74 Thing Samba Member
Posted: Fri Sep 24, 2021 12:59 am Post subject: Bushings do not fit "tight" in IRS outer spring plate caps |
How tight are new bushings supposed to fit in the IRS outer spring plate caps?
I would think tight with no side to side play when you insert the bushing into the cap, but there is a slight movement in mine (maybe 1/16-1/8").
Is this normal or are the bushings maybe smaller in dimensions than they should be or maybe there is wear in the cap over the years.
Thanks
https://www.thesamba.com/vw/gallery/pix/2160917.jpg
bhartwell59 Samba Member
Joined: December 28, 2014 Posts: 792 Location: dallas, tx
Posted: Fri Sep 24, 2021 5:56 am Post subject: Re: Bushings do not fit "tight" in IRS outer spring plate caps |
When I replaced mine... they were so tight that I needed longer bolts to tighten the spring plate caps down. _________________ '74 Zambezi green Ghia vert, autostick, 101k
'87 Jeep Wrangler, 4.2, 330k |
Posted: Fri Sep 24, 2021 8:50 am Post subject: Re: Bushings do not fit "tight" in IRS outer spring plate caps |
bhartwell59 wrote: |
When I replaced mine... they were so tight that I needed longer bolts to tighten the spring plate caps down. |
Yes, that is what I have to do when I install mine as well. Use two longer bolts to draw everything in then add the stock bolts.
I am describing that when you take the cap and put it in your hand and then set the bushing inside the cap when you are holding it to check for fitment it is not a snug fit as I would expect. Neither the used rubber OEM ones or the new delrin Saco bushings I have in my possession fit snuggly. That makes me wonder if they should be snug or the bushings may be undersized or the cap may be worn, |
MuzzcoVW Samba Member
Joined: February 21, 2018 Posts: 1475 Location: Westfield, MA.
Posted: Fri Sep 24, 2021 9:02 am Post subject: Re: Bushings do not fit "tight" in IRS outer spring plate caps |
A little tip that isn't always explained and can cause a huge headache if you don't figure it out first. Install the plate with the longer bolts BEFORE you pry the spring plate back up onto the stop. If you don't the bolt holes will not line up. |
raydog Samba Member
Joined: February 09, 2006 Posts: 1163 Location: Cape Cod
Posted: Fri Sep 24, 2021 9:16 am Post subject: Re: Bushings do not fit "tight" in IRS outer spring plate caps |
Don't over think it. The cover can't wear out. What you are describing with the relationship between bushing and cover sounds normal. When you get it tightened down, the bushing gets compressed inside the cover. _________________ Come on, It's not rocket science. KISS |
Posted: Fri Sep 24, 2021 10:57 am Post subject: Re: Bushings do not fit "tight" in IRS outer spring plate caps |
But if you are usling delrin or urethane I don't think there is any compression and depending on the durometer reading on the OEM bushing there may be limited squish.
The shiny marks inside the end cap cover shows some slippage.
Yes, maybe I am overthinking things.
I was just wondering what others experiences have been or if it is just normal. |
Tvättbjörn Samba Member
Posted: Fri Sep 24, 2021 4:14 pm Post subject: Re: Bushings do not fit "tight" in IRS outer spring plate caps |
Every single bushing I installed had no play when i put it in the cover. Always used NOS VW bushing. I have also seen just round rings for the cover, but than the cover has a ring in it to seat the ring firm. I never used Urethane bushing .
Post a picture of what you have. |
Posted: Fri Sep 24, 2021 8:51 pm Post subject: Re: Bushings do not fit "tight" in IRS outer spring plate caps |
I already installed what I have so no photo unfortunately.
Where are you finding NOS bushings? I have the inner knobby ones, but I need a set of the outer round ones 1 7/8".
I thought Wolfsburg West had good durometer stock like bushings, but I did not find them on their site.
Part 111511245E
Posted: Sun Sep 26, 2021 8:24 pm Post subject: Re: Bushings do not fit "tight" in IRS outer spring plate caps |
One thing to remember. The rubber bushing goes usually on tight onto the spring plate shaft. It will open up the bushing a bit. Maybe that is enough to make it sit tight in the cover.
I used tire mounting paste on the bushing to install it onto the spring plate. |
