vw_bud Samba Member
Joined: March 23, 2008 Posts: 265 Location: Bradford, PA
Posted: Sat Sep 25, 2021 4:29 pm Post subject: Distributor drive gear difference? |
Hey guys I have to ask as my 75 bus' distributor will not stay timed like it's kinda wobbly so I am going to replace everything because I already have the parts. Anyways is the type 1 engine and type 4 engine distributor drive shaft the same? |
Posted: Sat Sep 25, 2021 6:00 pm Post subject: Re: Distributor drive gear difference? |
The cog on the bottom of the shaft is supposed to be wobbly. If your hold down clamp is bent to crap you might not be able to get sufficient pressure against the distributor body to keep it from turning. How are you setting the timing? It is best to set it at 28° BTDC @ 3800+ rpms, with the hose(s) removed and plugged. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Sat Sep 25, 2021 6:51 pm Post subject: Re: Distributor drive gear difference? |
vw_bud wrote: |
The are different.
Type 4
Type 1
_________________ Glenn
Member #1009
#BlueSquare |
vw_bud Samba Member
Posted: Sat Sep 25, 2021 9:36 pm Post subject: Re: Distributor drive gear difference? |
Thanks guys and the timing keeps jumping from 12btdc to 0 and back and forth and there is no crank endplay so I'm totally confused |
SGKent Samba Member
Posted: Sat Sep 25, 2021 9:56 pm Post subject: Re: Distributor drive gear difference? |
vw_bud wrote: |
try another timing light. If it continues be sure you have a spring between the distributor and gear. ALSO, if your idle is too high, say close to 900 - 1000 Rpm, you may b seeing the distributor mechanical advance kick in and out. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Sep 25, 2021 10:02 pm Post subject: Re: Distributor drive gear difference? |
There are thrust washers both between the drive cog and the body of the distributor and inside the distributor body. When they fail and disappear (which is common) the distributor shaft can move up and down as can the distributor drive. This will cause a major scatter of the timing. |
