ilustr8tor Samba Member
Joined: November 07, 2010 Posts: 426 Location: Maryland
Posted: Wed Sep 29, 2021 2:19 pm Post subject: Timing on 1200 with big bore kit 1385 |
I have installed a big bore kit on my 1965 6 volt beetle so from 1200 to 1385. I have a 30PICT-1 carb and a distributor with the vacuum advance. I have been setting my timing at TDC. Should I be advancing to 7.5?
_________________ I love this analog addition to my over digitzed life. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Wed Sep 29, 2021 2:23 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
What is the part number on the distributor? _________________ Glenn
Member #1009
#BlueSquare |
KTPhil Samba Member
Posted: Wed Sep 29, 2021 2:25 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
Most likely, yes.
What distributor model do you have?
I had a big-cap 40hp unit, that same carb, and I timed it at about 7.5 degrees BTDC.
Your distributor looks different. Does it also have mechanical as well, or is it vacuum-only?
The change from 1200 to 1385 should not change your timing, unless you changed the CR, which can go up a bit if you just fit the larger volume PC set. If they set your CR back to normal by shimming or machining the heads then you are fine with the stock unit. |
Posted: Wed Sep 29, 2021 2:46 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
not sure I think it is 009, I will have to loosen up so I can read part number, I will post when I do. _________________ I love this analog addition to my over digitzed life. |
Glenn Mr. 010
Posted: Wed Sep 29, 2021 2:53 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
It's vacuum only either a 205K or 205L. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Sep 29, 2021 2:54 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
I recently purchased this distributor but have not installed since the original is working fine, if I do install in place of the Bosch 009 distributor what should timing be set at?
Glenn Mr. 010
Posted: Wed Sep 29, 2021 3:06 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
It will not work correctly with that carb, the vacuum signal from the carb will not produce enough for the vacuum canister. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Wed Sep 29, 2021 3:47 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
is there a modification I can make to the carb for the electronic ignition Glenn? I bought the card from Volkblitz hate to change it runs great. _________________ I love this analog addition to my over digitzed life. |
Zundfolge1432 Samba Member
Posted: Wed Sep 29, 2021 4:48 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
ilustr8tor wrote: |
Wish you luck with that aftermarket distributor. Mine failed in less than 2 years. |
KTPhil Samba Member
Posted: Wed Sep 29, 2021 4:53 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
Why add another failure point that will leave you by the side of the road (ignition module)? Spare points are cheap and reliable!
Few (if any) aftermarket ignition setups are of the quality VW//Bosch put into the original parts. For a 1385 you need nothing more than the stock distributor.
Sell that unit and put your money elsewhere will it will make a difference.
The larger carb is a nice adjustment for the displacement increase, and is also reliable.
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Wed Sep 29, 2021 4:59 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
The distributor you have installed there is a 111 series that is correctly matched to a 28 PICT carburetor not your 30 PICT 1. The vacuum signal from the carburetor is a mismatch.
That distributor delivers @ 20 degrees of advance from @ 50mm Hg, and is typically static timed at 10 degrees before TDC. The distributors that matches that carburetor deliver @ 25 degrees of advance from @ 65 mm/Hg of vacuum.
Bottom line; it'll run but not at it's best. It will fully advance sooner than designed. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Wed Sep 29, 2021 5:11 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
Glenn wrote: |
It's vacuum only either a 205K or 205L. |
A "205 K" could be any of three other distributors. This one has the small saucer shaped vacuum canister so it is a 111 series, Either a ZV/JU 4 R 3 ( a 111 905 205 L but that number has never been stamped on a distributor to my experience), or a 111 905 205 M or N. These are all timed at 10 degrees BTDC when static.
a "205 L" could also be any of three other Bosch distributors and even a Garbe Lahmeyer distributor if it's a 113 905 205 L. _________________ Roads Scholar &
TASB what distributor do you recommend? I have a buddy who is willing to buy the new Flamethrower from me. It is a Bosch OEM distributor original part. Not sure of the part number I will find out what number I have in the morning and repost
Posted: Wed Sep 29, 2021 5:15 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
when I bought the car it had a Frankenstein carb on it half 28 and the other half 30. So I had Volkzblitz build the 30pict-1 for me. My bug is still 6 volt. I also put in a Big Bore kit from AAP so I believe it is 1385 cc. I gave Volkzblitz that info when he built the carb _________________ I love this analog addition to my over digitzed life. |
Posted: Wed Sep 29, 2021 5:28 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
The factory match for a 30 PICT 1 Solex carburetor is a Bosch 0 231 137 009 VW # 113 905 205 K. It is a vacuum advance only distributor that delivers about 25 degrees of advance and is static timed at around 7 degrees An SVDA distributor like the Flamethrower would not be a good choice. It looks like the flamethrower has a points replacement module in it so it wouldn't have worked in any case. With points and condenser the voltage is irrelevant. _________________ Roads Scholar &
Posted: Wed Sep 29, 2021 6:44 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
found this one:
https://www.thesamba.com/vw/classifieds/detail.php?id=2263755
found a lot of others online but this is only "K" I could find. Should I get it with new vacuum canister?
Or if you know of another source.
Thanks for your help. _________________ I love this analog addition to my over digitzed life. |
Glenn Mr. 010
Posted: Wed Sep 29, 2021 6:53 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
The 205K is as basic as you can get so it's pretty hard to mess it up.
Price is good, but not sure why you would need 10 condensers. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Sep 30, 2021 9:34 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
Over the years I have come across many vacuum advance only distributors with issues which may not be caught or solved by the home mechanic:
incorrect/leaking vacuum canister installed
broken ground cable
broken cap clip with worn un-repairable bosses
missing broken shims
drive dog installed in reverse
stripped threads on points hold down screw
wrong points plate installed
wrong advance return spring installed
overtightened/bent clamp
just to name a few. Not as simple as some might try to make it seem. _________________ Roads Scholar &
Posted: Fri Oct 15, 2021 1:10 pm Post subject: Re: Timing on 1200 with big bore kit 1385 |
Here is the distributor in question it is a 111 but a 205M
Posted: Sun Oct 17, 2021 1:15 am Post subject: Re: Timing on 1200 with big bore kit 1385 |
A 111 905 205 M is a 40 hp distributor matched to a 28 PICT 2 carburator _________________ Roads Scholar &
