monpe Samba Member
Posted: Tue Sep 21, 2021 10:53 pm Post subject: Vanagon Taller transaxle |
Hello, my ‘86 Vanagon has a GoWesty 2450 engine, 15” rims and I need a new transaxle. Does anyone have any experience with a taller or freeway flier transmission with this engine? I’m worried that I’ll loose too much power going up hill. |
kourt Samba Member
Joined: August 13, 2013 Posts: 1948 Location: Austin, TX
Posted: Wed Sep 22, 2021 3:33 am Post subject: Re: Vanagon Taller transaxle |
Greetings. Nice first post. You waited four years!
Are you talking about an automatic transmission or manual transmission?
Also:
loose (v): to let something loose
lose (v): to fail to win, or to misplace
Both verbs work, but I think you meant the latter.
kourt |
Abscate Samba Member
Posted: Wed Sep 22, 2021 4:19 am Post subject: Re: Vanagon Taller transaxle |
kourt wrote: |
Also:
kourt |
Los…. to fire a torpedo in a German Submarine movie _________________ .ssS! |
DuncanS Samba Member
Posted: Wed Sep 22, 2021 4:36 am Post subject: Re: Vanagon Taller transaxle |
Thanks, kourt. Another fellow English grammar Nazi. Loose of adverbs drives me crazy.
All the feedback I've heard is don't do it. FAS used to recommend a taller 4th gear, but no longer do. In fact a number who have tried it have gone back to the OG 4th. The general consensus seems to be to just add tires with a larger circumference and the effect will happen in all gears. But don't go too much. Inadvertantly, when I went to 16" trims, my 205s have a 4% increase. I wouldn't go over 7%. But others here will know far better than I do. Matching engine RPMs and torque to your highway speeds is the important issue. Not gas mileage. No tranny mod to give better gas mileage will ever have a payback unless you plan to drive the car a million miles. Even then. a VanEgon would be tough to amortize.
I've always lusted after a 5 speed which is probably a better solution. Or maybe just stick in a Porsche complete with a 6 speed.
Duncan |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Wed Sep 22, 2021 5:38 am Post subject: Re: Vanagon Taller transaxle |
I have been running an '87 westy with a subaru 2.5 for over 15 years. I had a transmission built many years ago with a taller third and fourth gear. Stock tire diameter. Hated it. It was great on the flats and mild hills but when I was up in the mountains I'd have to slow down for a curve and would drop out of the power band in fourth and then be stuck in third. No bueno for me. And as mentioned it is not possible to change back without a lot of time and money to regear.
I went back to stock gearing with the next transmission and was very happy with it. Yes, I was going 4000rpm on the highway but the engines are fine with that.
I now am on 215/75/15 BFG KO2s (about 7% over stock tire diameter) on the westy with stock gearing and it works for me since I need the off road capability and love the BFG KO2s. 70mph (GPS verified) is about 3700rpm and while I do lose power the tradeoff works for me. I recently climbed up I70 out of Denver to the Eisenhower tunnel at 11,000 feet and was in forth at 65 most of the way. A couple of times I had to downship to third and went up at 55mph with power to spare.
It is way cheaper to play with drive ratios by swapping out tires until you get what you want. You can always sell off the lightly used tires to recoup 50% of their initial cost. My advice is to play with tires, not transmission gearing.
YMMV. _________________ Dave O
The Western Syncro build
9.5isCanadian Samba Member
Joined: September 16, 2017 Posts: 465 Location: In your blind spot.
Posted: Wed Sep 22, 2021 7:14 am Post subject: Re: Vanagon Taller transaxle |
dobryan wrote: |
SNIP
SNIP
I had the exact same result on this identical set up on my 87 High top
Agree on both points.
9 1/2 _________________ 9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi |
space Samba Member
Posted: Wed Sep 22, 2021 7:15 am Post subject: Re: Vanagon Taller transaxle |
I went Taller 4th, stock 3rd w 16's
Mountains do present a problem for 4th
I have no problem doing 45ish in the right lane in 3rd letting the Amish buckboard pass me by _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
valvecovergasket Samba Member
Posted: Wed Sep 22, 2021 7:21 am Post subject: Re: Vanagon Taller transaxle |
dobryan wrote: |
It is way cheaper to play with drive ratios by swapping out tires until you get what you want. |
and its even cheaper to do so with a nice plotting tool like this:
https://www.blocklayer.com/rpm-gear.aspx
if you have the dyno for your engine, or something roughly resembling the curve, you can play with the options there to see where the taller gearing might put you on the curve when you move into the next gear. so you know what rpm to avoid.
sample from some gearing ideas i was playing with on my tdi but you get the idea
_________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
monpe Samba Member
Posted: Wed Sep 22, 2021 6:40 pm Post subject: Re: Vanagon Taller transaxle |
Awesome advice from everyone! Sorry about the earlier grammar. Hearing the voices of reason I’ll stick to the regular, non freeway flier transaxle and play with the tires. Thanks |
monpe Samba Member
Posted: Wed Sep 22, 2021 7:02 pm Post subject: Re: Vanagon Taller transaxle |
Forgot to answer- manual transmission.
Thanks again,
‘86 Westy ( Der Flea )
‘01 Eurovan GL
‘17 GTI |
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Wed Sep 22, 2021 8:49 pm Post subject: Re: Vanagon Taller transaxle |
you have to figure out your torque curve to make sense of it all.
apples and oranges here...but...
when i did my subaru swap in my bay window i used a 091 from the get go because the 002 had miserable gearing.
with the 091 i would be on the highway and literally clutch it to shift into the non existent 5th.
the solution was a built box with a different r+p plus a taller 3rd and 4th.
i am happy with it.
thing is, you need to "re train" yourself in driving it. i'm in 3rd mostly around town, no problems. i can run 3rd up to about 85 if i have to.
biggest issue is people tend to "over shift" or upshift too early. if you get the numbers right...all of them...tire size, r+p etc and be mindful of the gear spread it is possible to pull it off.
it's all in the combo. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
