Correcting Dog Legs that were poorly done
mikelars
mikelars is offline
PostPosted: Sat Oct 16, 2021 1:49 pm    Post subject: Correcting Dog Legs that were poorly done Reply with quote
I have an issue where both dog legs were welded on with poor alignment (before I bought the bus). It annoys me every time I look at it, and I am trying to figure out if I can fix it. I have a welder, but no cutter.
Drivers side
Passenger Side Photo 1
Passenger Side Photo 2
I was looking to see if I could easily break a few spot welds, align it and re-weld it with better alignment, but it doesn’t look straight forward…
Here is my 1961 Beetle Restoration:
https://www.youtube.com/playlist?list=PLW_2wBCs4Ny2qXEPvdnfvEzN42T8JA8zO
Here is my 1966 Split Bus - Restoration Channel:
https://youtube.com/channel/UCPBRysmvrJlif2wzwEwiuwQ
2332 Torque Motor Build
https://youtube.com/playlist?list=PLW_2wBCs4Ny2HwsKM9QT4LFpcSqP3QG0p
Engine Rebuild 1968cc Playlist:
https://youtube.com/playlist?list=PLW_2wBCs4Ny1JbZ2EgJQQ2awfo0koZRqz
busdaddy
busdaddy is offline
PostPosted: Sat Oct 16, 2021 4:09 pm    Post subject: Re: Correcting Dog Legs that were poorly done Reply with quote
Hmmm...., there's a ton of spot welds all along where it meets the floor and seat stand, and a bunch more as well as some MIG beads where it meets the A & B pillars. At least that's how VW did it, whoever installed those could have done almost anything. Confused
How's the rest of the door gaps front, back and along the top?, a little door tweaking would be a whole lot less work.
Слава Україні!
Bulli Klinik
Bulli Klinik is offline
PostPosted: Sun Oct 17, 2021 7:33 am    Post subject: Re: Correcting Dog Legs that were poorly done Reply with quote
You’d be better off replacing them than trying to adjust them.
I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs
Help Help
Help Help is offline
PostPosted: Tue Oct 19, 2021 10:12 am    Post subject: Re: Correcting Dog Legs that were poorly done Reply with quote
If I remember correctly, to adjust the areas that you're pointing out you'll need to separate the inside and outside of the dog legs and re-weld them.
I got mine to fit without opening them up but check out this video from Glideking ===> https://www.youtube.com/watch?v=sexLbz4W9N8
tisius
tisius is offline
PostPosted: Wed Oct 20, 2021 8:49 am    Post subject: Re: Correcting Dog Legs that were poorly done Reply with quote
that is a good video!!
drive it like you just robbed the bank
.... if it ain't dutch, it ain't much!
