OBD1 2.2 to OBD2 2.5 Subaru swap - anyone done it?
Mikesarge
Mikesarge is offline
PostPosted: Thu Sep 23, 2021 6:09 pm    Post subject: OBD1 2.2 to OBD2 2.5 Subaru swap - anyone done it? Reply with quote
So, in my quest for ever more mid-range torque, I’ve come to a couple of conclusions regarding my early ej22.
1- I can cobble together a turbo kit for this with stuff I have sitting around. It’ll sound cool, probably be pretty torquey, but reliability will become an issue. Not ideal.
2- I can frankenmotor this thing. Not a perfect solution either, as it’s still a shade tree hacky sort of solution, and it seems like the power is higher up in the revs for these too. I need torque in the middle!
3- I can swap in a later, more powerful dual port engine and harness, reusing all of the hardware currently on this thing.
3 seems like the best solution, but for the fact that I bought this with the swap, and all of the guides for wiring are for adapting a stock harness to a subaru, not for updating the Subaru setup.
Has anyone done this? Can you provide me some guidance, and prevent me from turbocharging my current setup?
1986 Syncro westfauxlia EJ22
1980 911 SC 3.1
skills@eurocarsplus
Samba Peckerhead
PostPosted: Thu Sep 23, 2021 6:37 pm    Post subject: Re: OBD1 2.2 to OBD2 2.5 Subaru swap - anyone done it? Reply with quote
the only thing you may have to change other then the harness is the exhaust (single port vs dual)
i'd go 2.5 with a set of cams. would be the most bang for the buck
i built my 70 deluxe with a frankenmotor and cams. pulls like a ox on meth. but, it was a pain to build. heads CC'd to drop compression, custom head gaskets etc and it's running the 2.2 management which is fine, except for the million dollar coolant fed IAC valve.
i think you'd be money ahead with the 2.5 and some cams.
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Silverghost500
Silverghost500 is offline
PostPosted: Sat Sep 25, 2021 9:24 am    Post subject: Re: OBD1 2.2 to OBD2 2.5 Subaru swap - anyone done it? Reply with quote
@skills, what cams are you running in your 2.5's?
1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A converversion-Road Testing Phase
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA
