jlinares Samba Member
Joined: June 30, 2018 Posts: 71 Location: Distrito Capital de Bogotá
Posted: Thu Sep 23, 2021 6:51 am Post subject: Engine |
VIN: 10221144 and engine number 10266806
According to thesamba numbers, this car is December 1950, although in every document here in Colombia, it is listed as 1949. I want to know what is the original engine for it, it has some things that don't belong. The most obvious is the oil cleaner, as it is clearly made by the owner. It also has a much bigger carburetor than it should have. My question is, this engine is 25hp? 1100cc?
should it look like this?
I am looking to restore it as it came from the fabric. |
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Thu Sep 23, 2021 7:36 am Post subject: Re: Engine |
don't both those numbers indicate a January 1951 car? numbers in the chart are the last produced for the month. _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Thu Sep 23, 2021 7:49 am Post subject: Re: Engine |
it appears to be early jan. 51 the last 50 in dec. is 1-0220133 .
when you look at the samba list the last # is the last one built that month .
the engine # is also jan. 51 . with later 36hp parts. the good is
it looks to be the original engine case. the bad is I has a bunch of hard to
find 25hp parts missing.$$$ yes the bottom pic is a correct 25hp. 1100cc.
yours may have been built into a 36hp 1200cc at some point . as the piston/cyl
and heads for a 1200cc 36hp are plentiful. carb is a manual choke 30pic.
last 1949 beetle built is # 1-0138544 . your Colombia documents are off. IMO
tail lights are 50-52. I think the car is a 51 by the looks of it.
Steve. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Thu Sep 23, 2021 2:57 pm Post subject: Re: Engine |
i'd run that (more efficient and improved) oil-bath air cleaner and use the (less efficient) T-air-cleaner at shows - that's what I did - looks like a clean 36 horse - hot here to pick you apart... pretty car that was updated, as needed.
Your car says it's a '49 - few are gunna' know the difference - z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
