benchracer1 Samba Member
Joined: September 24, 2006 Posts: 583 Location: ramona
Posted: Sat Oct 09, 2021 8:02 pm Post subject: Sanding body lines |
Anybody got any tips or techniques on sanding body lines. I am trying to avoid any grooves and have nice crisp lines
jitbba Samba Member
Joined: August 20, 2013 Posts: 165 Location: San Antonio
Posted: Sun Oct 10, 2021 6:51 am Post subject: Re: Sanding body lines |
guidecoat and light pressure with a sanding block. let the sandpaper do the work _________________ My other ride is a Zildjian |
Braukuche Samba Member
Posted: Sun Oct 10, 2021 8:49 am Post subject: Re: Sanding body lines |
After using the block I like to use a soft block or even cardboard backing with paper and lightly go over it to knock off any ridges that may have formed from the block, working across the grain. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Sun Oct 10, 2021 12:10 pm Post subject: Re: Sanding body lines |
Thanx guys |
Posted: Sun Oct 10, 2021 6:04 pm Post subject: Re: Sanding body lines |
It's going a bit better. I still am having an issue with leaving a small amount of guide coat in the valley of the line or if I get the line clean and smooth I end up removing the primer on the outside edge of the line. I'm wondering if I'm using the wrong shape of block or maybe the right block but operator error. I'm using 150 grit before 220...steve
jitbba Samba Member
Posted: Sun Oct 10, 2021 7:23 pm Post subject: Re: Sanding body lines |
220 is too coarse for primer if sanding by hand and not machine. That’s why you’re knocking down all your primer to expose the metal _________________ My other ride is a Zildjian |
Caveey Samba Member
Joined: August 21, 2014 Posts: 52 Location: Alberta, Canada
Posted: Thu Oct 28, 2021 8:11 am Post subject: Re: Sanding body lines |
I am probably too late but I had the same problems in my body lines (especially on the rear notch fenders...very tight body line). What worked really well for me was to wrap a drill bit that had the same curve as the body line and it worked great, I think I ended up using 2 different drill bit sizes.
Good Luck!
Rob |
Igpoe Samba Member
Joined: February 24, 2019 Posts: 853 Location: South Boston, VA
Posted: Fri Oct 29, 2021 2:44 am Post subject: Re: Sanding body lines |
SCOTCHBRITE _________________ '73 super. |
