INEEDAIR Samba Member
Joined: November 03, 2020 Posts: 10 Location: new york 11542
Posted: Fri Oct 15, 2021 3:40 pm Post subject: Weber jet question |
I need some advice on where to start. I have a 2332 bug with WEBER dual 48 IDF's. 044 heads. It's jetted for a much higher altitude than I am. I purchased the car from Colorado and now it's on Long Island. Basically at sea level. It's way to rich. It currently has 140 mains, 185 air corrections and 50 idle jets.
Zero bog or stumble. Just a sooty tailpipe and smells on the rich side. Suggestions??
Thank you. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Fri Oct 15, 2021 5:02 pm Post subject: Re: Weber jet question |
Should be the other way…less air at altitude equals smaller fuel jets
So when bringing to Seal Level you should need to increase jet sizes
50 idles seem way small |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Sat Oct 16, 2021 3:50 am Post subject: Re: Weber jet question |
Try 200 airs check float level & fuel pressure too _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
oprn Samba Member
Joined: November 13, 2016 Posts: 12714 Location: Western Canada
Posted: Sat Oct 16, 2021 6:42 am Post subject: Re: Weber jet question |
Don’t you just love the wild a$$ guesses on jetting when the OP doesn’t even say at what the engine RPM or load is? Never mind a plug color check or AFR reading… _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
Posted: Sat Oct 16, 2021 7:07 am Post subject: Re: Weber jet question |
well some of us have owned the same combo,, so we do know _________________ 'Black Ice'Drag Buggy 'Turbo'
oprn Samba Member
Posted: Sat Oct 16, 2021 8:19 am Post subject: Re: Weber jet question |
Ok, fair enough. _________________ We had the stone age, the bronze age, the industrial age and now we are in the age of mass deception and mind control for corporate profit. (The mass media age) |
txoval Samba Member
Posted: Sat Oct 16, 2021 9:50 am Post subject: Re: Weber jet question |
If it is rich at sea level, it was dog rich at much higher elevation… |
Ohio Tom Samba Member
Joined: February 09, 2006 Posts: 1660 Location: Marshallville Ohio
Posted: Sat Oct 16, 2021 6:10 pm Post subject: Re: Weber jet question |
50 idle sounds really lean for the application.
Usually end up at 60-65 idles for a motor like that.
Mains seem small too. She should want at least a 150 main.
What emultion tubes are you running?
Richness you smell might just be the mixture screws needed adjusted. |
