UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
oprn Samba Member
Joined: November 13, 2016 Posts: 12740 Location: Western Canada
Posted: Thu Oct 14, 2021 6:54 am Post subject: Re: Pinging under light load |
Seems odd. Maybe you are hearing something else, cracked piston, rocker arm loose, end play in the cooling fan/generator, throw out bearing. Something like that? _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Thu Oct 14, 2021 7:31 am Post subject: Re: Pinging under light load |
Luke,
you would think so , but thats not always the case, sometimes the heavier loading quiet things up. but under light load allows things to move... make noise. had a guy recently who broke the 2nd ring land on a piston... under heavy load... sounded normal... under light load or idle.... clanging and banging. |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Thu Oct 14, 2021 8:13 am Post subject: Re: Pinging under light load |
Who knows it could be the fuel.
I always use Shell V-Power as well. _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7219 Location: Videbaek Denmark
Posted: Thu Oct 14, 2021 10:11 am Post subject: Re: Pinging under light load |
40 on cruise is pushing it, especially on 95 octane. It will most likely not appreciate more than about 30 & 38.
What is your map in the trouble area at 40% throttle? _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
fl59bug Samba Member
Joined: November 23, 2005 Posts: 1976 Location: North Carolina
Posted: Thu Oct 14, 2021 10:29 am Post subject: Re: Pinging under light load |
I can empathize - any carb to manifold or manfold to head vacuum leaks?
I had a 1776 once that ran great at first but then the Dellorto manifolds (or the head joint itself) developed some nasty warpage and due to the lean condition the bug would ping no matter what gas I ran.
Back then I didn't know what the heck a vacuum leak was and never bothered to investigate. Only later did someone find the problem for me.
Good luck and I hope you get it resolved - Ted |
Posted: Thu Oct 14, 2021 12:30 pm Post subject: Re: Pinging under light load |
Alstrup wrote: |
What is your map in the trouble area at 40% throttle? |
I pulled 5° out. So it was around 37° cruise
Map is 95-97kPa
AFR 13.8
Now I've tweaked the trigger offset and pulled a little more out. Around 30-33 cruise and 26 wot. Yet to be road tested though.
It's currently drinking Jet Ultra which is a 97 octane e5 _________________ 2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
Posted: Thu Oct 14, 2021 12:31 pm Post subject: Re: Pinging under light load |
fl59bug wrote: |
It's a fair call, and certainly one I shall investigate.
I would expect to see it in the data logs though tbh. _________________ 2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172 |
Posted: Thu Oct 14, 2021 1:40 pm Post subject: Re: Pinging under light load |
UK Luke 72 wrote: |
Map is 95-97kPa
AFR 13.8
It's currently drinking Jet Ultra which is a 97 octane e5 |
95-97 Kpa is just about atmospheric pressure. At that point the advance should be 0 and the system running on the base map only, You don´t want the advance to begin to kick in until about 92 Kpa.
No wonder its pinging on less octane. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
Posted: Thu Oct 14, 2021 1:55 pm Post subject: Re: Pinging under light load |
Yes, but what does the system say at WOT? Probably something like 98 Kpa.
While I am no fan of MS the 12x12 ignition map is more than sufficient for a N/A engine, - provided your map sensor has a decent load range.
Also, are you running open or closed loop? _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=435993 |
panel Samba Member
Joined: December 02, 2001 Posts: 1091 Location: Victoria B.C. Canada
Posted: Thu Oct 14, 2021 2:05 pm Post subject: Re: Pinging under light load |
Are you adjusting the trigger offset at idle with the timing gun and have the the table fixed at 10° ?
You shouldn't have to keep adjusting it. Have it match what the timing says by adjusting the offset to match the 10° then leave it alone. _________________ My '65-Subaru EJ20 Turbo conversion |
Posted: Thu Oct 14, 2021 2:30 pm Post subject: Re: Pinging under light load |
Alstrup wrote: |
Also, are you running open or closed loop? |
A bit of both, it's been open all night this time as AFR seems pretty good.
100.2kPa, dropping to 97.3 by the time we hit 6500rpm _________________ 2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
oprn Samba Member
Posted: Thu Oct 14, 2021 2:32 pm Post subject: Re: Pinging under light load |
I am running 87 octane, 8.4/1, C/R, 31* total and 41* part throttle advance. No pinging anywhere in the load or RPM range. AFR is low 13s at full throttle and mid 15s at cruise.
Something seems odd to me… _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age)
panel wrote: |
You shouldn't have to keep adjusting it. Have it match what the timing says by adjusting the offset to match the 10° then leave it alone. |
I set fixed timing to 0, and then adjusted offset to get tdc bang on. No idea how or why I was a few degrees off but I haven't changed that for years.
So it's been off all this time. _________________ 2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
