Oil Pressure Switch
syncroAustralia
syncroAustralia is offline
PostPosted: Wed Oct 13, 2021 7:58 pm    Post subject: Oil Pressure Switch Reply with quote
Does the oil pressure switch (for the oil light) have a tapered thread or a parallel thread with a washer?
The leaking one that is fitted is a tapered thread, like a VW switch and the new one that I have bought is a straight thread with a washer.
Phill
http://members.ozemail.com.au/~pjlander/volkswagen_syncro.htm
Starbucket
Starbucket is offline
PostPosted: Sat Oct 16, 2021 12:16 pm    Post subject: Re: Oil Pressure Switch Reply with quote
The switch should have DIN thread which is not tapered. Tapered pipe threads are real close and some people just run a tapered pipe tap into the hole but doing that will mean no going back.
syncroAustralia
PostPosted: Sat Oct 16, 2021 12:30 pm    Post subject: Re: Oil Pressure Switch Reply with quote
Thank you. I will try the new straight thread switch.
Phill
Jacks
Jacks is offline
PostPosted: Sun Oct 17, 2021 12:33 am    Post subject: Re: Oil Pressure Switch Reply with quote
I’ve never seen an original 356 engine that didn’t have a tapered ops. Service of thousands of examples dating back to 1966, still in the trenches 5 day a week
Jack Staggs
Actual name
