Nando_b63 Samba Member
Posted: Sat Oct 02, 2021 5:11 pm Post subject: Omitting stock oil cooler from doghouse shroud |
So I heard back in 2003/2004 about some people were omitting the doghouse oil cooler on big engines up to 2275cc , but never saw compression numbers.
They block off the cooler on the case , ran lines to remote oil cooler and thermostatically switched fan under the car on left of trans.
They would prop the bottom of the deck lid , Accor to them no heating issues.
I now see this in 2021 still and they still utilizing this method.
So does it really work on big engines with 8:0:1 to 10:0:5 compression,
Driven on street?
Thanks in advance |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Sat Oct 02, 2021 5:18 pm Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
Bad idea.
I have a 2180 and it runs as cool as stock with just the stock oil cooler. _________________ Glenn
Member #1009
#BlueSquare |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Sat Oct 02, 2021 5:22 pm Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
Works fine with mine…
2100cc, 9.8:1 |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
nextgen Samba Member
Joined: August 19, 2004 Posts: 6028 Location: CONGERS, N.Y.
Posted: Sat Oct 02, 2021 5:35 pm Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
In my manual I told customers of my Type 4 Conversion manual to use the larger T-4 Oil cooler.
I drive a 2.0 914 in my bug and personally found out the stock T-1 cooler was enough to cool my engine.
A point some guys miss if you have an engine that is putting out more HP, the engine will hardly be working to to push the car.
Less work, less heat.
Sure if you go High Compression etc. you just jumped into the unknown. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Sat Oct 02, 2021 5:38 pm Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
I run a remote cooler "only'' on both of my street cars.
No issues at all. Regulates oil at 195F no matter what.
I saw the oil temp hit 205F once after a long highway trip on a 90F+ day.
So I run a late model fan (wider) in an early shroud. |
Posted: Sat Oct 02, 2021 5:53 pm Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
Ohio Tom wrote: |
What compression and what brand of remote oil cooler?
Thanks . |
94touring Samba Member
Joined: October 24, 2020 Posts: 313 Location: Oklahoma - OK
Posted: Sat Oct 02, 2021 5:59 pm Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
I run remote only on a 2110 bus but only because I kept getting leaks off the oil adapter and got sick of dropping the motor. End result is I still run 180-200 everywhere I go. No fan on the cooler, just a scoop to direct air over it. |
txoval Samba Member
Posted: Sat Oct 02, 2021 7:39 pm Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
My numbers are similar to Tom’s. My fan comes on at 190F and my oil never gets above 195F. I live in Texas and it gets plenty hot.
Setrab oil cooler and fan
Wreck Samba Member
Posted: Sat Oct 02, 2021 7:48 pm Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
So far every one as just mentioned oil temps , what about the more important CHT difference ? Has anyone done a back to back change and noted the difference or difference in CHT's , particularly on a hot day over 30C , 90F ambients ? |
Posted: Sat Oct 02, 2021 8:03 pm Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
txoval wrote: |
how long have you ran that Sertab oil cooler and how efficienthas it been , including the thermostat on it?
thanks |
Posted: Sat Oct 02, 2021 8:50 pm Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
Wreck wrote: |
Made zero difference in CHT readings. |
Wreck Samba Member
Posted: Sat Oct 02, 2021 9:03 pm Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
94touring wrote: |
Wreck wrote: |
That makes sense , with the dog house the cooler is out of the air flow and the airflow feeding the cooler duct should be surplus. Nice to know someone has done the experiment . |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Sun Oct 03, 2021 2:51 am Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
My first thought : why? There's delicate balances going on inside those shrouds, figured out by engineers who knew what they were doing.
Then I read :
Ohio Tom wrote: |
And that totally makes sense; you're not upsetting the balance by modifying a doghouse shroud, just increasing the flow (presumably). I assume the choice of an early shroud is for reasons of space? |
txoval Samba Member
Posted: Sun Oct 03, 2021 4:13 am Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
Yes,
UK Luke 72 wrote: |
txoval wrote: |
[img]https://www.thesamba.com/vw/gallery/pix/2175964.jpg[/img |
How is that mounted? Guess it's attached to the torsion tube? |
txoval Samba Member
Posted: Sun Oct 03, 2021 4:18 am Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
I have been running the Setrab for two years, before that I had a 6 pass cooler.
The Setrab is much more efficient and a better cooler by far. It is tiny too, 6”x6”
It is an inline electronic thermostat, no a bypass…oil gets to 190F and the fan kicks on. Thermostat is on the outlet side of the cooler |
Posted: Sun Oct 03, 2021 4:51 am Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
txoval wrote: |
Setrab or the CBR cooler where my choices ,
Getting the Setrab for sure..
Thank yo and have a blessed Sunday txoval. |
pupjoint Samba Member
Posted: Sun Oct 03, 2021 7:40 am Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
txoval wrote: |
hi txoval, what about the relief plunger bypass on the flywheel side, still stock spring and piston? |
txoval Samba Member
Posted: Sun Oct 03, 2021 7:50 am Post subject: Re: Omitting stock oil cooler fro doghouse shroud |
Stock spring and piston…
My stock cooler block off allows flow thru it…the ports aren’t plugged, so the oil system doesn’t know the cooler isn’t installed
Just as a warning, the Setrab setup is not cheap
https://www.thesamba.com/vw/classifieds/detail.php?id=2278097 |
