EverettB Administrator
Joined: April 11, 2000 Posts: 69826 Location: Phoenix Metro
Posted: Mon Oct 04, 2021 8:38 am Post subject: 1965 21-Window at Mecum auction this weekend |
https://www.mecum.com/lots/LN1021-467969/1965-volkswagen-type-ii-bus/
A member asked me if I knew anything about this Bus and if it was a real 21-Window as no M-code or proof are provided.
I did not know anything but in the auction text it says
Custom roof conversion
I feel this was easy to miss and I assume that means it is a conversion.
It looks really nice otherwise, although I do see some typical strange and/or missing parts, for example:
2-tone wheels with no trim rings
Heater knob and maybe mechanism too are missing from underneath the driver seat
Headliner might be cloth and not vinyl?
No pedal pan
Rear bumper looks misaligned in some photos
Steering column painted Beige Grey instead of black
Middle seat grab handles are installed wrong or don't fit right
I decided to start a thread in case anyone else sees anything else "off" about the Bus _________________ How to Post Photos
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Oct 04, 2021 10:41 am Post subject: Re: 1965 21-Window at Mecum auction this weekend |
The rear bumper should be pointed- not a chisel, no?
The passenger headlight is a bug unit with a bus driver's side ring installed (drain hole pointing up).
Minutia perhaps- but when it's a high dollar resto for high payoff things probably could have been addressed earlier. _________________
EverettB wrote: |
FU#5 |
Braukuche Samba Member
Posted: Mon Oct 04, 2021 11:14 am Post subject: Re: 1965 21-Window at Mecum auction this weekend |
Early style handle, should be a flat folding style.
Spacer for the carb instead of governor.
12v conversion
15 inch wheels
Shitty Wolfsburgwest repro radio delete plate
No splash pan
Underside painted instead of left in primer
Went repro rear bumper as noted
Fake 21 window _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Mon Oct 04, 2021 11:29 am Post subject: Re: 1965 21-Window at Mecum auction this weekend |
Not a problem with the bus per se, but shiny classic in an industrial complex is a huge red flag for me, It's quite obvious this one was created solely for profit. I want to buy from an owner thats had the car a while, been on trips with it, etc. |
hitest Samba Member
Posted: Mon Oct 04, 2021 12:42 pm Post subject: Re: 1965 21-Window at Mecum auction this weekend |
It would have taken all of 2 minutes with a spatula to make all those pop out windows seal effectively. _________________
EverettB wrote: |
FU#5 |
Clara Samba Member
Posted: Mon Oct 04, 2021 3:04 pm Post subject: Re: 1965 21-Window at Mecum auction this weekend |
EverettB wrote: |
No pedal pan
I decided to start a thread in case anyone else sees anything else "off" about the Bus |
I'd think a deluxe should have a white column, not black.
The bracket for column to dash is white, it should be black.
extra hole left side of pod
a 65 should have mesh grey interior, not mesh platinum
spare tire cover should be the basketweave vinyl no beading, not smooth vinyl with beading. ( this is picky I know)
where's the pic of the rear carpet showing the spare tire cover snapped in place?
I think 65 was a split year for rear bumper, so slant for early 65, pointy is for late 65
should have grease on brake cables where they go round the bend under the front floor
Is the bumper trim straight?
looks like there's no beading on middle seat kick panel
I like the black covers for the rear axle tube. and the red body there where the spring plates bolt on.
T series key (correct)
has vinyl on parcel tray
correct cab door handle orientation
side pic of sunroof folded nicely _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
hitest Samba Member
Posted: Mon Oct 04, 2021 6:45 pm Post subject: Re: 1965 21-Window at Mecum auction this weekend |
I keep noticing small things:
Black fill-in on the hubcap logos is a little later than should be.
The engine vents lack chrome strips. _________________
EverettB wrote: |
FU#5 |
Posted: Mon Oct 04, 2021 7:45 pm Post subject: Re: 1965 21-Window at Mecum auction this weekend |
hitest wrote: |
The engine vents lack chrome strips. |
Weren’t the chrome strips only on outie vents? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Mon Oct 04, 2021 7:47 pm Post subject: Re: 1965 21-Window at Mecum auction this weekend |
Clara wrote: |
Thanks for the correction, I did mean the bracket but left off the word "Bracket".
