maybe the it just has later tail lights that through me off.
The four lug brake drums are still suspect.
Like so many. It is likely a franckenbug!
Have fun with it. BAJA's are fun!
Please post the pics directly to the samba. Pic sites have a tendency of disappearing from the interwebs. _________________ I have learned over the years.
Buy Once, Cry Once!
cbeck Samba Member
Posted: Fri Sep 24, 2021 6:08 pm Post subject: Re: Father/Daughter Baja Project |
Thought irs did not arrive until 68 auto stick only, and the rest of the type one in 69.
Edit, us spec. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sat Sep 25, 2021 6:55 am Post subject: Re: Father/Daughter Baja Project |
Another not-a-67 item is the floor mounted high beam switch. Looks funny mounted next to the late pedal assembly. Last year for that on US models was 1964.
P.S.
Post the VIN number for better replies.
If you're afraid of security simply XXX the last three numbers. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
