Valve guides
[email protected]
JERRY63VW@YAHOO.COM is offline
PostPosted: Fri Sep 24, 2021 2:46 pm    Post subject: Valve guides Reply with quote
Would cast iron valve guides be a good thing or a bad idea ...
petrol punk
petrol punk is offline
PostPosted: Fri Sep 24, 2021 2:49 pm    Post subject: Re: Valve guides Reply with quote
Aluminum has a thermal expansion coefficient of ~13, bronze roughly ~10, and cast iron about ~6. So I think there would be cause for concern that the valve guides might loosen up at high head temps.
36hp '56 European DeLuxe oval, '70 bug 1835cc dual 36DRLA, and a '98 4x4 5spd single cab Tacoma
[email protected]
PostPosted: Fri Sep 24, 2021 3:12 pm    Post subject: Re: Valve guides Reply with quote
I notice on my honda 400t cylinder heads had 3 valves per cylinder and used cast iron valve guides...so I was just curious if they could be done to a 36hp head ...it was just a thought ...bored in life right now ..to much thinking you can say lol ...
AirCooledClassics
AirCooledClassics is offline
PostPosted: Sun Sep 26, 2021 8:21 pm    Post subject: Re: Valve guides Reply with quote
Cast guide work fine but they are a pain in the ass to remove.
2010 Bonneville record holder Type 2, 36hp
NHRA Divisional Sports Compact Champion
My You-tube video
http://www.youtube.com/watch?v=GJoq3MtsPmc
My National Dragster article
http://www.dragracecentral.com/DRCStory.asp?ID=231552
[email protected]
PostPosted: Sun Sep 26, 2021 8:23 pm    Post subject: Re: Valve guides Reply with quote
I heard they last way way longer than a bronze ones for street use but not so good for racing motors ....
RWK
RWK is offline
PostPosted: Mon Sep 27, 2021 5:13 am    Post subject: Re: Valve guides Reply with quote
Your Honda guides are most likely powdered or sintered metal, all kinds of thing are made this way now, very accurate and needs little machining after it is made (pressed).
I would stick with a good alum. or tin bronze for valve guides.
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
RWK
RWK is offline
PostPosted: Mon Sep 27, 2021 5:41 am    Post subject: Re: Valve guides Reply with quote
Also on a side note, IMHO some after market heads have brass valve guides, I assume because of cost and ease of machining, see pic, about 90% certain these heads have brass guides, see also stock replacement guide and good grade of bronze bar stock I make guides from. Brass has a machinability rating of over a 100% compared with the steel standard, bronze's range from 20% to 80%.
Point is that most anything will work, just how long it last's is the key.
73 Type 181
63 Type 113
gears
gears is offline
PostPosted: Tue Oct 19, 2021 4:17 pm    Post subject: Re: Valve guides Reply with quote
VW cast iron guides were distributed to shops in the early '70s (EMPI), both 36hp and 40hp style. I still have a few 36 somewhere.
aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com
RWK
RWK is offline
PostPosted: Wed Oct 20, 2021 5:35 am    Post subject: Re: Valve guides Reply with quote
Here's some pics of some cast iron guides, 10mm OD 7mm ID, the drawer they are in is marked
111-101-417-B-C1 I didn't mark them so not sure of accuracy.
73 Type 181
63 Type 113
[email protected]
PostPosted: Wed Oct 20, 2021 1:16 pm    Post subject: Re: Valve guides Reply with quote
Nice ....yeah I knew I seen some heads with them in the past but thought my eyes were playing with me ...and was thinking what would be the down side of them ..all I know by what I've read is that cast iron valve guides last longer for a street engine/use but not good for racing engines and bronze ones are good for racing so they have there up and downs ....