I was surprised at the parcel tray vinyl too, that is often missed, even on top level restorations. _________________ How to Post Photos
Posted: Mon Oct 04, 2021 7:48 pm Post subject: Re: 1965 21-Window at Mecum auction this weekend |
hitest wrote: |
No vent strips are ok - that's only an earlier Bus outie vent thing.
You are correct on the painted hubcaps of course.
I missed that it had 15" wheels too, as someone else noted _________________ How to Post Photos
Busstom Samba Member
Joined: November 23, 2014 Posts: 3853 Location: San Jose, CA
Posted: Mon Oct 04, 2021 10:24 pm Post subject: Re: 1965 21-Window at Mecum auction this weekend |
Shouldn't there be dash tabs to latch the safaris?
Edit:
- No heater tube insulation
- No brake reservoir cover in front floor board
- No grommet on accelerator pushrod
- No rear hatch alignment guides (wedges)
What's with the radio speaker (wiring) hole in the A-pillar?
zehbeh Samba Member
Joined: February 16, 2008 Posts: 249 Location: Stuttgart
Posted: Mon Oct 04, 2021 10:53 pm Post subject: Re: 1965 21-Window at Mecum auction this weekend |
what do you think: are those safari windows original ones?
The v-shaped lower profile looks like they are original ones. But after the bus is a fake 21 I would have assumed that the safari windows were added later too. |
FarmerBill Samba Member
Joined: July 25, 2017 Posts: 766 Location: New England
Posted: Tue Oct 05, 2021 8:13 am Post subject: Re: 1965 21-Window at Mecum auction this weekend |
Carburetor pre-heat on the wrong side for 65. They also list the engine as "1600 dual port" wonder if they meant dual relief? |
hitest Samba Member
Posted: Wed Oct 06, 2021 4:33 pm Post subject: Re: 1965 21-Window at Mecum auction this weekend |
Braukuche wrote: |
hitest wrote: |
Weren’t the chrome strips only on outie vents? |
Well shart my shorts and rub my eyes. Busted. _________________
EverettB wrote: |
FU#5 |
Tizian Samba Member
Joined: February 18, 2015 Posts: 383 Location: Hamburg, Germany
Posted: Sun Oct 10, 2021 1:25 am Post subject: Re: 1965 21-Window at Mecum auction this weekend |
How much did it fetch? |
BonTonRoulet Samba Member
Joined: September 29, 2020 Posts: 363 Location: Mississippi
Posted: Sun Oct 10, 2021 1:34 am Post subject: Re: 1965 21-Window at Mecum auction this weekend |
Tizian wrote: |
I don't know. I clicked on the link posted above and it said I had to put a log into it or something to see the selling price. |
ronjonlasvegas Samba Member
Joined: October 08, 2004 Posts: 902 Location: Las Vegas, NV
Posted: Sun Oct 10, 2021 5:06 am Post subject: Re: 1965 21-Window at Mecum auction this weekend |
BonTonRoulet wrote: |
Tizian wrote: |
The 1965 21 window sold for $132,000
This 1964 mouse grey 21 window sold for $88,000
https://www.mecum.com/lots/LN1021-468008/1964-volkswagen-type-ii-21-window-deluxe-bus/ _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
Posted: Sun Oct 10, 2021 8:19 am Post subject: Re: 1965 21-Window at Mecum auction this weekend |
That’s a lot of money for a fake, but then real ones are going for $150k plus. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Tizian Samba Member
Posted: Sun Oct 10, 2021 11:33 am Post subject: Re: 1965 21-Window at Mecum auction this weekend |
That's insane!
I won't sell my original 21. And she will get a proper vinyl for the parcel tray, too these days
Those prices are disturbing though. I thought they were falling a bit recently. But it seems not, as even a fake fetches a lot more than 100K.
I used to drive her as a daily driver. That seems almost impossible nowadays, which is somewhat sad... |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Sun Oct 10, 2021 6:26 pm Post subject: Re: 1965 21-Window at Mecum auction this weekend |
Were they both fake? |
