paddyo Samba Member
Posted: Tue Oct 12, 2021 10:31 am Post subject: Unable to shift into first gear--1965 Beetle |
Have recently installed a new 1600 engine in my beetle. I am able to shift into all gears except first. I have adjusted at the shift plate on the gear shift several times and removed the rear seat access plate to make sure that the bolt is firmly seated in the proper indentation. It looks like third gear can move the shaft back further than first gear. I have re-filled the transmission with the proper hypoid gear oil. (The car had been sitting quite a while.) I am thinking that a short drive using the remaining gears might be in order (?) Any suggestions would be welcome. Thank you. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34009 Location: Conejo Valley, CA
Posted: Tue Oct 12, 2021 11:00 am Post subject: Re: Unable to shift into first gear--1965 Beetle |
I would check the shifter ball, and also the condition of the plastic rod bushing. |
paddyo Samba Member
Posted: Tue Oct 12, 2021 11:06 am Post subject: Re: Unable to shift into first gear--1965 Beetle |
Thank you KTPhil. I installed a new shifter ball. I will double-check the plastic rod bushing. |
Pops67Beetle Samba Member
Joined: January 03, 2021 Posts: 127 Location: Queens, NY
Posted: Tue Oct 12, 2021 2:58 pm Post subject: Re: Unable to shift into first gear--1965 Beetle |
Are you still using the original 65 transmission? _________________ When I close my eyes I’m a little kid riding in the cubby..... Priceless!
13 y/o son’s quote while watching us replace the pedal cluster…. “Who says the Germans lost the war.”
67 Beetle bought new, 95% stock. |
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
paddyo Samba Member
Posted: Tue Oct 12, 2021 3:21 pm Post subject: Re: Unable to shift into first gear--1965 Beetle |
I replaced the transmission about 15,000 miles ago with a new one from “Transform”—a company specializing in VW trannys and it operated well with the original 1200 40 hp engine for several years. I have not operated this transmission for the past 18 years. During the restoration process, I drained the transmission and refilled it with fresh gear oil. |
KTPhil Samba Member
Posted: Tue Oct 12, 2021 3:29 pm Post subject: Re: Unable to shift into first gear--1965 Beetle |
If you do replace the bushing, check the advice in the threads about it. Some plastics are bad, some are poorly made, and you must check the fit of the clamping ring before you install it. Those are often poorly made or distorted or too tight/loose, and you will have to do the job all over again.
https://www.thesamba.com/vw/forum/viewtopic.php?t=157519
https://www.thesamba.com/vw/forum/viewtopic.php?t=662961
viiking Samba Member
Joined: May 10, 2013 Posts: 2668 Location: Sydney Australia
Posted: Tue Oct 12, 2021 3:35 pm Post subject: Re: Unable to shift into first gear--1965 Beetle |
Disconnect the rear coupling and then see if you can engage first gear manually there.
It'll be pretty obvious then whether the problem is your linkages or your internals. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
paddyo Samba Member
Posted: Wed Oct 13, 2021 11:04 am Post subject: Re: Unable to shift into first gear--1965 Beetle |
Thank you all for your advice on this matter. As suggested, I replaced the bushing, did some additional lubrication and made some adjustments at the shifter. I then took it for a short 15 minute drive and finally got it into first (The drive reminded me to adjust the steering as well.) I am now on my way. Appreciate the help!! |
aa390392 Samba Member
Posted: Wed Oct 13, 2021 4:08 pm Post subject: Re: Unable to shift into first gear--1965 Beetle |
Once you remove the gamblit housing, the donneley nut spacing and crackedsystem must be rim riding the gripet configuration. _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
RUNKLE Samba Member
Posted: Thu Oct 14, 2021 7:37 am Post subject: Re: Unable to shift into first gear--1965 Beetle |
aa390392 wrote: |
Once you remove the gamblit housing, the donneley nut spacing and crackedsystem must be rim riding the gripet configuration. |
Don't forget the pin-flam-fastened pan traps at both maiden-apexes of the jim-joist. _________________ Type 1
Type 3
1968 Squareback |
