Which Engine? |
Another TDI? |
16% |
[ 4 ] |
Some other VAG gas engine (make suggestion) |
12% |
[ 3 ] |
"Subaru the Hell of it!" |
70% |
[ 17 ] |
Total Votes : 24 |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Sat Sep 25, 2021 6:53 am Post subject: Help Me Pick My New Engine |
As you may have seen, my TDI engine has died. Again... This conversion has now had 3 engines in it, plus a rebuilt head on one of those engines. And two rebuilt transmissions, all since 2013.
Considering going a different direction.
Here's what I'm thinking about, and what I see as pros/cons. I'd love to hear your thoughts on all this. Going back to an aircooled motor is essentially out of the question for a variety of reasons.
Throw in another TDI motor.
Pro: everything is set up and it would quite literally bolt right in and the wires would plug right in. And the transmission is geared for it. Would be the quickest and easiest way to get an engine in there and get it driving again.
Con: While theoretically the new transmission is stronger, at this point I don't know if it'll be possible for me to drive without always being on edge. Always worrying about the diesel engine pounding on the transmission. Plus it has been annoyingly loud. And all the ancillary things ( e.g. the intercooler setup) were more complicated than I figured and still aren't "right."
Some VAG gas engine.
Pro: Just about any of them would bolt right in, also. Theoretically it should be less worrisome with regards to smoothness and transmission pounding. Something like a late 90s 2.0 would be fairly easy to get in there and get the wiring set up. A non-turbo motor would require less extra "stuff" to get running. Seems like it would be quieter than a TDI motor.
Con: The current transmission gearing may not match one of these motors; they typically want to rev up a bit more. Other wiring changes to go from diesel to gas. Potentially less torque/power. If I wanted something like a 1.8T, I'd still have to worry about things like the intercooler system.
A Subaru motor.
Pro: Plenty of people have done it. They at least appear to be clean and simple when comparing to my TDI. Everybody says they have good power. Like a VAG gasser, less worry about pounding on the transmission. Some of my current work would still transfer, such as cooling system and heater system. Maybe I can sell some of the Mexican Bus stuff I used. (See con section.) Should also be quieter than TDI.
Con: Biggest one I see is a lot of the current work doesn't transfer as much. E.g. I'd probably have to swap the old bellhousing and associated parts back on, as it's probably easier to find adapter plates and such for the stock bus transmission. (Could possibly sell the Mexican stuff.) I also am not sure about how well the current trans gearing will work. I don't yet "speak" Subaru. _________________ Dave Cook
1973 Wild Westerner
My Thing
consvws Samba Member
Joined: April 07, 2009 Posts: 950 Location: Roseburg, OR
Joined: August 31, 2013 Posts: 12854 Location: North Carolina
Posted: Sat Sep 25, 2021 7:41 am Post subject: Re: Help Me Pick My New Engine |
If you decide to go Subaru, I’d be able interested in the trans… and I gots a new Small Car Subaru header & throttle linkage conversion bits. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
cmonSTART Samba Member
Posted: Sat Sep 25, 2021 8:43 am Post subject: Re: Help Me Pick My New Engine |
2JZ
_________________ '78 Bus 2.0FI
de K1IGS |
Joined: January 01, 2007 Posts: 16878 Location: sticksville, ct.
Posted: Sat Sep 25, 2021 9:01 am Post subject: Re: Help Me Pick My New Engine |
vwwestyman wrote: |
what's the definition of insanity? doing the same thing over and expecting different results....
either you have the worst luck in the world or you and TDI's don't get along.
honestly, only you can answer this question. i didn't run the math but i'm willing to bet your trans will hate anything not TDI and the gearing will be very poor at best.
if you do away with the diesel you need another trans, no doubt. so it really comes down to how much you want to recycle into a VAG gasser.
doing anything from the 80's-90's VAG line up will give you blah performance. even an ABA is only 115 horse. not worth it.
2.5 subaru is 165/170 out of the gate. fits and are plentiful.
not sure what MPG's you are chasing but this is from a guy i did a swap for:
granted, his is a tin top and he drives like an old lady (even his wife busts his balls about it )
they usually ride heavy, as they camp in it.
my experience has been 22-24 mpg no matter how i drive mine....which is usually with my foot buried to the floor because it's fun to drive a slow car fast.
i have a good friend in NM who is forever dicking with his TDI in his vanagon. they just seem to be needy little bitches but somehow people justify that and the expense.
sounds to me like you have some soul searching to do. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
crownline Samba Member
Joined: September 10, 2010 Posts: 593 Location: Northwoods of WI
Posted: Sat Sep 25, 2021 11:58 am Post subject: Re: Help Me Pick My New Engine |
"As you may have seen, my TDI engine has died. Again... This conversion has now had 3 engines in it"
Your above quote says it all. You could try for 4 TDI engines.
My vote is listen to skillz "Subaru and be done." _________________ 1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL] |
Xevin Samba Member
Posted: Sat Sep 25, 2021 12:51 pm Post subject: Re: Help Me Pick My New Engine |
In your bus. Whatever fits your budget, gets you rolling, and doesn’t take away from family time. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Sun Sep 26, 2021 7:11 am Post subject: Re: Help Me Pick My New Engine |
I'll try to address several comments.
I think I'm leaning toward Subaru as of this moment. Even if I *should* be able to make a TDI engine work, Skills was dead on with the definition of crazy comment. If nothing else, it does feel crazy to try to keep going on the TDI train.
Just yesterday I was at a car show and talked to someone I hadn't seen in a few years. He asked about the TDI bus and said I'd maybe inspired him! Has a Bus that needs an engine and his nice 2002 Golf was obliterated by baseball size hail this past spring. I told him that it does seem like one should be able to be made to work, but at this point I think I'm kinda traumatized by the whole thing. Even when that thing was running well, I was always eyeing the gauges and worrying about my transmission.
By contrast, we drove the '73 (with AC Vanagon engine, 091 trans, and late bay FI) to the car show and took the interstate there. That thing drove 70-75 no problem and felt kind of relaxing.
Some of the difficulties with this conversion are certainly related to mistakes I made (and could have been prevented) and some is bad luck.
The only real reason for considering a gasser VAG engine would be easy bolt-in. After seeing Skills comment, I looked up the specs for an ABA... The torques are quite a bit lower than the TDI, and at much higher RPMS. So I think that is out.
If I were to run across another TDI motor fairly easily/a good deal I'd probably go ahead and do that simply because of the ability to swap it in with as little difficulty possible.
Otherwise, I think I'm interested in trying a Subaru out. I've already figured that whenever the engine in the '73 wears out, it would probably get a Subaru.
But whatever I get, it'll probably be a while. Gotta save up the cash for the new engine. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Sun Sep 26, 2021 9:00 am Post subject: Re: Help Me Pick My New Engine |
i'll have to look
i was having benco do my first 5 or so transmissions but found matt steedle who is in NJ, so way closer
benco was doing a taller 3+4 which i liked, but matt ran some numbers and came up with a totally different R+P that equalized the gear spread.
i like both, for different reasons.
with the taller 3+4 it is more fun to drive and 3rd is used pretty much around town. i can run 3rd up to 85/90 before i shift to 4th
matts trans is kind of the same, but with the R+P the gear spread is a bit better, you can run ALL of the gears longer.
the benco trans is like having a close ration GTI trans for the first few gears. in the end, both of them cruise at the same RPM's on the highway _________________
Jake Raby wrote: |
Brian wrote: |
SGKent Samba Member
Posted: Sun Sep 26, 2021 9:34 am Post subject: Re: Help Me Pick My New Engine |
If you want to run a more modern engine, I think you will have to go thru the whole conversion again, re-engineering the weak spots that have failed on you, if you want to avoid having the same failures again. Try to go with a zero mile engine if you can rather than a high mileage one. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Sun Sep 26, 2021 11:36 am Post subject: Re: Help Me Pick My New Engine |
Whatever gets you back on the road fastest. Time spent with kids in Bus is added to the Creators’ allotted end time _________________ .ssS! |
Posted: Sun Sep 26, 2021 12:30 pm Post subject: Re: Help Me Pick My New Engine |
i'll have to look
the benco trans is like having a close ration GTI trans for the first few gears. in the end, both of them cruise at the same RPM's on the highway |
If you could check when you get a chance, I'd appreciate it.
Far as I know, there are only two R/Ps out there, stock and 4.13, which I have. _________________ Dave Cook
1973 Wild Westerner
My Thing |
SGKent Samba Member
Posted: Sun Sep 26, 2021 1:02 pm Post subject: Re: Help Me Pick My New Engine |
i'll have to look
Isn’t this how it should be done? It’s how Arizona Transaxle does it and the way I learned. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Sun Sep 26, 2021 1:27 pm Post subject: Re: Help Me Pick My New Engine |
it should be done to match the torque curve of your engine.
a subaru likes 3-3200 rpm @72-75 mph
an aircooled needs more to keep the fan speed up. you'd be at 4-4200 at those speeds in an aircooled
i did my 70 with a stock 091 and in 4th on the highway i kept looking for 5th. no need to keep the subaru on boil like that.
also consider your tire size. makes a big difference on which way to go _________________
Jake Raby wrote: |
Brian wrote: |
Cap10323 Samba Member
Posted: Sun Sep 26, 2021 9:32 pm Post subject: Re: Help Me Pick My New Engine |
IMO, If you're not going with a Type 4 Aircooled, Subaru is the only solution. _________________ -Ian
'77 Westfalia - 2.0 F.I |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Mon Sep 27, 2021 7:58 am Post subject: Re: Help Me Pick My New Engine |
There is another option: Go electric _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
