djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32598 Location: Reading Pennsylvania
RBEmerson Samba Member
Joined: November 05, 2011 Posts: 2108 Location: SE PA
Posted: Fri Sep 24, 2021 12:01 pm Post subject: Re: Stuck in Welcome NV - No start - 90 Westy |
Bingo - it's only a bit of ECU slight of hand, and not reality. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Posted: Sat Sep 25, 2021 4:21 pm Post subject: Re: Stuck in Welcome NV - No start - 90 Westy (SOLVED) |
Two hundred plus miles including high Nevada desert, Reno traffic (insane!), and 7100' Spooner Summit
All is very well. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Posted: Sun Sep 26, 2021 8:13 am Post subject: Re: Stuck in Welcome NV - No start - 90 Westy (SOLVED) |
We put the old pump outside last night, hoping more of the smell of gas will dissipate. We're in black bear country, so we hope the smell discourages the bears. ;)
Yes, we'll keep it. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
SyncroHead Samba Member
Joined: May 23, 2005 Posts: 1141 Location: Northern Nevada
Posted: Sun Sep 26, 2021 8:44 pm Post subject: Re: Stuck in Welcome NV - No start - 90 Westy |
SyncroHead wrote: |
RBEmerson wrote: |
Good news / bad news
I have a ScanGauge (from GW), and it shows the fuel pressure. According to the ScanGauge, the system's pressurized to 70 psi. Or, the pump's working. Too bad the motor isn't.
About the only loose end is where is the pressure being read? This is the GW EFI, BTW. |
As far as I know there is no fuel pressure sensor, so the ScanGauge can't display fuel pressure. Did you install a fuel pressure sensor with the GW EFI? I didn't install a fuel pressure sensor in mine and do not know of any reference to this possibility, nor any wires to attach to a fuel pressure sensor.
Fuel pressure sensor is not in the GW parts list, nor in their wiring diagram.
Also, fuel pressure shouldn't be anywhere near 70psi. More like high 30s psi.
I don't know how, but I'm questioning the idea that your ScanGauge is displaying fuel pressure. You apparently have "70 something", but I can't guess what.
Jim Davis |
RBEmerson,
Still curious about why you thought the ScanGauge was showing you 70 for "Fuel Pressure". Did you ever circle back to figure out what this 70 actually is?
Jim Davis _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote: |
I have *no* idea what the previous owner carried in his Westy... angry donkeys? |
Posted: Sun Sep 26, 2021 8:57 pm Post subject: Re: Stuck in Welcome NV - No start - 90 Westy (SOLVED) |
I did. It's a fixed value, used to keep ECU code happy. I have the GW EFI, and asked the designer about the number. Even if the vehicle was bone dry, the ScanGauge would show 70.4 psi. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
danfromsyr Samba Member
Posted: Sun Sep 26, 2021 8:58 pm Post subject: Re: Stuck in Welcome NV - No start - 90 Westy (SOLVED) |
buy a pack of ziploc FREEZER bags... I think a Qt bag will hold it. but we ALWAYS carry a buncha Gallong ziploc freezer bags..
drop a few paper towels in there and double bag it. _________________
Abscate wrote: |
Posted: Sun Sep 26, 2021 9:09 pm Post subject: Re: Stuck in Welcome NV - No start - 90 Westy (SOLVED) |
Hmmm... I like the idea. We carry ZipLoc bags and blue shop towels. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Posted: Mon Sep 27, 2021 8:35 pm Post subject: Re: Stuck in Welcome NV - No start - 90 Westy (SOLVED) |
I like the idea, but it's a challenge when traveling from one state or national park to the next. :) _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Posted: Mon Sep 27, 2021 8:44 pm Post subject: Re: Stuck in Welcome NV - No start - 90 Westy (SOLVED) |
don't feel so alone.
I've personally changed 3 fuel pumps on the side of the road on cross country travels in 3 different vans.. one was a New pump that was preventatively changed that failed.
add in another friend who had to have a TAXI (before uber) pick up and deliver a fuel pump to him on his road trip because he was 35miles to (and back) from the nearest town..
there are soo many other things that can go awry.. just had mom's van have it's engine harness burn out the IGN wires. hows your power steering switch wires looking?
it's all in the challenge, the 'sense of adventure'
yeah right... _________________
Abscate wrote: |
Posted: Mon Sep 27, 2021 8:51 pm Post subject: Re: Stuck in Welcome NV - No start - 90 Westy (SOLVED) |
Fuel pumps get changed when they demand it.
My point was "mothballing" a pump can be difficult with limited resources, in places not noted for putting up with automotive repair activity. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
Posted: Tue Sep 28, 2021 9:58 am Post subject: Re: Stuck in Welcome NV - No start - 90 Westy (SOLVED) |
RBEmerson wrote: |
I did. It's a fixed value, used to keep ECU code happy. I have the GW EFI, and asked the designer about the number. Even if the vehicle was bone dry, the ScanGauge would show 70.4 psi. |
Thanks!
Jim _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.Vanagons.org
sphet wrote: |
Posted: Tue Sep 28, 2021 10:01 am Post subject: Re: Stuck in Welcome NV - No start - 90 Westy (SOLVED) |
Da nada. _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
