ourv12 Samba Member
Joined: November 30, 2006 Posts: 492 Location: Great SouthWest Michigan
Posted: Sat Sep 25, 2021 7:46 pm Post subject: Thread size for the oxygen sensor |
Anyone know the thread size for the oxygen sensor on the vanagon catalytic converter? I need to chase the threads , thanks |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4717 Location: Bemidji, MN
Posted: Sat Sep 25, 2021 8:38 pm Post subject: Re: Thread size for the oxygen sensor |
18mm x 1.5mm _________________ -dan
www.thefixitworkshop.com |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9520 Location: Western WA
Posted: Sun Sep 26, 2021 7:13 am Post subject: Re: Thread size for the oxygen sensor |
Dan you must be a bung welder? _________________
....KTMs, GasGas, SPOT mtb |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1477 Location: Victoria,B.C.Canada
Posted: Sun Sep 26, 2021 6:28 pm Post subject: Re: Thread size for the oxygen sensor |
DanHoug wrote: |
18mm x 1.5mm |
My O2 sensor plug thread looks slight smaller than a 20mm x 1.5 so 18 must be it. |
jlrftype7 Samba Member
Posted: Mon Sep 27, 2021 12:13 pm Post subject: Re: Thread size for the oxygen sensor |
Here's my two old go-to tools, as Dan noted, 18mm x 1.50mm thread.
There are other O2 sensor threads out there, but thankfully we don't use them, so these dead common tools are easier to find.
Chaser if the space is tight, and actual tap if the threads won't work with the chaser due to damage or rust. Tap needs way more room though to work...
_________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
brickster Samba Member
Joined: January 05, 2004 Posts: 503 Location: CO, USA
Posted: Thu Oct 05, 2023 8:16 am Post subject: Re: Thread size for the oxygen sensor |
My O2 port's threads are damaged after removing the sensor. I've never used a tap before, but plan to pick one up from a FLAPS to cope. From the looks of things, I'll also need to buy a handle for it, correct?
I've done some web searches and it looks pretty straightforward (use oil, carefully start the tool to ensure correct, perpendicular cutting, after partial-turn resistance, turn backward before continuing, etc.). Since space is tight, I'm wondering if anyone was able to use a tap + handle in the same scenario.
Mostly, I'm looking for TheSamba to feed me optimistic feedback, success stories, etc. ;^) |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9776 Location: Mt Lemmon, AZ
Posted: Thu Oct 05, 2023 8:41 am Post subject: Re: Thread size for the oxygen sensor |
brickster wrote: |
...I'll also need to buy a handle for it, c Drorrect? |
Ideally, yes. But I have also used a wrench or 8-point socket when swing room was limited or ratcheting was useful. |
Posted: Thu Oct 05, 2023 4:02 pm Post subject: Re: Thread size for the oxygen sensor |
Ahwahnee wrote: |
brickster wrote: |
I can’t seem to get the tap started because the top threads are gone and it won’t catch on the bottom. There isn’t enough room to use a handle to exert downward pressure. Do I have any other options? |
Posted: Thu Oct 05, 2023 4:57 pm Post subject: Re: Thread size for the oxygen sensor |
Slowly turn the tap with a wrench while you tap LIGHTLY on the end of the tap with a hammer. Removing the exhaust might be in order. |
dougnlina Samba Member
Joined: January 19, 2016 Posts: 241 Location: San Francisco, CA
Posted: Thu Oct 05, 2023 5:57 pm Post subject: Re: Thread size for the oxygen sensor |
brickster wrote: |
Ahwahnee wrote: |
brickster wrote: |
Are you using a tapered tap? they are best for "finding" lost threads lower in the hole, proceed with caution... _________________ "Olive" a '60 Ragtop Beetle
"Grover" a '87 Syncro Poptop 1.8T |
Posted: Thu Oct 05, 2023 8:07 pm Post subject: Re: Thread size for the oxygen sensor |
dougnlina wrote: |
Are you using a tapered tap? they are best for "finding" lost threads lower in the hole, proceed with caution... |
Yes, and thanks to Wildthings’ tip to tap the top of the tap, I was able to cut new threads. With the tin shield removed, I had just enough room. I then used a magnet to get the shavings out. |
