tdoman Samba Member
Posted: Thu Oct 14, 2021 12:26 pm Post subject: Transmission for 1800cc |
I've got an 1800cc engine for my dune buggy. Can someone tell me the ideal transmission for this size of an engine?
I've busted the gears in a couple of small swing axle trannys and I'm assuming it's because I need a tougher tranny used in a vw bus? |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Thu Oct 14, 2021 12:32 pm Post subject: Re: Transmission for 1800cc |
Your question is too vague to give a realistic answer, A stock swing with a super diff might be all you need as a 2-d Mendi might also be all you need. Kinda like asking"how much does a bag of groceries cost?" _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
tdoman Samba Member
Posted: Thu Oct 14, 2021 2:12 pm Post subject: Re: Transmission for 1800cc |
Ok, what details do you need to answer the question?
Or is there some documentation you can point me to that explains what transmissions match with what motors? |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3284 Location: Rapid City, SD
Posted: Thu Oct 14, 2021 4:50 pm Post subject: Re: Transmission for 1800cc |
Some guys can make a stock used trans last for years in a bus with a 2332cc.
Some guys can break a built trans with a 3/4 worn out 1600cc.
Brian _________________ www.type-emotorsports.com |
stevebaz Samba Member
Joined: March 14, 2008 Posts: 189 Location: El Monte CA
Posted: Tue Oct 19, 2021 3:56 pm Post subject: Re: Transmission for 1800cc |
might help if you describe where and how you use it any frequent flyer miles or wheelies or drive like a motocross bike? what terrain are you driving. how hard you use it, ho long you use it. after you broke the first one what did you do do to the second one before you broke it? have you checked your tranny and engine mounts when you replaced the second tranny? lots of open questions. Have you talked to any tranny specialists for insite on what broke and why? |
oprn Samba Member
Joined: November 13, 2016 Posts: 12708 Location: Western Canada
Posted: Wed Oct 20, 2021 5:51 am Post subject: Re: Transmission for 1800cc |
The rule of thumb back in the day was that a stock Beetle transaxle was good to 150 HP but Dad's neighbor broke his early Bus transaxle in a light Buggy in half right over the diff with a stock 40 HP engine. That's the bellhousing I use now for an engine test stand. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
