Era Vulgaris Samba Member
Joined: August 22, 2012 Posts: 1677 Location: Raleigh, NC
Posted: Thu Feb 10, 2022 6:20 pm Post subject: Re: 1966 Ghia coupe restoration |
Tomorrow is going to be an exciting day. After being separated for many months, the pan and body are going to be re-united. I just installed the German pan seal tonight, using 3M Super Black and original style upholstery tacks (which no one will ever see, but I'll know they're there just like when the car rolled off the assembly line). I still need to cut holes in the seal for the body mount bolts, but I'll do that in the morning before the tow arrives
_________________ Currently own:
66 Karmann Ghia, L390 Gulf Blue, under construction, here: www.thesamba.com/vw/forum/viewtopic.php?t=760505&highlight=
99 Mazda MX-5 10AE, Sapphire Blue Mica, 6 speed, LSD
Previously owned:
98 Porsche Boxster, silver, 2.5L -- 67 Karmann Ghia, Black, 1500sp -- 98 BMW Z3, Atlanta Blue Metallic, 2.8L I6 -- 75 Porsche 914, Laguna Blue, 2270cc -- 72 Porsche 914, Signal Orange, 1.7 FI -- 74 Karmann Ghia, Black, 1600dp -- 74 Triumph TR6 with O.D., sapphire blue |
Braukuche Samba Member
Posted: Fri Feb 11, 2022 8:55 am Post subject: Re: 1966 Ghia coupe restoration |
Congrats, it’s a huge step. I was planning on reuniting mine today but I chopped off the tip of my finger cutting kohlrabi. Look forward to pictures. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Fri Feb 11, 2022 6:07 pm Post subject: Re: 1966 Ghia coupe restoration |
Braukuche wrote: |
Congrats, it’s a huge step. I was planning on reuniting mine today but I chopped off the tip of my finger cutting kohlrabi. Look forward to pictures. |
Ouch! I hope your finger's ok _________________ Currently own:
Previously owned:
Posted: Fri Feb 11, 2022 6:09 pm Post subject: Re: 1966 Ghia coupe restoration |
Some final shots of the chassis by itself. Could be the last time, or at least for hopefully a very long time, that this chassis is body-less
Previously owned:
Posted: Fri Feb 11, 2022 6:10 pm Post subject: Re: 1966 Ghia coupe restoration |
On the way to get the body
Previously owned:
Posted: Fri Feb 11, 2022 6:12 pm Post subject: Re: 1966 Ghia coupe restoration |
Back together again.
It was lots of: ok slowly, stop stop stop, shift a hair left, ok go, no stop, a little this way, etc
Previously owned:
Posted: Fri Feb 11, 2022 6:14 pm Post subject: Re: 1966 Ghia coupe restoration |
Back home
And now the fun begins. I have a feeling I'm going to start digging through the boxes of parts I took off the car, and very little is going to pass the test to go back on. The hardware in particular. Is there an actual list of nut, bolt, and screw sizes for everything, or do most people just use whatever fits?
Previously owned:
Marcdeb Samba Member
Posted: Fri Feb 11, 2022 7:02 pm Post subject: Re: 1966 Ghia coupe restoration |
This is moving along nicely. Putting the body and pan back together would certainly make me a nervous wreck, especially with this beautiful paint job. Great work. Looks amazing. Anxious to see it all back together. _________________ Marc
71 Karmann Ghia Cabrio
Previously Owned:
2011 VW EOS Hard Top Conv
2008 Saab 9-3 2.0T Conv
2003 Saab 9-3 SE Conv
2001 Saab 9-3 Conv
1998 BMW 3 Series Conv
1997 Saab 900 Conv
1997 Mazda Miata
71 Ghia Vert Restoration: https://www.thesamba.com/vw/forum/viewtopic.php?t=726710&postorder=asc |
Posted: Fri Feb 11, 2022 8:26 pm Post subject: Re: 1966 Ghia coupe restoration |
I try to use all original hardware, I just clean it up on the wire wheel on my grinder and paint it if it’s supposed to be painted. There’s not much of it and not much variety. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
Posted: Fri Feb 11, 2022 10:00 pm Post subject: Re: 1966 Ghia coupe restoration |
I don't think they got this much care and attention at the factory. Nice work! This is where the marathon enters the stadium and the finish line is in sight
Era Vulgaris wrote: |
....or do most people just use whatever fits? |
I can only speak for myself... I had bags of nuts and bolts that I reused after cleaning them up as best I could. I lost a bunch when I had them acid dipped and learned the hard way that the acid ruins them. The best method I've since learned is to thoroughly degrease them and send them away to get "blacked" again.
Nicholas _________________ '66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
c21darrel Samba Member
Posted: Sun Mar 06, 2022 4:48 pm Post subject: Re: 1966 Ghia coupe restoration |
It really starts to look like a Ghia once those nose grills are in
Previously owned:
Posted: Sun Mar 06, 2022 4:53 pm Post subject: Re: 1966 Ghia coupe restoration |
I hadn't replaced these 60-69 tail light seals before, and man they are a bit of a wrestling match to get them fitted on the lens.
I'm sure some of y'all know this, but I discovered that the best order of op for these is: seal onto lens, lens onto lighting housing, then the entire assembly onto the car.
I had initially put the lighting housing onto the car first, before installing the lens with seal, and I couldn't get the seal to fit flush against the body that way. But installing the lens onto the lighting housing before it all goes onto the body, everything fit flush and perfect.
Previously owned:
Rome Samba Member
Joined: June 02, 2004 Posts: 9640 Location: Pearl River, NY
Posted: Sun Mar 06, 2022 5:35 pm Post subject: Re: 1966 Ghia coupe restoration |
Will you still drill through the new paint and the body filler to open up the two M6 holes for the rear bumper overrider struts? You can barely see the hole locations in this photo- |
Posted: Sun Mar 06, 2022 6:21 pm Post subject: Re: 1966 Ghia coupe restoration |
Rome wrote: |
Will you still drill through the new paint and the body filler to open up the two M6 holes for the rear bumper overrider struts? You can barely see the hole locations in this photo |
Nope, I ended up having them closed up the correct way, no filler. I'm installing Euro bumpers. I'm not a fan of how the US overriders look. _________________ Currently own:
Previously owned:
Rome Samba Member
Posted: Sun Mar 06, 2022 9:36 pm Post subject: Re: 1966 Ghia coupe restoration |
OK. I saw a later photo while at the body shop with a skim of filler over the hole area, which was my clue that it was filled that way. Euro bumpers will look good against the blue color. |
Posted: Mon Mar 07, 2022 6:26 am Post subject: Re: 1966 Ghia coupe restoration |
Rome wrote: |
It was an oversight on my part. There was so much focus on the front of the car with the nose swap, that I completely forgot about having those holes deleted when I gave them the go ahead to move on from the metalwork. Caught it at the last minute _________________ Currently own:
Previously owned:
Posted: Mon Mar 07, 2022 8:33 am Post subject: Re: 1966 Ghia coupe restoration |
Nice ass shot. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Mon Mar 07, 2022 6:09 pm Post subject: Re: 1966 Ghia coupe restoration |
Braukuche wrote: |
Nice ass shot. |
Previously owned:
Posted: Tue Mar 08, 2022 6:08 pm Post subject: Re: 1966 Ghia coupe restoration |
Does anyone know what the size and thread pitch of the mounting nuts are for Blaupunkt radios? Are they the same size as for Sapphire radios?
My Blaupunkt didn't come with any. There's some people in the classifieds selling mounting nuts for Sapphires. Was curious if they're the same or not. _________________ Currently own:
Previously owned:
