vanis13 Samba Member
Joined: August 15, 2010 Posts: 3101 Location: ABQ NM USA.... Except when not
Posted: Wed Dec 01, 2021 6:36 pm Post subject: Re: Started my full length roof rack |
consider that the sides of pipe clamps you selected will bash what ever is sliding around your rack. even if just while putting it up there before tying down....plus it costs you 2"? of usable width?
maybe something like this as an alternate?
_________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Mateo83 Samba Member
Joined: September 14, 2021 Posts: 608 Location: Lodi, CA
Posted: Wed Dec 01, 2021 9:26 pm Post subject: Re: Started my full length roof rack |
I prefer the pvc insert so it’s not metal on metal. Nothing will ever be loose sliding around _________________ 83 Air-cooled 2.0 Tin Top |
DuncanS Samba Member
Posted: Wed Dec 01, 2021 10:49 pm Post subject: Re: Started my full length roof rack |
Oh, so the bottom U clamp is welded to the cross bar and that's what holds the water reservoir in place?
I'm with vanis13 and think moving the side bolt out of the way might have some qualities.
Duncan |
Posted: Wed Dec 01, 2021 11:07 pm Post subject: Re: Started my full length roof rack |
even a complete strap that goes all the way around...kinda like what you have but with the bolt only on the one rail side and the inside side just band. the PVC insert is possible in all those options _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1858 Location: anchor pt. alaska
Posted: Thu Dec 02, 2021 6:11 pm Post subject: Re: Started my full length roof rack |
Cool, rack looks good. Any idea how much it weighs? I've often considered what's the total weight I'd feel comfortable with on the roof. 300 to 400 lbs? Is 400 ridiculous? What's a loaded westy roof plus rocket boxes weigh? |
Posted: Fri Dec 03, 2021 9:48 am Post subject: Re: Started my full length roof rack |
I calculated around 200lbs just for the rack. My wife and I could pretty easily set it on top. Now with the gussets, solar and water tank. May be closer to 300. So yeah when it’s loaded I could see that 400lbs range. _________________ 83 Air-cooled 2.0 Tin Top |
