w2vy Samba Member
Joined: October 30, 2016 Posts: 122 Location: Tampa, FL
Posted: Wed Sep 29, 2021 4:24 pm Post subject: Rear Seat Back question |
Just got an oval that was made Dec 1955
The back seat is completely missing!
I see from other posts that the seat bottom from 56-63 will fit.
But the seat back is a little more of a mystery.
It seems to not have the two bolts on each end of the seat like on 67+
Did that also change between 63/64?
Thanks for any insights.
Tom |
janerick3 Samba Member
Posted: Wed Sep 29, 2021 5:35 pm Post subject: Re: Rear Seat Back question |
The change from two to one bolt per side took plane in August 1955, so any rear seat back between 1956 and 1964 model years (and probably later) will drop right in. The cardboard back and steel rails were replaced by carpet at some point. _________________ Thanks,
Jan K. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9969 Location: Huntington Beach, CA
Posted: Thu Sep 30, 2021 8:45 am Post subject: Re: Rear Seat Back question |
I had a later 55 that I was able to install a 73 Super Beetle rear seat into. Got the seat from Pick A Part, out of the 73. Took a gamble at $5! But it worked out great! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Thu Sep 30, 2021 9:17 am Post subject: Re: Rear Seat Back question |
janerick3 wrote: |
The change from two to one bolt per side took plane in August 1955, so any rear seat back between 1956 and 1964 model years (and probably later) will drop right in. The cardboard back and steel rails were replaced by carpet at some point. |
Yup - 8/55 was a '56 and almost any back seat will work for you - although the early '55 rear seats were a different design - consider yourself fortunate that you were not missing that one - is mucho Yankee-dollars- if you even found one -z _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
w2vy Samba Member
Posted: Thu Sep 30, 2021 5:41 pm Post subject: Re: Rear Seat Back question |
Pulled the driver's side panel in the backseat and found the bolt holt.
My Dad hadn't punched a hole in the new cover for the cardboard.
Thanks! |
w2vy Samba Member
tehillah1 Samba Member
Joined: August 23, 2009 Posts: 278 Location: Colorado
Posted: Thu Dec 02, 2021 9:49 am Post subject: Re: Rear Seat Back question |
So anyone out there been able to fit a later seat back into an early '55? Any modifications that will make a later seat back work in an early '55?
Mika (Vertanen) makes the lower tabs that fit on the bottom of the early seat backs but I've not seen anything on Samba about making a later seat back work on an early '55 |
Posted: Thu Dec 02, 2021 10:45 am Post subject: Re: Rear Seat Back question |
tehillah1 wrote: |
We have tried and tried, and no later seat back will work if the original seat back was the early mounting-design - poor planning by VW - on one of our 2/1955s, with early mount-design, we made a wood platform, covering the back seat area - it works well, in our now 2 seater type one.
The last 2, 1954s, we bought, have the correct ( early) rear seat backs - one of 'em, i'll re-use and re-use - i'll never sell it - have fun - z _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
Posted: Thu Dec 02, 2021 10:58 am Post subject: Re: Rear Seat Back question |
That's kinda what I was afraid of. I've made two seaters out of a couple of later bugs so that's the direction I've been heading for the 'Ol 55.
Thanks for the info Zen...Experience is the best teacher and having you and others willing to share your wealth of experience keeps some of us less experienced folks plugging along!
Cheers |
aa390392 Samba Member
Posted: Wed Jul 19, 2023 2:18 pm Post subject: Re: Rear Seat Back question |
Anyone know the hardware size of bolts/ fasteners that hold up back seats of 1955…anything special about them?
Thanks a lot. _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
Dan22 Samba Member
Joined: August 30, 2019 Posts: 470 Location: Battle Ground, WA
Posted: Wed Jul 19, 2023 2:26 pm Post subject: Re: Rear Seat Back question |
Two 6mm bolts each side with fender washers is for the backrest. No hardware used on the seat bottom but it does have support feet left and right that rest/lock behind the inner quarter panel tab, and one foot in the center. _________________ 1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074 |
Posted: Wed Jul 19, 2023 2:47 pm Post subject: Re: Rear Seat Back question |
Thank you Dan…fast response, just what I like. _________________ .
55 ragtop
56 delux sedan
56 Kabriolet |
